Caryle Racing
Old 06-27-2012, 09:13 AM   #1
Beave
Beave's Avatar
Drives: 2014 RRM 2SS/RS LS3
For those who don't know!
I have a 2011 SS/RS with around 10K miles. I started hearing a slight rubbing sound when backing out of the driveway, or turning at slow speeds. I looked at everything, and could never find a sign of the noise. I didn't hear the noise all of the time, just every so often. I took my car in yesterday for oil change and service, I asked the guys to check out the sound. Turns out that 2011 and 2012 models have an issue with a clutch located in the rear of transmission. I could never pin point the sound, but evidently it was coming from the under the center of the back seat (location of transmission and differential). The service guys said that it is not a recall but an issue they are watching and playing close to the vest. The fix is to drain and change out the transmission and differential fluids then replace with a special super secret fluid. The service guys said so far only one car has had to have parts replaced, and that included a transmission and rear end.
Beave is offline
Old 06-27-2012, 09:18 AM   #2
Ladybugsmom
Older than I look....
Ladybugsmom's Avatar
Drives: 2010 VR Camaro 2SS/RS LS3
Special super secret fluid???
High Heels and Fast Wheels!!
Ladybugsmom is offline
Old 06-27-2012, 09:21 AM   #3
Beave
Beave's Avatar
I said super secret fluid, because when I asked what they were replacing it with they would only say that it was a special fluid recomended by GM for the fix. They would never give me a brand or any other details. They said GM was being very cautious about this issue
Beave is offline
Old 06-27-2012, 09:21 AM   #4
Chrisrp454
Chrisrp454's Avatar
Drives: 2010 ABM 2SS/RS M6, 98Z28 M6
It's Secret Sauce!
Always Remember! Rest in Peace Brothers
9/11/2001. And thanks to all those who defend and serve!
Ordered 5/23/2009
3400 with TPW of 08/03/09
3800 8/11/2009
Arrived 8/21/2009 2SS/RS/Aqua Blue/Grey Interior
Chrisrp454 is offline
Old 06-27-2012, 09:22 AM   #5
dkg11
dkg11's Avatar
Drives: 2010 Camaro 2SS
i have a 2010 ss and i have a similar problem everyonce in a while when backing out of a driveway...only happens on an incline and its only once and a while and it sounds like your scrapping the bottom a little... should i be worried about this or say something tot he dealer? also ever have problem putting itin reverse or it not go into reverse smoothly?
2010 Camaro 2SS/LS3
Magna Flow Street series Exhaust
Airaid Intake+throttle body
Custom tune by Bob Morreale www.thetuningschool.com
QTP Electronic Exhaust cut-outs
12'' Alpine type R with 1500watts double ported box
Tinted windows
392RWHP on Mustang Dyno
#13933
dkg11 is offline
Old 06-27-2012, 09:25 AM   #6
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
Originally Posted by Chrisrp454 View Post
It's Secret Sauce!
so.......if he ever wants or needs to replace it he has to go to "JACK in the BOX" .... hmmmmmmmmmmm
Sir Nuke is offline
Old 06-27-2012, 09:26 AM   #7
Beave
Beave's Avatar
The service guys didn't say anything about 2010, only 2011 and 2012. But that sounds like what I was hearing. I never had issues with putting it into gear. I have had no issues at all, other than the sound. It was pretty clear that the car should not be making that sound
Beave is offline
Old 06-27-2012, 09:27 AM   #8
midnighter
Drives: nothing
It's Secret Sauce!
Thousand Islands dressing?
midnighter is offline
Old 06-27-2012, 09:31 AM   #9
Beave
Beave's Avatar
I don't care if it's balsamic vinaigrette just so long as it fixes the issue
Beave is offline
Old 06-27-2012, 09:32 AM   #10
meissen
Founder - Michigan FBody
meissen's Avatar
Drives: 1994 Camaro LT1, 2016 Camaro LT
Had you changed your transmission and differential fluid yourself yet? I changed mine and the fluids that came out from the factory were nasty and had a lot of gunk in it. If I hadn't changed the fluid, I can imagine it'd be a problem in time. Curious if yours was still the factory fluid or replaced?
2016 Camaro 1LT V6 A8 - "Elmo" - LGX V6 with 8-Speed Automatic, NPP Dual Mode Exhaust
1994 Camaro LT1 A4 - "Red Alert" - v6-to-LT1 Swapped Cruiser; Cammed, Stalled, Enjoyed
"Gone But Not Forgotten"
2014 Camaro 1LT M6 - "Cherry Bomb"
2012 Camaro 1LS M6 - "Clifford"
Michigan FBody Association
http://www.mifbody.com/
meissen is offline
Old 06-27-2012, 09:34 AM   #11
Secret Squirrel
Secret Squirrel's Avatar
Drives: 1965 Chevelle Malibu
Thousand Island dressing is some bad ass stuff. Only a matter of time before they broke into the automotive industry. You can use it for just about anything...burgers, fries, salad, differentials...you name it!
Secret Squirrel is offline
Old 06-27-2012, 09:34 AM   #12
dkg11
dkg11's Avatar
ill ask them at the dealership when i bring it in friday for some other maintenance but thank you!
2010 Camaro 2SS/LS3
Tinted windows
#13933
dkg11 is offline
Old 06-27-2012, 09:37 AM   #13
Beave
Beave's Avatar
I had not changed the fluids, it was factory fluid.
Beave is offline
Old 06-27-2012, 09:38 AM   #14
meissen
meissen's Avatar
Wonder if that's what the cause was. I know my factory fluid was absolutely disgusting when it drained out. I changed mine around 2,000 miles to switch over to fully synthetic.
meissen is offline
