Gen5DIY
Old 06-26-2012, 07:56 PM   #1
Caddyroger
Caddyroger's Avatar
Drives: 2011 RJT Camaro LT2 RS auto shift
Metra dash kit
How easy is the Metra kit to install? I might have to trash the Scosche kit. I have a problem with a dead battery every once in a while. 3 times since March.
Caddy
Caddyroger is offline   Reply With Quote
Old 06-26-2012, 08:40 PM   #2
Griffintile
Drives: 2011 IOM 2SS/RS L99 convertible
It installs relatively the same might even be a little easier, with better directions.
Griffintile is offline   Reply With Quote
Old 06-26-2012, 09:12 PM   #3
Caddyroger
Caddyroger's Avatar
Never mind it does not need any thing for Onstar to work
Caddy
Old 06-26-2012, 11:47 PM   #4
Griffintile
It will work fine with a fark harness or stock speakers and stock amp. Gets a little tricky when you run all new wires, speakers and amp. I used my center speaker tapped in to the front left output of kit harness before it hooked into factory harness. On the scosche kit I added an eight ohm resistor to the postive speaker wire to lower the volume. Metra kit should be able to use the black/yellow wire to adjust volume per directions. With schosche kit I get chimes, backup chimes, and blinkers through built in speaker on backside of touch screen, Onstarr and factory Bluetooth comes through center speaker.
Old 06-27-2012, 06:42 AM   #5
jydenwr
jydenwr's Avatar
Drives: 2012 CHEVROLET CAMARO ZL1 (BLACK)
Can I add the Metra Dash kit to the ZL1? Won't it mess up the HUD on it or everything will be the same?
jydenwr is offline   Reply With Quote
Old 06-27-2012, 08:40 AM   #6
Griffintile
I believe the zl1 and all camaros so far use the same dash kits. Will not mess up HUD just will not show song title.
Old 07-02-2012, 02:25 PM   #7
jydenwr
jydenwr's Avatar
I cannot get OnStar to work, so I need the 12K ohms resistor, so where the heck do I put that? Everything else works but Onstar, PTT and Mute button from the steering wheel.
