Old 09-15-2012, 11:40 PM   #15
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
12% loses. wow
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 09-16-2012, 10:12 AM   #16
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
Updated! Impressive numbers guys!
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 09-16-2012, 04:19 PM   #17
HP Turbine
Boosted
HP Turbine's Avatar
I'm very impressed by sycraft's numbers. I wish he would post his after numbers!
Old 09-16-2012, 04:38 PM   #18
sycraft
COTW 5/06/2013
sycraft's Avatar
I will, but have to wait for the article to be released, impressive though !! it is above 400 now.....
Old 09-16-2012, 05:03 PM   #19
HP Turbine
Boosted
HP Turbine's Avatar
Oh I know you have to wait. I've been waiting eagerly. but that number is promising so far!
Old 09-16-2012, 05:21 PM   #20
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Also, would like to know if there is a difference in the Dyno used for his numbers stock to be so much higher then everyone else, especially HP since you did 3 mods.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 09-16-2012, 09:06 PM   #21
HP Turbine
Boosted
HP Turbine's Avatar
other than being a manual, I think he has magic in that engine.
Old 09-16-2012, 09:18 PM   #22
ecko04
Drives: Too many to list
Lets NOT start comparing dyno graph A to someone else's unless you were both dynoing at the same facility.
A dyno result should be for you. Use it to compare future dyno plots to see gains/losses from mods or whatever. You should use the same dyno facility to get the best comparable data - you should also dyno in the same weather conditions.
Comparing dyno plots to others is almost pointless.. too many variables are at play to get a fair comparison.
For example you could take your car & current set up TODAY to 5 different dyno's in your local area and you'd get 5 different numbers.
Dyno's are a tuning device not a precision machine.
What's even more absurd is how someone will dyno on a Mustang dyno, get XXXwhp and claim that it's X% higher on a dynojet without even testing it on a dynojet.
ecko04 is offline   Reply With Quote
Old 09-16-2012, 09:27 PM   #23
rickyrocket
rickyrocket's Avatar
Drives: 2015 blk 1 SS
Im impressed w/all...keep moddin I like to see the results
rickyrocket is offline   Reply With Quote
Old 09-16-2012, 09:32 PM   #24
'11CamaroLS
'11CamaroLS's Avatar
Drives: 2011 Camaro LS
Originally Posted by IneedAZ View Post
I have been looking at the IPF and Triffecta Tunes? IPF claims 10% increase, so i would like to see some dyno results showing that.
Good luck trying to get a dyno sheet for IPF. I asked them a while ago about info and all they responded quickly and said was the 10% gain etc, as soon as i asked for a dyno i never heard a reply again, i then sent another message and still no reply. plus there dynos are iffy cause they show crank hp or something.
I have no real issuses with trifecta, Im happy with it, plus you can get e85 and no2 tunes with trifecta
'11CamaroLS is offline   Reply With Quote
Old 09-22-2012, 04:18 PM   #25
IneedAZ
IneedAZ's Avatar
I am at the dyno today waiting for my turn. Hope to have results soon.
Old 09-22-2012, 07:06 PM   #26
IneedAZ
IneedAZ's Avatar
Well, think i waisted my time doing the dyno today. My numbers were way less then expected. 269hp and 236TQ. 92 degrees w/58% humidity. Used a Dynojet with SAE correction. 11,100 miles
Couple things the guy running the dyno mentioned that the air temp/humidity hurt my numbers a little. Also, he said my numbers would have been higher with 18" or 19" wheel/tires instead of the 20s. He did say his dyno is the latest model and calibrated within the last 6 months.
I would like to ask those that did the dyno already to list your rim size and do u know when the dyno was last calibrated.
Old 09-22-2012, 09:04 PM   #27
HP Turbine
Boosted
HP Turbine's Avatar
I did mine on 20's. I'm not sure the last calibration, but I could find out.
Old 09-22-2012, 09:14 PM   #28
IneedAZ
IneedAZ's Avatar
we were close in tq but u had me by 8hp
