Flowmaster Exhaust
Old 06-27-2012, 08:30 AM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Intercooler Pump Upgrade!!
After a lot of testing finding the limits of the supercharger cooling system and addressing the reservoir, or lack of as well as the heat exchanger we knew the small 4GPM pump was going to be a restriction on anything making additional heat/boost or doing any kind of racing.
The stock intercooler pump on the ZL1 only flows 4gpm and that is rated without any hoses, fittings, lines to the core etc that can slow down the flow or any restrictions in the intercooler system impeding flow. Although that may be enough for a stock ZL1 we believe that it's not going to be enough to provide adequate cooling in higher hp applications. We're also not the only ones that believe this. As mentioned above, for the 2010 Super Cobra Jet Ford ditched the stock pump for a higher flowing 55gpm pump. Since the Super Cobra Jet has already been 8's and that size pump worked for them it's safe to say that if we were to upgrade our system the 55gpm would be the one to go with. Again, many assume that 55GPM may be too much but this rating does not take into consideration the 3/4 or 5/8 hose ends going on the end of the pump or the other restrictions inline that drastically slow down flow to nearly 20GPM.
The pump is a direct bolt-on install and uses the factory OEM mounting hardware/location. There is some small wiring involved but nothing most cannot take care of on their own.
Meister@Torq is offline   Reply With Quote
Old 06-27-2012, 08:55 AM   #2
Joebot8484
ZL1 # 1307
Joebot8484's Avatar
Drives: 2012 Camaro ZL1, 2008 Hummzilla H3
Interesting.
Click on my signature for my build thread
Joebot8484 is offline   Reply With Quote
Old 06-27-2012, 09:04 AM   #3
Meister@Torq
We have seen 15+ degree drops in temperatures without much rise at all. This is MASSIVE improvement. The factory 4GPM is simply not enough. With the restrictions and hose reductions this is about a 20GPM gain in flow.
Old 06-27-2012, 09:07 AM   #4
alex33x
Drives: 2013 Camaro ZL1
PM Price please.
Devliered July 20, 2012
alex33x is offline   Reply With Quote
Old 06-27-2012, 09:37 AM   #5
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
Interesting... I remember reading it's IC pump is the Volt's coolant pump, but bumped from around 50-some-odd-watts to something like 80-some-watts for ZL1. Flow is what I'm more concerned with, and it's looking like this is definately a winner.
SUBSCRIBED!
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 06-27-2012, 09:40 AM   #6
b_williams_82
b_williams_82's Avatar
Drives: 2013 ZL1 #142
Can you also PM me the price as well? Thanks!
Order # QHQWJF
Current Status: 4200 VIN 142
1100, (04/25/12): 2000, (05/21/12): 2500, (5/22/12): 3000, (5/22/12): 3100, (5/31/12): 3300, (5/31/12): 3400, (6/7/2012): 3800, (6/15/2012): 4000, (6/15/2012): 4104, (6/15/2012): 4106, (6/19/2012): 4150, (6/19/2012), 4200, (7/16/2012), 4300, (7/18/2012), 4B00, (6/15/2012) , 5000, (7/25/2012)
6000, Delivered to the customer (8/2/2012)
b_williams_82 is offline   Reply With Quote
Old 06-27-2012, 10:06 AM   #7
HDRDTD
You're going from a 4gpm to a 55gpm? that's a hellofa jump.
Old 06-27-2012, 10:43 AM   #8
Silverguardrail
Silverguardrail's Avatar
Drives: 2012 ZL1 #1448
What about putting a thermostatically controlled electric fan in front of the heat exchanger ?
2012 ZL1 SIM, MN6, B92, RTQ
ZL1 - the true definition of joy ride
Silverguardrail is offline   Reply With Quote
Old 06-27-2012, 10:59 AM   #9
Meister@Torq
We have a dual pass heat exchanger with fans already out for these cars.
Old 06-27-2012, 10:59 AM   #10
Meister@Torq
55GPM is the free flow rate but with all of the line restrictions and system restrictions it becomes more like 20 or so.
Old 06-27-2012, 11:07 AM   #11
Meister@Torq
The kit comes with 2 fittings for the pump and necessary wiring and relays. Not only does this MOUNT in the stock location without modification it uses the factory PCM control for on/off.
Old 06-27-2012, 11:08 AM   #12
Silverguardrail
Yes I know... I should have said have you put your dual fan on the stock heat exchanger and stock pump ?
What was the results ?
Old 06-27-2012, 11:20 AM   #13
Meister@Torq
Our fan kit will not bolt up to the stock heat exchanger. Our dual pass units have a mounting frame built into them to allow for the fan kit to bolt up.
We know the factory heat exchanger does not even do a good enough job on a stock car so we replace them on almost every build we do, but make them a requirement once a pulley is added.
Old 06-27-2012, 11:23 AM   #14
bwnunnally
Drives: 2008 Cadillac STS-V
Send a message via AIM to bwnunnally
Good job doing the work and packaging this for the Camaro ZL1.
Do you have a pump performance curve for the 55 gpm pump and a system resistance curve for the ZL1?
You have it plugging into the IC pump harness, so it pulls few enough amps to work there?
Have you tested the actual flow through the system with this pump?
I have been doing some intercooler pump flow tests on my STS-V so I am interested in how this pump might do in the similar Cadillac setup.
Intercooler pump test 4: Jabsco 29 gpm pump
bruce
CaddyInfo; Blog
2008 Cadillac STS-V -- Spectre CAI, Corsa, S3TC HX
bwnunnally is offline   Reply With Quote
