Old 06-28-2012, 10:56 PM   #1
Topnation
Topnation's Avatar
Drives: White 2012 Camaro 2Lt RS
New Alternator for sub System??
Do I really need to get a new alternator or a alternator built on top of the one I have if i have a somewhat big system in my camaro??
I have 1 JL 12w7 with a Rockford Fosgate T1500.1db
An Audio store told me I have to have one if I have this system?
Topnation is offline   Reply With Quote
Old 06-28-2012, 11:31 PM   #2
SS King
SS King's Avatar
Drives: a Panty Dropper
I"m runnin a t2 12"with a t1001 BD on stock with no cap and I'm fine I'll be putting my cap in soon thou
SS King is offline   Reply With Quote
Old 06-28-2012, 11:33 PM   #3
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
I have 1000 watts rms and don't have one. All stock and no light dimming.
=Stephens= is offline   Reply With Quote
Old 06-29-2012, 10:14 AM   #4
kalimus
kalimus's Avatar
Drives: '14 Z51 3LT Stingray and '13 Cruze
No.
kalimus is offline   Reply With Quote
Old 06-29-2012, 10:59 AM   #5
SC2150
You can always swap to the overdrive alt pulley to increase the stock alt's output at idle/low RPM's.
Old 07-02-2012, 08:50 PM   #6
Topnation
Topnation's Avatar
Thanks guys. Im just thinking the audio store wants to sell me stuff I really don't need.
Old 07-02-2012, 09:30 PM   #7
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
There have been quite a few alternator threads in the past few days. From what I have read on Camaro5, the stock alternator is rated at 150Amps.
A 1000W system would use 83.3Amps at 1000W. (1000W/12V=83.3Amps). Which means your amp alone has the capability of using more than half of the alternator's output. If you consider the alternator's output was designed without a 1000W amp in mind, that is pretty significant.
On the flip side, it's not likely that you're running your system at 1000W continuously. To do so, you would have to play some sort of sine wave at full volume, and you would probably be deaf. For the few moments that you actually hit 1000W, the battery is probably sufficient to keep the voltage from dipping.
The bottom line is that an alternator can only help, but it's probably not worth the cost of $500+, for most people. I personally have never seen any voltage fluctuations in my car, which has a 900W amp.
jeepguy_1980 is offline   Reply With Quote
Old 07-02-2012, 09:40 PM   #8
gorgeous-ss
Drives: 2011 ss/rs
I have a sd 5k at 1 ohm putting out about 6500 watts at full tilt and 14.4 volts
I needed a higher output alt so i went with dc power 270 amp alt but then i also got 2 xs power d3100 batteries. So yes now i have over kill but when u are competing you want your voltage to stay as high as you can.
Sent from my DROID RAZR using Tapatalk 2
gorgeous-ss is offline   Reply With Quote
Old 07-03-2012, 01:57 AM   #9
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
I have 3 class D amps with a total RMS output of around 2900w. It is too loud to listen to over half volume but still clean and has never caused the voltage meter to move. You would be fine with your setup.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 07-03-2012, 04:47 PM   #10
jeepguy_1980
Just a follow up: I did some non-scientific testing for a few minutes in my car. Instead of referencing the 4-pack gauge cluster, I brought my car's voltage up on the DIC.
I had been listening to my radio and driving for a while. When I first pulled up my voltage on the DIC, it indicated a steady 13.2V. I then turned my radio off and the voltage crept up to 13.7V, over a period of about 2 minutes. I then pulled into my garage, where the headlights came on and the voltage hit 13.5V for a second then steadied out at 13.6V.
I do not have an overly aggressive system (900W), and it does have a noticeable impact on the Camaro's charging system. I'm now curious to see where the voltage would steady out if I had given the car longer to fully charge the battery. I think it would steady out at 14.0V.
Old 07-03-2012, 10:59 PM   #11
CWI
CWI's Avatar
I really need to finish installing my ammeter. While installing my amps and speakers, I installed the current pickup near the battery on the 1/0 cable for the amps. I ran the wires to the dash and that's as far as I got. Maybe this weekend. I'd like to see how much current my system is drawing.
Old 04-10-2015, 04:48 PM   #12
Powellbr
Drives: '99 Mitsubishi Mirage de coupe
So I'm going to be running a system that consists of 4 Rockford Fosgate 13" 2000 watt subs and a pair of MB Quart 12" 500 watt subs also with 4 Rockford Fosgate Power series component speakers with a Rockford Fosgate sub feeding the Rockfords and an MB Quart feeding the MB Quart along feeding the speakers in the doors and the deck. Would I be fine with the stock alternator or will I need to go DC power? If so, would I also want to feed the Rockfords with a separate battery if I needed to go DC because they'd be used only at an event or if someone wanted to see the full system in action.
Powellbr is offline   Reply With Quote
Old 04-11-2015, 03:24 PM   #13
timshifty
timshifty's Avatar
Drives: 2012 2SS/RS
I had 2 of those with no issues
Flowmaster American Thunder Exhaust
timshifty is offline   Reply With Quote
Old 03-24-2017, 06:00 PM   #14
caliraider
caliraider's Avatar
Drives: 2013 2ss Convertable
not for a w7 you will be fine. you can do a big 3 wiring upgrade instead if you really need to
caliraider is offline   Reply With Quote
