Jason 98 TA
Old 06-26-2012, 07:19 PM   #1
ZL1 Brian
ZL1 Brian's Avatar
Drives: 2012 Camaro ZL1
Mild to Wild problem!
I installed the mild to wild exhaust tuner on my ZL1 and I believe I installed it correctly, but the baffles are open all the time, they wont close when it's turned off. Any suggestions?
ZL1 Brian is offline   Reply With Quote
Old 06-26-2012, 07:50 PM   #2
DangerZL1
Drives: Accord Coupe
Are you saying the Mild to Wild controller won't open and close the baffles while you are driving below 50% throttle?
DangerZL1 is offline   Reply With Quote
Old 06-26-2012, 08:19 PM   #3
ZL1 Brian
ZL1 Brian's Avatar
No. The baffles stay open at all times. When turned off the baffles should be closed at idle. I'm not sure if it is the controller or perhaps my install?
Old 06-26-2012, 09:36 PM   #4
DangerZL1
The baffles should be open when the car is off and at idle. This is why it sounds good when you start up the car. If you pull the fuse the baffles will stay open all the time. If the switch works while you are driving, then it sounds like everything is ok. The controller doesn't close the baffles at idle. It either leaves them open all the time or allows the car to function as it did stock. The Vette system closes the baffles at idle from the factory, so the mild to wild controller makes a bigger difference. There is no difference at idle with the ZL1 controller on or off.
I have the exhaust commander on my car which operates the same as the mild to wild controller.
Old 06-26-2012, 10:03 PM   #5
ADM PERFORMANCE
Drives: 2016 CAMARO SS
This is why I think it is #1 stupid mod you can do to this car!
BTW-It would be nice to close them at idle ....Hmmmmm
Gm did a great job at making it perfect right out of the box
ADM PERFORMANCE is offline   Reply With Quote
Old 06-26-2012, 10:12 PM   #6
DangerZL1
A stealth mode would be nice for those early morning departures or late night arrivals.
Old 06-27-2012, 11:58 PM   #7
oortcloud
oortcloud's Avatar
Drives: 2013 ZL1 ordered
Thats what I'm thinking. I sometimes want steath mode.
There's one type of exhaust commander that allows you to set the rpm. I wonder if that would also close it at idle?
oortcloud is offline   Reply With Quote
Old 06-28-2012, 06:13 AM   #8
DangerZL1
Which one?
Old 06-28-2012, 02:17 PM   #9
oortcloud
oortcloud's Avatar
http://www.sunsetorangecreations.com...nder_Elite.php
I just noticed its made for the vette, so maybe it does not work on the zl1. But it looks like you can set the rpm where it opens, and then set the rpm where it closes.
Old 06-28-2012, 02:46 PM   #10
DangerZL1
I purchased my Exhaust Commander from them. It works as advertised, but I didn't see where the Elite model was available for the ZL1. Maybe its possible or in the works
Old 06-28-2012, 06:15 PM   #11
rmyers
rmyers's Avatar
Drives: Both American Made
Tell us how you really feel Andy!!!!!
PS...My wife just smiles at me every time I crank my car in the garage!!!
2012 ZL1 #213 M6 Black on Black
2013 ZL1 #2638 Convertible Auto
2010 Chevrolet Suburban
2011 GMC Seirra HD Denali
rmyers is offline   Reply With Quote
Old 06-29-2012, 07:40 AM   #12
ADM PERFORMANCE
As of yesterday we now have stealth mode
Systems designed.
TUSCONZL1 got the first one
Old 09-20-2012, 05:04 PM   #13
jsd
jsd's Avatar
Drives: 2012 ZL 1 #370
Hi guys
Works the exhaust commander on the zl1 or just on the corvette.
I think about to order some mild to wild system, but the exhaust commander is more interesting
jsd is offline   Reply With Quote
Old 09-21-2012, 08:55 AM   #14
Drew P
Drew P's Avatar
Drives: Camaro ZL1
I noticed the npp exhaust on our cars uses a vacuum reservoir on the passenger side of the vehicle. If you could wire a 12v switch to the hot wire leading back to the vacuum solenoid, i think you could effectively have a switch to close the baffles, even at idle. Has anyone tried anything like this?
Drew P is offline   Reply With Quote
