Old 06-30-2012, 11:36 PM   #1
Bcran3
Bcran3's Avatar
Drives: White 2012 Chevy Camaro 2LS
Stock V8 exhaust to a V6?
I have a 2012 camaro 2LS 3.6L V6 and i want to know if i am able to take a stock camaro SS V8 exhaust and install it onto mine. It would be Cat-back.
Does anyone know if it would fit nicely? Do you know anyone that has done this before? Need some suggestions.
Trying to save money and dont want to spend a lot on the exhaust. Ill be installing a K&N Typhoon Intake very shortly as well....
[SIGPIC]
Bcran3 is offline   Reply With Quote
Old 06-30-2012, 11:39 PM   #2
_Nick_
Drives: '87 T/A, '87 IROC, '70 Grand Prix
It'd be a complete waste. Go aftermarket.
_Nick_ is offline   Reply With Quote
Old 06-30-2012, 11:52 PM   #3
gahammerle
gahammerle's Avatar
Drives: 2010 Camaro LS M6 Inferno Orange
The mounting points are the same and it will fit, but there isn't much to be gained. The pipes are just slightly larger, but still have the big, heavy stock mufflers. I have also been told that the V8 exhaust on V6 cars doesn't really sound all that good.
Gordy
Injen CAI / Solo Mach-X LLT / Solo High-flow res-cats / Barton short shifter / RX Catch Can / RPI Gills / 35% tint / LED Footwell Lighting Front & Rear / Pedders Street 1 / Pedders steering rack bushing / SS struts / Pfadt drop springs / VMax Ported Throttle Body / Spohn Toe Rods / Spohn Trailing Arms / Trifecta Tune / MACE 25mm Intake Spacers
Find me on Facebook:
http://www.facebook.com/gahammerle
gahammerle is offline   Reply With Quote
Old 07-01-2012, 03:16 AM   #4
ihaveacamaro
I like teeth.
ihaveacamaro's Avatar
Drives: #198
I totally disagree. I have it on my car and it sounds WAY BETTER than stock.
Please check out my youtube detailing channel: http://www.youtube.com/user/roshan517
"When you want to succeed as bad as you want to breathe, then you will be successful."
Old 07-01-2012, 03:23 AM   #5
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
Take the v8 exhaust and put a SS on it . Sorry I had to.
AdamZ is offline   Reply With Quote
Old 07-01-2012, 03:28 AM   #6
Bcran3
Bcran3's Avatar
Thanks everyone for the input. Reason im not looking into aftermarket exhaust is i dont have the money at the moment and i can get the SS exhaust for very very cheap. And also, thanks for the video. Sounds good!
[SIGPIC]
Old 07-01-2012, 03:32 AM   #7
ihaveacamaro
I like teeth.
Drives: #198
Same reason I went for the SS exhaust. You'll like it I'm sure. Huge upgrade over stock
Old 07-01-2012, 05:05 AM   #8
SSGUNNER
Chu no guat a hasa is?
SSGUNNER's Avatar
Drives: 14 Jeep G Cherokee Overland HEMI
Wouldn't it be cheaper to go aftermarket???
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
SSGUNNER is offline   Reply With Quote
Old 07-01-2012, 05:56 AM   #9
SD2011SS
SD2011SS's Avatar
Drives: 2011 Chevrolet Camaro 2SS-RS
no because he can buy the full catback system for the stock SS for the price he would spend on an axel back for an after market brand.. I actually have a full catback stock exhaust with mufflers sitting in my garage lol..
SD2011SS is offline   Reply With Quote
Old 07-01-2012, 05:59 AM   #10
Camaro_hx
Drives: 2010 1LT/RS CGM
Send a message via MSN to Camaro_hx
So you can fit a V8 SS stock exhaust onto the V6??
Would'nt the manifold diameter be larger than the V6's?
That install will surely damage header gaskets or something when run for a while..No?
Camaro_hx is offline   Reply With Quote
Old 07-01-2012, 06:20 AM   #11
SD2011SS
SD2011SS's Avatar
no it should all be the same, from stock exhaust v6 to v8. I believe its the same 2.5 inch piping from the cats back. unless the v6 is on 2 inch pipes which wouldnt make much sense at all in my opinion.. if it is for whatever reason bigger then a little welding and a clamp should do the trick
Old 07-01-2012, 06:36 AM   #12
Sterling
Sterling's Avatar
Drives: 2010 Camaro 1LT/RS M6
Make sure the SS exhaust is from a stick. The Auto's exhaust has extra stuff in it because of the noise from the cyllinder deactivation and it won't sound as good.
Sterling is offline   Reply With Quote
Old 07-01-2012, 06:39 AM   #13
SD2011SS
SD2011SS's Avatar
^^ useful info I didnt know that..! im diggin the grey and red sterling.. a little bit of a different color combo!
Old 07-01-2012, 08:34 AM   #14
Camaro_hx
thanks for the info.
now, need to make sure of the manifold diameter sizes.
