Caryle Racing
Old 12-20-2007, 12:32 PM   #1
3whiterag
GM Powertrain Retired
3whiterag's Avatar
Drives: 67SS350, 87 IROC L98, 96SS ver
Corvette ZR1 LS9 2009
Hope this link works!!
http://media.gm.com/servlet/GatewayS...39&docid=42156
3whiterag is offline   Reply With Quote
Old 12-20-2007, 10:43 PM   #2
Kenz Camaro
Kenz Camaro's Avatar
Drives: 1994 Impala SS
The link works just fine 3whiterag!
Thank you VERY much, that's the kind of stuff I like to get from this site!
Ken
Kenz Camaro is offline   Reply With Quote
Old 12-20-2007, 11:12 PM   #3
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Thanks a TON, whiterag! Tell me, are you guys building this thing at your plant? or is it somewhere else...
Mr. Wyndham is online now   Reply With Quote
Old 12-21-2007, 01:22 AM   #4
headpunter
Not That sad..considering
headpunter's Avatar
Drives: Man
Location: the part of washington the capital forgot about.
Send a message via AIM to headpunter
i have been reading about the new 6th gen eaton supercharger simply amazing more power at less boost, as i said simply amazing
headpunter is offline   Reply With Quote
Old 12-21-2007, 01:26 AM   #5
TAG UR IT
www.Camaro5store.com
TAG UR IT's Avatar
Drives: 2014 ZL1 #705
Great job, GM. WIth engines like these hitting the streets, you know they have more engines in the back just waiting for the Camaro...
This is going to be GREAT!!!!
Old 12-21-2007, 01:31 AM   #6
joes3rdcamaro82/91/2010
Z28 Hold Out!
joes3rdcamaro82/91/2010's Avatar
Drives: 2000 Monte Carlo SS
Wow great share, thanks! That is going to be a monster. Thank you chevy, come on 500+horses for the camaro.
joes3rdcamaro82/91/2010 is offline   Reply With Quote
Old 12-21-2007, 02:12 AM   #7
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
More than just its tremendous peak horsepower and torque numbers, the supercharged LS9 makes big power at lower rpm and carries it in a wide arc to 6,600 rpm. GM Powertrain testing shows the engine makes approximately 300 horsepower (224 kW) at 3,000 rpm and nearly 320 lb.-ft. of torque (434 Nm) at only 1,000 rpm. Torque tops 585 lb.-ft. (793 Nm) at about the 4,000-rpm mark, while horsepower peaks at 6,500 rpm. The engine produces 90 percent of peak torque from 2,600 rpm to 6,000 rpm.
I want to see a dyno chart for this thing. At idle it makes more power and torque than most cars
To the Viper, and every other performance car for under 300k:
Oh, the LS9 is being built at the same place where the LS7 is built.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 12-21-2007, 02:14 AM   #8
Mindz
E.B.A.H.
Mindz's Avatar
Drives: you wild...
Old 12-21-2007, 05:27 AM   #9
3whiterag
3whiterag's Avatar
No, we won't be building it although we did run all the protypes in the machining process. I don't know if we will be doing the machining for it but I do know it will be assembled in Wixom where the LS7 is now built. Heck of an engine!!
Old 12-21-2007, 08:58 AM   #10
Jeff
~ANTI-FORD~
Jeff's Avatar
Drives: Cadillac CTS
Send a message via MSN to Jeff
I love it, with this Vette and the Camaro hitting the streets soon.. Chevy will be leaving Ford and Mopar in awe.
My Z28
sorry guys.. sold Camaro and got a Cadillac CTS, waiting for a few years to get a 2010 SS used ;]
Jeff is offline   Reply With Quote
Old 12-21-2007, 09:18 AM   #11
Mr. Wyndham
Thanks. Hand built...I should have thought of that first before I asked...
Old 12-21-2007, 12:06 PM   #12
SilverTurtle
Reality Check Specialist
SilverTurtle's Avatar
Drives: '02 Z28, 2012 45th SS
Send a message via AIM to SilverTurtle Send a message via Yahoo to SilverTurtle
hmmmm... LS9 + wife's 2010 hardtop in black
got tequila?
SilverTurtle is offline   Reply With Quote
Old 12-22-2007, 01:34 AM   #13
SoFlaZ
SoFlaZ's Avatar
Drives: Nothing special :-(
Hmmm, I wonder if by 3whiterag posting this he is trying to hint something as well as give us info on this amazing engine?? It did say "The LS9 represents the first of several new, supercharged small-block engines that will be introduced in GM vehicles in the near future, each using superchargers of similar design."
A possible supercharged engine to follow for the Camaro??
Edit: Changed whiterag to 3whiterag*
SoFlaZ is offline   Reply With Quote
Old 12-22-2007, 07:07 AM   #14
3whiterag
3whiterag's Avatar
3whiterag, 3whiterag, 3whiterag as in triple white convertible!
2009 Camaro / C5 Corvette performance comparison markhoran 5th Gen Camaro SS LS LT General Discussions 12 07-02-2008 10:46 PM
VETTE ZR1 REVEALED!!! Scotsman General Automotive + Other Cars Discussion 67 03-04-2008 12:02 AM
LS9 GM Pics z28camaro2471 General Automotive + Other Cars Discussion 26 11-29-2007 03:03 PM
Corvette ZR1 pics.! Moose General Automotive + Other Cars Discussion 2 10-24-2007 07:53 AM
