SDTW Custom Wheels & Tires
Old 06-29-2012, 02:27 PM   #1
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Vibration under acceleration
I've got a vibration under full acceleration (most noticeable in 2nd and 3rd gear).
Where should I start to try to figure this out?
Thanks
Old 06-29-2012, 02:42 PM   #2
willhe64
willhe64's Avatar
Drives: 2012 45th Vert, 2011 4x4, 9sec Vega
Get under and wiggle the driveshaft and halfshafts, wee if there is any play.
I feel it only fair to warn you, I have a black belt in CAPS LOCK.
willhe64 is offline   Reply With Quote
Old 06-29-2012, 02:52 PM   #3
SGOS252382
SGOS252382's Avatar
If that's the case then what? They need to be tightened up or would I need to think about replacing them?
Old 06-29-2012, 02:57 PM   #4
phantomfuzzie
phantomfuzzie's Avatar
Drives: 2012 Black Camaro
is it at a certain RPM range? but all gears? can you make the vibration happen always? Is it still under warranty?
phantomfuzzie is offline   Reply With Quote
Old 06-29-2012, 03:04 PM   #5
SGOS252382
SGOS252382's Avatar
Vibration is under hard acceleration. It is mostly felt in 2nd gear when I go wide open. I also feel it in 3rd gear when I go wide open, but not as noticeable as in 2nd gear.
It's come on stronger as the rpms increase under wide open acceleration.
I've had the problem for about 2 months. Today, it seemed a little worse.
Definitely no warranty for me. I've got too many mods and a converter.
Also - I first notice the problem after having my car in the shop getting some paint work. I don't know if they messed something up jacking the car up, or they hot rodded the car.
Or it could just be a coincidence but its been on my mind.
Old 07-03-2012, 12:53 PM   #6
SGOS252382
SGOS252382's Avatar
Bump for more suggestions.
I just recently got 1" lowering springs and I had the performance shop look under the car at the axles, driveshaft, and wheels. The car also got an alignment.
They said they didn't see anything out of place.
So now I'm thinking torque converter, transmission, tuning, or engine related.
Old 07-10-2012, 02:34 PM   #7
JQUICK
Drives: 2013 2SS
Sounds like a u-joint going out.
JQUICK is offline   Reply With Quote
Old 07-10-2012, 02:36 PM   #8
SGOS252382
SGOS252382's Avatar
Thanks, I'll have to have someone check that out.
Old 07-11-2012, 09:58 AM   #9
SGOS252382
SGOS252382's Avatar
Update on my situation.
It is now believed that my issue is in the stall converter. FTI told me to send them my converter and they will swap it out for one of their new triple disks.
Hoping that will correct the vibration.
Old 07-12-2012, 01:46 PM   #10
SGOS252382
SGOS252382's Avatar
Car is now at the tranny shop and my single disk FTI converter is on its way to FTI.
Tranny shop should get the converter back late tomorrow, but I probably won't get my car back until Monday.
Anyone with a single disk FTI converter might want to follow this thread.
Old 08-23-2016, 11:19 PM   #11
Agent orange
socal ht5
Agent orange's Avatar
Drives: 2010 Camaro ss
I think i have the same problem as yours.
Agent orange is offline   Reply With Quote
