sjm autoprod
Old 06-28-2012, 07:52 PM   #15
tkrupinski
Hugger Orange
tkrupinski's Avatar
Drives: 2010 Hugger Orange 2SS/ RS YSI/4l80
Take the boost line off the blower and run a new line from blower to drivers side of car, then just use a T fitting and conect the boost line and the line you removed from the blower together. Thats how mine is set up.
tkrupinski is offline   Reply With Quote
Old 06-28-2012, 07:52 PM   #16
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
Originally Posted by 67motorcat View Post
Do you have a boost-a-pump PQ ?
Looks like a vacum reference switch.
Motor cat is Right. Its the Pressure switch for you Vacuum reference for your BAP.
JLE58 is offline   Reply With Quote
Old 06-28-2012, 07:53 PM   #17
MA2010SS
Drives: 2010 Camaro SS
It's a vacuum switch with a diaphram, it looks like it gets the vaccum/boost from the port that the rubber hose is connected to which is connected to the switch and the wiring goes to the boost guage just taking a wild guess at the picture shown
2010 Camaro SS Whipple SC, CAI Inc Intake, TSP 1 7/8" LT headers no cats, 3" magnaflow exhaust, HPT, RX Catch Can, LSR Toe Rods, LSR Trailing Arms, ALKY Control Meth, McLeod RXT Twin Disc, ZL1 fuel pump, 3.73 ZL1 Differential Kit, BTR PDS Stage 2 Cam, Tuned by SLOWHAWK Performance Bridgewater MA
MA2010SS is offline   Reply With Quote
Old 06-28-2012, 07:57 PM   #18
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Boost line? You talking about a new tube and connect both the BAP device AND gauge with?
Are we possitive? Makes sense to me but I didn't know the BAP would need a vacuum line?
Never had a gauge on it.
Old 06-28-2012, 07:58 PM   #19
JLE58
Yeah on a LS1 you would hook it up to the brake booster line at the back of the intake manifold just like that.
Old 06-28-2012, 08:00 PM   #20
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Drives: 2011 Black on Black 2SS M6
Yep.....just install a "Tee" before the switch as stated above and your golden
Had a 2010 IBM 2SS M6
Enjoy life.Think of all the women on the Titanic who passed up dessert.
67motorcat is offline   Reply With Quote
Old 06-28-2012, 08:03 PM   #21
tkrupinski
Hugger Orange
tkrupinski's Avatar
Yes. Connect your boost a pump and new gauge boost line together. If you run a new line from the blower to drivers side and make the T connections there you will have easy access for tuner boost hook up and also easy removal of gauge line or boost a pump line. The line on the blower should have a zip tie on it to keep it from blowing off. Hope this helps.
Old 06-28-2012, 08:08 PM   #22
PQ
Booooosted.
PQ's Avatar
Yup. Helps a ton. Thank you.
Where should I get power for my gauge? I don't want to get it from the BAP line.
Old 06-28-2012, 08:09 PM   #23
tkrupinski
Hugger Orange
tkrupinski's Avatar
Fuse box on drivers side dash.
Old 06-28-2012, 08:13 PM   #24
67motorcat
Blown Cool Breeze
67motorcat's Avatar
Yep....F17 or F18 with a add a fuse link.
Old 06-28-2012, 08:16 PM   #25
JLE58
I love it when A plan comes together!
Old 06-28-2012, 08:16 PM   #26
PQ
Booooosted.
PQ's Avatar
Awesome.
I was going to tap the tapped blower coolant pump fuse.
The inside way will work better. Sweet.
You guys rock.
Old 06-28-2012, 08:17 PM   #27
PQ
Booooosted.
PQ's Avatar
Old 06-29-2012, 08:18 AM   #28
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
Is f17, or f18 powered during engine crank? I just bought an Autometer boost gauge that needs power when the engine is cranking so it can reference current atmospheric pressure.
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
