SDTW Custom Wheels & Tires
Old 09-22-2012, 09:28 PM   #29
HP Turbine
Boosted
HP Turbine's Avatar
Drives: 2012 1LT RS... with snails
yeah. still a good run. Now its tune time!
IPS Twin Turbos, Corsa Exhaust, Ported Throttle Body. 461 rwhp 443 rwtq!! *Cameron Hass.ani*
HP Turbine is offline   Reply With Quote
Old 09-22-2012, 10:54 PM   #30
HP Turbine
Boosted
HP Turbine's Avatar
Wait. I'm sorry but why would the HP be higher with smaller rims??? I know the radius of the wheels between the 18s, 19s, and 20s is practically similar and the weight difference between the three is also minimal. So what would make more HP?
Old 09-22-2012, 11:43 PM   #31
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Dyno guy was talking about rolling mass. He said he had a car on the dyno that they changed the tire size by 2" and showed almost 80hp less
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is offline   Reply With Quote
Old 09-23-2012, 08:02 AM   #32
HP Turbine
Boosted
HP Turbine's Avatar
80! seems a bit much. If you had small tires tires A) you'd need to recalibrate your speedo. B) It would look stupid.
Keep the 20s
Old 09-23-2012, 08:47 AM   #33
IneedAZ
IneedAZ's Avatar
I wouldn't change..just stating what he said he experienced by just changing tire sizes.
Old 09-23-2012, 08:57 AM   #34
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
I have the 18" steelies - not sure how much lighter they are compared to the full on rims but I think your biggest pain point is the heat and humidity. Would have been good to see what the dyno numbers were when stock to really have a comparison.
The real truth to dynos is that you can't 100% compare your dyno numbers to anyone else's unless it was on the same dyno with the same conditions. Each dyno is going to be different - some in my town are known to be ball busters while others are known to read high. Then other companies are known to mess with the calibration for any car that wasn't built by them just so they can sell you performance parts and then adjust the dyno back to normal so they can show a huge improvement in HP after they're done.
Were you running 87 octane or 93?
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline   Reply With Quote
Old 09-23-2012, 09:05 AM   #35
HP Turbine
Boosted
HP Turbine's Avatar
the 19s are a bit lighter.
http://www.camaro5.com/forums/showthread.php?t=51143
Old 09-23-2012, 09:15 AM   #36
meissen
meissen's Avatar
Sorry looking at that link I realized mine are 18" -- I have the heritage steelies that come on the LS.
Old 09-23-2012, 09:17 AM   #37
IneedAZ
IneedAZ's Avatar
Running 93 octane last 4-5 months
Old 09-23-2012, 09:30 AM   #38
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Tampa Orlando Dyno Tuning Camaro Corvette CTS-v GTO GM Trucks performance tuning
Mass build cars should have about the same horse power after leaving the factory. They have the exact same drivetrain built, but there is a little room for elevation and fuel type. On the same dyno, on the same day, they will be very close.
Its the dyno that plays the larger factor. Some dyno's read higher or can be made to read higher ( because higher numbers will help advertising for the shop), and some read lower and several reasons come into play on that.
Example,
Yesterday, I was tuning a package that the owner said was previously dyno'd at 499 RWHP on a mustang dyno in January on a dyno in Virginia on a cold winter day.
So like normal with no changes made to the calibration, Tampa Tuning did the normal baseline dyno pull, and we come up with 393 RWHP and 5 degrees of knock on a 248 Dyno Jet. Normally, Id expect those numbers to be reversed on two dyno types.
After tuning the package, I build it up to 430 RWHP.
So like I do with every client after we finish up the dyno tune and the street refinement process with them driving, I always ask if they notice a differance. The smile never lies. According to the owner, the car was faster with being quicker and smoother through the RPM band now. He was able to drive with the A/C on without the car stalling, and although the numbers were differant, the car performed much better.
So, the dyno is a tool. More can go into factors on why dyno themself read differantly, compared to why the same build packages on the same make and model vehicle, have differant numbers from dyno to dyno.
The dyno only shows me a graph of numbers, My HP Tuners scanner shows me how and why im getting those numbers.
www.TampaTuning.com
Phil
Tampa Tuning is offline   Reply With Quote
Old 09-23-2012, 09:51 AM   #39
sycraft
COTW 5/06/2013
sycraft's Avatar
I was running 93 with my graph as well.
Old 09-23-2012, 12:18 PM   #40
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
Good analysis, Phil, thanks.
I dropped almost ten pounds per wheel when I dumped my steelies and went with my aluminum wheels. Anybody need a set of four boat anchors/ashtrays?
People always seem to dwell on how heavy the stock mufflers are, and completely ignore how much their wheels weigh. Unsprung weight plays a (much) larger role in how your car accelerates, brakes and turns than any other weight loss regimen. Doubtful it would play much of a role in peak HP numbers, but it would make a difference in how fast the car is able to get to redline.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 09-27-2012, 08:12 PM   #41
wyd_trkr
wyd_trkr's Avatar
Drives: 2016 Camaro 2LT/RS A8
Question
Originally Posted by HP Turbine View Post
I did mine on 20's. I'm not sure the last calibration, but I could find out.
Nice Dyno numbers guys, but what have your 1/4 mile times been at the track, or nobody has done that yet with their 2012 LFX V6 yet? Also, any track time numbers with any 2LT's yet as well? Thanks in advance for the replies.
Regards, wyd_trkr
Bose Premium System
My Link Navigation
Onstar & Bluetooth Built-In
K&N Panel Filter
Lumar/Pro WindowTint
Mailto: wyd_trkr@bellsouth.net
wyd_trkr is offline   Reply With Quote
Old 09-27-2012, 08:31 PM   #42
sycraft
COTW 5/06/2013
sycraft's Avatar
http://www.youtube.com/watch?feature...&v=b3gDi8XlUoQ
