Old 06-27-2012, 02:45 PM   #1
Meister@Torq
Drives: 2001 Crown Vic
Send a message via AIM to Meister@Torq Send a message via MSN to Meister@Torq
Airaid Cold Air Intake!!!
Finally we are able to release this info. We have been working exclusively with Airaid for the last few months developing a cold air intake specific for the ZL1.
We cannot release our dyno numbers, you will have to wait for GM High Tech Magazine to release these (coming to the shop tomorrow to test our first three performance packs) but I can tell you this thing makes HUGE HP/TQ. Airaid may be able to provide you with gains and dyno sheets
These intake systems feature Airaid's new large, one-piece, rotational-molded air box and totally redesigned air intake tube. These new one-piece air boxes house Airaid's exclusive air filter which, when combined with the CAD-designed intake tube, provides improved horsepower, torque, and MPG. All MXP series intake systems include all of the necessary hardware and easy-to-follow instructions for a quick and hassle-free installation.
Massive Tubing
HUGE Gains in horsepower and improved throttle response
Feeds air directly to the high performance, premium filter
Allows only cool, outside air to the intake
Lifetime filter is washable and reusable
Simple to install with just basic hand tools
System is computer designed for a perfect fit
These will be IN STOCK within 1 week and we will be the FIRST to have them. They are available on our website now.
Meister@Torq is offline   Reply With Quote
Old 06-27-2012, 02:47 PM   #2
cjon9657
cjon9657's Avatar
Drives: 2010 Camaro LS
Send a message via MSN to cjon9657
I love Airaid, the install was so easy.
cjon9657 is offline   Reply With Quote
Old 06-27-2012, 05:29 PM   #3
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Tune required?
Thanks
FSTORG5 is offline   Reply With Quote
Old 06-28-2012, 06:11 AM   #4
BlackedOutZL1
Boss Killer
Drives: 2012 ZL1, Black, A6
no air leaks in through the hole for the washer fluid fill?
Is there some kind of gasket there?
1100 : 2-6-12 Order placed at dealership, QDQS6G
2000 : 4-21-12 Oder accepted by GM
2500 : 4-24-12 Order preferenced. Order pulled into production
3000 : 4-25-12 Order accepted by production control
3300 : 5-10-12 Order scheduled for production
3400 : 05-15-12 - Order Broadcast (internal plant paperwork order produced)
3800 : 5-23-12 - Order produced VIN 1477
4000 : 5-23-12 - Vehicle available to ship
4150 : 5-23-12 Invoiced (order is invoiced to the dealer)
4200 : 5-26-12 Bayed waiting transport
5000 : 6-6-12 Delivered to dealer
BlackedOutZL1 is offline   Reply With Quote
Old 06-28-2012, 12:27 PM   #5
Meister@Torq
It is a pretty tight seal and not enough airflow will escape through the 'sealed box' enclosure to defeat it's purpose. Airaid has had this box out since the first SS with zero issues.
Old 06-28-2012, 12:28 PM   #6
Meister@Torq
Originally Posted by FSTORG5 View Post
Tune required?
Thanks
Yes. We feel any intake worth putting on will require a tune. Airflow drastically increases with this setup
Old 06-28-2012, 05:20 PM   #7
FSTORG5
Fast Orange
FSTORG5's Avatar
Drives: 2012 ZL1
Thanks. It is hard to see in the picture, but the box appears to be more of a "bucket" compared to others. Where does it pull air from with the hood closed? It doesn't look like it is open to the front.
Old 06-28-2012, 08:35 PM   #8
DangerZL1
Drives: Future ZL1 Owner
I think it may be similar to their intake for the SS. I wondered the same thing, so I went to their website and looked at the SS intake.
DangerZL1 is offline   Reply With Quote
Old 06-28-2012, 08:59 PM   #9
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
What is the inside diameter of the intake tubing?
1st Gen Forever is offline   Reply With Quote
Old 06-29-2012, 09:29 AM   #10
Meister@Torq
This box is the same as the SS and uses the factory air scoop. Here is a picture of an SS kit that is the same
Old 06-29-2012, 10:01 AM   #11
Meister@Torq
At which part? It is over 4" the entire run with some velocity transitions. I can state that this intake is one of the best performing we have seen for the ZL1 to date and we work with Airaid because of their amazing quality and R&D process
Old 06-29-2012, 02:18 PM   #12
1st Gen Forever
ZL1 #140
Both between the TB and air filter as well as the front inlet to the air box. I would think the front inlet of the filter box should also be larger than the normal SS box to maintain high RPM supercharged airflow if someone were to combine this with other mods (102TB, porting, cam, exhaust) to improve airflow through the engine.
Old 06-29-2012, 03:26 PM   #13
Erik@Torq
Erik@Torq's Avatar
Drives: '10 SS + '04 Z16 Z06 S/C
Send a message via MSN to Erik@Torq
This airbox will support well over 85lb/min before it becomes a restriction. This is something that Airaid took into consideration when developing the kit
When we get the next one in, I can take measurements. The opening at the filter is much larger
Erik@Torq is offline   Reply With Quote
Old 06-29-2012, 05:00 PM   #14
1st Gen Forever
ZL1 #140
Nice. Thanks. I'll be watching this as I'm knee deep in upgrades right now and might try out some different CAIs to see what works best with high flow.
