Billet Custom
Cosmetics and Lighting Modification Discussions External and Internal cosmetics modifications.
Old 06-26-2012, 06:05 PM   #1
SamHouseIII
I Carry!
SamHouseIII's Avatar
Drives: 2013 CRT ZL1
Need help with Technostalgia full LED tail lights
I have emailed Todd and have not received an answer back. Has been 2 full work days.
I need to know what the resistance is for the newer style lights from them, I have a late 2011 SS and the "check rear lights" is displayed for turn signals.
I read on here that there is a newer risistor type and need to know the value, to correct the BCM feed to the lights, I am tried of waiting and will fix it myself.
If anyone can post a picture of the value...thanks.
I am a Modaholic!! Please Help!! Do Not feed my addicition....See build...
http://www.camaro5.com/forums/showthread.php?t=261540
From Oklahoma, Join us on Facebook
https://www.facebook.com/groups/okcamaros/
SamHouseIII is offline   Reply With Quote
Old 06-27-2012, 09:45 AM   #2
BADMAB
Drives: Camaro
Those should only be for the 2012s. Did the resistors work at any point? Did you try calling Todd?
BADMAB is offline   Reply With Quote
Old 06-27-2012, 01:01 PM   #3
SamHouseIII
I Carry!
Not yet, I have been tied up with work
Old 06-27-2012, 02:18 PM   #4
BADMAB
Drives: Camaro
Understood. I think he's pretty slammed with e-mails all the time, but someone always picks up if I call.
And did the resistors work initially? If so then it's not the value that is the problem.
Old 06-27-2012, 05:57 PM   #5
SamHouseIII
I Carry!
Unplugged the lights/power and no change.
I got an email back from him and let him know whats going on. Basically the turns produce the MAL, sometimes they work, sometimes not.
Old 06-27-2012, 08:23 PM   #6
Abstrak
Abstrak's Avatar
Drives: 2012 AGM Camaro LS / Team LFX
Its 50w 1ohm I believe you can jimmy rig 50w fuse to if you cant find the resistor let me check my car a little later and I'll get the specifics I'm pretty positive its 50w 1 ohm look for an orange resistor
Matterfact search my post because I had a problem with a broken prong on one of my resistors when I first got my set.
I found it for you these are the new resistors and the pic shows what was wrong with mines.
Abstrak is online now   Reply With Quote
Old 06-27-2012, 10:09 PM   #7
SamHouseIII
I Carry!
Thanks for the info, I did disconnect the power from the lights and battery, still same results.
Old 06-28-2012, 02:29 PM   #8
BADMAB
Drives: Camaro
Abstrak is right on. It sounds like the joint on your resistor is dorked. See what Todd says, but I would say you'll need a new one.
