Emblempros
Old 06-27-2012, 12:25 PM   #1
cris
Drives: 2010 Camaro SS L99
difference for the LT headers in 1 7/8 or 1 3/4
I need to know if you guys know the difference and which one is better, because I just buy the 1 3/4 LT HEADERS and I see other brands who make this in 1 7/8 to.....
thanks
cris is offline   Reply With Quote
Old 06-27-2012, 01:07 PM   #2
hapisok
crazier than a coconut
hapisok's Avatar
Drives: 2010 2SS/RS LS3
1 3/4 if you don't plan on making ridiculous HP...1 7/8 for ridiculous HP...and 2" for INSANE HP.
hapisok is offline   Reply With Quote
Old 06-27-2012, 01:12 PM   #3
Juiced1
Juiced1's Avatar
Drives: 2012 2SS CAMARO 45th
Generally when you use a header that is to big for your application you lose some torque down low. For LS3 applications a 1 7/8 tube seems to be a great blend for top end power and torque and doesn't seem to lose anything down low. The 1 3/4" seems to be lost to the LS3 Camaro's but would actually be suited just fine for a bolt on car but at the same price you'd be better off with the 1 7/8". I wouldn't recommend the 2" header to anyone under 800 HP or so.
Juiced1 is offline   Reply With Quote
Old 06-27-2012, 01:18 PM   #4
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2014 GMC Sierra Denali
Originally Posted by Juiced1 View Post
Generally when you use a header that is to big for your application you lose some torque down low. For LS3 application a 1 7/8 tube seems to be a great blend for top end power and torque. The 1 3/4" seems to be lost to the LS3 Camaro's but would actually be suited just fine for a bolt on car. I wouldn't recommend the 2" header to anyone under 800 HP or so.
Grrrrr, show me some dyno charts that validate your claim of "loss of low end torque." You are perpetuating a myth!
The only drawback to larger primaries is cost (and fitment to a lesser degree). You do not lose low end with these cars with increases in primary diameter.
2011 2SS/RS M6 CGM Rotofab CAI, Kooks 1 7/8, Corsa (LS3)
geaux_tigerss is offline   Reply With Quote
Old 06-27-2012, 01:35 PM   #5
caverman
caverman's Avatar
Drives: '69 SS Convertible
I have 1 3/4" because I got a smokin' deal on a set of used ones. No way I could've turned them down. I don't have true back to back comparison because I've never switched them out. However, I can say my car still runs good at the track. I've even beat other Camaros that had the same basic bolt-ons but with 1 7/8" headers (difference being that I had suspension work and they didn't). My car dynoed about 3 less HP than the average 1 7/8" on the same shop's dyno.
All in all there is nothing wrong with 1 3/4" headers. You'll never notice or feel the difference in 3 or 4 hp. That being said, if I were to buy brand new and money not being an issue I would still lean towards 1 7/8" just in case you were to add a big cam or super charger down the road. If you know for sure you won't do that or you found a good deal on 1 3/4" then stick with that.
Build Journal
Old 06-27-2012, 01:40 PM   #6
IndeedSS1
IndeedSS1's Avatar
Drives: 2010 Camaro SS LS3
Actually Juiced1 is correct. It is way down low though.
I went from SOLO cats to 1 7/8 headers and immediately noticed a difference. The way to maximize testing this, would be to cruise down the hiway at 65 mph in 6th gear (LS3), quickly increase the throttle position by a very small percentage and not only pay close attention to how much squat you feel but how quickly the mph increases. There is a noticable difference. Once you move up in the rpms it no longer is noticable and the opposite happens.
It is hilly around and I noticed I had to give it more throttle to maintain a climb or downshift where-as before the headers it would climb no problem. Don't get me wrong, once up in the rpms the headers really shine.
She is only memory now.
IndeedSS1 is offline   Reply With Quote
Old 06-27-2012, 03:23 PM   #7
nighttowl
nighttowl's Avatar
Drives: 2014 ZL1 2010 Camaro 2SS/RS
if you have ported heads, go with the bigger ones. i went with 1 7/8 because that is how big the exhaust ports were. stock heads, go with 1 3/4.
"The salesman actually told me to stop getting it sideways during the test drive; so you can’t say I wasn't trying."
2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq
2014 CRT ZL1 574 rwhp, 537 rwtq
nighttowl is offline   Reply With Quote
Old 06-27-2012, 03:29 PM   #8
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Exactly. I did a true back to back dyno back in the day on my LS1 bolt on 98 SS. I had 1 3/4 headers and then swapped to 1 7/8 headers. The dyno curves were EXACTLY the same from just under 2,000 all the way to about 4,500. After 4,500 rpm the HP and TQ both started climbing on the 1 7/8 headers. The difference was only about 5 hp 4 tq but remember this was only a bolt on LS1 so anything with more power like our LS3 will have a bigger gain.
I think 1 3/4 are a waste on these cars unless you get them for a CRAZY good price, like $100. I went with 1 7/8 but would swap to 2" on my bolt on car in a heartbeat if they weren't so expensive.
SUX2BU is offline   Reply With Quote
Old 06-27-2012, 03:54 PM   #9
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Actually, dyno tests have shown ZERO low end difference between the 1 3/4, 1 7/8 and 2". The HP and Trq curves are identical until you reach the 4k rpm range. After 4k, the 1 3/4 begins to drop off from the other 2.
Old 06-27-2012, 03:57 PM   #10
MarylandSpeed
MarylandSpeed's Avatar
Drives: 2012 ZL1 & 2010 2SS/RS
No one really runs 1 3/4" on these cars. 1 7/8" are pretty much the same powe wise, and give you room to grow. The only exception is stepped headers. When designed right, a 1 3/4" stepped to 1 7/8" header can out perform a straight 1 7/8" header.
443-730-9428 - www.marylandspeed.com - Great Prices and Free Shipping!
MarylandSpeed is offline   Reply With Quote
Old 06-27-2012, 04:02 PM   #11
dekan513
chevy pride
dekan513's Avatar
Drives: 2ss/rs
i seen test from someone i think it was jannetty racing that did a comparison
check out ky speeds fb page https://www.facebook.com/kyspeed
dekan513 is offline   Reply With Quote
Old 06-27-2012, 04:30 PM   #12
geaux_tigerss
Yep, and that test showed that bigger primaries had higher tq and hp all the way through the rpm range. I want to see a single dyno that shows otherwise. Back pressure is a myth on modern fuel injected cars.
Old 06-27-2012, 05:02 PM   #13
Whitehambone
Whitehambone's Avatar
Drives: 2011 Camaro 2SS
Look into Kooks stepped headers if you can't decide. They start at 1 3/4 and step up to 1 7/8. My tuner showed me several dyno sheets with the same mods compared to mine on one sheet. Mine did better than the others in HP and TQ.
Whitehambone is offline   Reply With Quote
Old 06-27-2012, 05:05 PM   #14
BlackM6RS/SS
BlackM6RS/SS's Avatar
Drives: 2010 Black M6 RS/2SS
ARH 2" wouldn't be bad on a all out Heads Cam build like I see shops run on big builds!
10 Blk/Blk RS/2SS w/CGM Stripes
ADM H/C/I M6 480rwhp 435rwtq
FE4 LCAs w/Pfadt ZL swaybars Diff bushings Trailing arms Drop springs
BlackM6RS/SS is offline   Reply With Quote
