ModBargains
Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust
Old 06-28-2012, 10:25 AM   #1
Aries240SS
Drives: 2011 1SS RS Camaro, 1995 LSX 240SX
Trunion Upgrade Questions
I know some of you must have already done this with your cam swaps, but I'm looking for additional information on doing the trunion upgrade at home without a normal press. Simple things like, can it be done with a smooth vice? Or are most of you taking your rockers to a shop to have the upgrade done?
I know Texas Speed and some others do the upgrade with a rocker exchange, but I was looking at a few kits out there like Jannetty's 480 kit and they seem to come with the upgrade but you need to install it yourself. Hence the questions.
2011 Camaro 1SS/RS
Hotchkis Chassis Brace, Rotofab Intake, Hurst Short Shifter, BMR Springs / Trailing Arms / Sways, Nitrous Outlet 150 Shot, SubThump Stealth Box, TSP 1 7/8 Headers, VMax TB, JRE Scoop, Rotofab Washer Relocation, JRE Tune
Aries240SS is offline   Reply With Quote
Old 06-28-2012, 10:31 AM   #2
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS
Although, not quite as easy, I believe they do say in this video that assembly can be done with a standard vice.
blazzin1 is offline   Reply With Quote
Old 06-28-2012, 10:46 AM   #3
Aries240SS
Thank you sir! That video lead me to http://www.summitracing.com/parts/SME-906011/.
Looks like they put out a kit to do it with a vice already!
2011 Camaro 1SS/RS
Old 06-28-2012, 10:51 AM   #4
toml_pa
ʇuɐıʌǝp lɐıɔos
toml_pa's Avatar
Drives: 2011 2SS/RS LS3/M6
This Summit kit is great and well worth the $40.00. Just used it on my cam swap.
Way too many mods and way too much money. Wouldn't have it any other way.
toml_pa is offline   Reply With Quote
Old 06-28-2012, 10:57 AM   #5
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS
Hmmm, didn't know about that kit from Summit, but definitely looks like a good investment if you don't have access to a real press. Glad I could help a little anyway!!!
Old 06-28-2012, 04:19 PM   #6
Stealth 2010 2SS/RS
Stealth 2010 2SS/RS's Avatar
Drives: Black 2SS/RS M6
vice and a socket, thats all you need. Once you do one and you get everything down you can do the rest in about 30-45 mins. Easy upgrade.
2010 LS3 2SS/RS M6
AirAid Cold Air Intake, AAC LED sidemarkers, AAC P13w plasmas drl, Kook's Custom 1-7/8" Headers, Corsa Hybrid Exhaust
JRE 445 Cam Package, JRE SCT Tune, RX Catch Can and Breather
Tech AFX Heater Hose Relocation Kit, Black Chrome Wheels
Pfadt trailing and toe arms, Pfadt solid subframe mounts, Pfadt diff bushings, Street Slayer Twin Carbon
Technostalgia Camaro LED taillights, CTS-V Front Brakes, Powder Coated Calipers By ME
Stealth 2010 2SS/RS is offline   Reply With Quote
Old 06-28-2012, 04:35 PM   #7
MikeOD
Drives: 2010 M6 2SS
I've ALWAYS done it with a vice...done several sets now. You'll need a second person if the vice is horizontal because you'll need to keep things aligned where gravity can't help like it would in a vertical press.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust.
499 RWHP 463 RWTQ.
MikeOD is offline   Reply With Quote
Old 06-28-2012, 07:17 PM   #8
blake-b
blake-b's Avatar
Drives: Black 2010 2SS/RS LS3
Vise and socket here too. Maybe an hour to complete.
Old 06-28-2012, 07:32 PM   #9
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Save the 40 for gas and just use a vise. If my wife can do it you can to, very easy install.
tkrupinski is offline   Reply With Quote
Old 06-28-2012, 08:11 PM   #10
The 2010 Sin
CorkTulsa.com
The 2010 Sin's Avatar
Drives: 2010 2SS BLK, 2013 2SS CRT
I know i should already know this answer but we all learn something new everyday...
What exactly do we gain with a trunion upgrade? What does it accomplish. I'm 10,000 miles on a motor with a .236/.244 .602/.612 on a 112LSA without the upgrade.
The 2010 Sin is offline   Reply With Quote
Old 06-28-2012, 08:15 PM   #11
Synner
Drives: 2011 2SS/RS M6
Removes the possibility of needle bearings being vomited into your engine if the rocker arm fails. The retrofit has enclosed bearings.
Old 06-28-2012, 08:54 PM   #12
Aries240SS
This. And as someone who has just rebuilt a friend's LS1 that had a rocker arm fail, I'm not interested in going through all that again. He was smart this time and went with Yella Terra rockers, but they don't seem to gain enough to offset the cost on an LS3.
2011 Camaro 1SS/RS
Old 06-28-2012, 09:03 PM   #13
mikeSS
mikeSS's Avatar
Drives: 2013 E92 M3
there use to be problems with older GM v8s. but they seem to fix the problem. i see A LOT of cammed camaro at meets and at my local shop who do not have the upgrade. in fact my shop advises against the upgrade on the ls3. note they do the most Lsx work in the state of MI.
its one of those things, where people said do it and others say its not needed.
Old 06-28-2012, 11:02 PM   #14
Bo White
Drives: 2009 Pontiac G8 GXP
I would think the upgrade would be a good idea on the LS3/7/9 more so than any other LS engine because of the offset intake rocker and the uneven corner to corner load it experiences.
2009 PBM G8 GXP M6
#196 of 1829
JBA LT headers
Spectre intake
Old 06-30-2012, 11:42 AM   #15
The 2010 Sin
CorkTulsa.com
Thanks for the teachings... I have 10k+ miles of 7k RPM shifts and hard driving on mine and no issues yet.. Let the gambling begin!! :-P
Old 07-01-2012, 08:38 PM   #16
MikeOD
Drives: 2010 M6 2SS
The newer engines seem to have a better track record with rocker arms and rold bolts than the older ones do. I was always terrified of high RPM with my old LS1 and LQ4 in the past, mostly because of rod bolts. With the LS3, I still did the trunnion bearings, but I'm not really concerned with the rod bolts.
499 RWHP 463 RWTQ.
Old 07-02-2012, 09:33 AM   #17
Doubleblank
Doubleblank's Avatar
Drives: 2010 Camaro 2SS
One of our H-Town CC guys recently puked his bearings into his motor. He spent a lot of time flushing, using magnets, etc to try to find them all.
ERL 500 cu in Short Block, 2in ARH Headers, TSP LS7 Heads, LSXR/NW 102, Forgeline, Invo's 295/275, MGW Shifter, StopTech BBK, KWv3's, Pfadt ASB's, etc, PowerFab Dynotune
Doubleblank is offline   Reply With Quote
Old 07-02-2012, 09:38 AM   #18
blazzin1
blazzin1's Avatar
Drives: 2010 2SS/RS
I think it's good insurance....especially for the price and easy installation....why not??? I have a set sitting on my work bench awaiting install. Just can't decide if I want to mess with it now, or just wait until cam upgrade time....
Old 07-02-2012, 11:10 AM   #19
Bo White
Im going to go ahead and upgrade my topend soon so that next year when I do my camswap Ill have half the job done already. Thats how I did my Z28 I had.
2009 PBM G8 GXP M6
#196 of 1829
JBA LT headers
Spectre intake
Old 10-31-2012, 09:01 PM   #20
Mikes2nd
Drives: 1970 Pontiac GTO
has ANYONE ever heard of a 2010+ camaro or any LS3 do this?
I would have thought GM would have this issue figured out by now.
Mikes2nd is offline   Reply With Quote
Old 11-01-2012, 08:02 PM   #21
Cruz-lo
Drives: 2010 2ss RS
Yes LS3.
30K on motor. about 27K on the cam. While the needles were still there the outer race failed on one side. Thanks to the noise "tick tick" I caught it in time. But this caused the rocker to ride ****eyed.
Took out the $14.00 rocker OK no big deal.
But it also wiped out the valve stem top. Changing the valve now is a big deal.
Cruz-lo is offline   Reply With Quote
Old 11-01-2012, 08:30 PM   #22
Ebbsnflows
Drives: 2010 Camaro SS/RS
It's an extremely rare point of failure on a stock-valve trained car. From that perspective GM does have it figured out.
The problems occur on cam'd cars with much higher spring pressures, faster ramp rates and more importantly, higher rev-ranges. The stock components simply aren't designed for that level of stress.
2010 Camaro SS: TSP 231/236 cam, Kooks LTs, Magnaflow 16580 catback, Airaid CAI, U/D pulley, P-TB, Pfadt-Stage 3, MTI shifter, MPD1 spoiler, S-S Splitter, 22" Nurburgrings
2001 Camaro Z28: ARE Forged S-block/PRC 2.5's/VRX-3 cam/Fast 90-90/QTP L-tubes/True Duals/FTRA/85mm Lid/12-bolt 4.30 gears/Full BMR adj. Suspension/6 point rollbar/Built T-56/McCleoud clutch/255lph pump/42 lb inj/N20 Express 125 shot
2006 Yamaha R1: Akro Full-length exhaust, Sprocket/PCIII, Speedo-Healer, Braided lines/EBC pads, Adj Rear-Sets, etc
Ebbsnflows is offline   Reply With Quote
Old 11-01-2012, 08:34 PM   #23
Mikes2nd
yeah i guess it kind of sounds like a "cheap" precautionary almost bolt on mod...
I was wondering if I should just do mine while I have it apart. Or get new rockers...
Im going for a vvt 2 cam
Old 11-02-2012, 01:23 AM   #24
376LS3
376LS3's Avatar
Drives: 2010 2SS
If its in your budget, Id go roller rockers. I regret not getting them when I did my cam install. I just always feel like Im on borrowed time. Theyre not made to handle anymore than .550 lift, and Im way over that. Its just hard to decide which rockers to go with since all 3 companies Ive looked into have all had problems. And I dont have $1600 for Jesels, so thats not an option.
2010 2SS LS3 - Cammed
376LS3 is offline   Reply With Quote
Old 11-02-2012, 11:46 AM   #25
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
For the price, very cheap insurance. I've got 4500 miles on mine with several hard road track and drag strip days on them with no issues. Running a fairly stout cam (227/239, .624 lift) and Comp double springs as well. I would definitely do it again. Only way I wound spring for the aftermarket rockers is if I was doing a complete and more aggressive build.
The Toy: 2011 Camaro 2SS/RS, LS3, Power by Vengeance Racing...
"I don't make things difficult. That's the way they get, all by themselves." Riggs
The Workhorse: 2006 Silverado CCSB, EFI Live, MBRP/Diamond Eye 4" turbo back, Edge Insight CTS
tadams72 is offline   Reply With Quote
