Emblempros
Old 07-02-2012, 08:20 AM   #1
vafinest25
vafinest25's Avatar
Drives: 2010 2SS/RS "Orange Crush"
TO CUT OR NOT!!!
I have a set of H&R 35mm lowering springs, which translates to a 1.4" drop all the way around. the issue is that the guy i bought them from had the same set up as i have with 22" rims 9.5 frontand 10.5 rears, but he says that his install guy didnt cut the bump stops on his struts. I went on the forum and looked for DIY of H&R springs but no joy!! So i pulled everyting from Pdat, Ebach, and BMR, installs, and all of them say cut the bump stop 1" off. So i need to know if anyone of you guys did the same install height, or install for that matter without cutting the bump stop. And ultimatly what is the right answer from the experts, to cut or not?
" Drive It Like You Stole It "
[SIGPIC][/SIGPIC
vafinest25 is offline   Reply With Quote
Old 07-02-2012, 08:37 AM   #2
Secret Squirrel
Secret Squirrel's Avatar
Drives: 1965 Chevelle Malibu
I installed Eibachs on my car, and didn't touch the bump stops. Not necessary, and I think if you go to the Eibach website, or look at the instructions, it will tell you that you do not need to cut them.
Secret Squirrel is offline   Reply With Quote
Old 07-02-2012, 08:45 AM   #3
robsls3
Drives: 2010 camaro 1SS
My BMR spring instructions stated NOT to cut the bumpstops. I even checked their site and it said not to cut them. Even the Eibachs I had said not to cut.
robsls3 is offline   Reply With Quote
Old 07-02-2012, 09:53 AM   #4
vafinest25
vafinest25's Avatar
Ok you and the other guy above me are right. This is where i go that info from. Scroll to the bottom of the site and you see the cutting part.
http://www.planetlsx.com/tech/How_To...010_Camaro/131
[SIGPIC][/SIGPIC
Old 07-02-2012, 10:01 AM   #5
robsls3
Yeah some springs require you cut but not the BMR or eibachs.
Old 07-02-2012, 10:59 AM   #6
caverman
caverman's Avatar
Drives: '69 SS Convertible
The only ones I've seen that require the cut are Pfadts. I had Hotchkis for a while and no cutting with them either....then again those were 1".
Build Journal
Old 07-02-2012, 11:01 AM   #7
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
We would recommend following the instructions as published by your spring manufacturer.
With our springs we do suggest that you trim your bump stops, it's extremely simple and has no adverse effects to handling or ride comfort. When you lower your car you're placing your shocks in a different portion of their stroke, and by removing some material from the bump stop you reduce the likelihood of riding on the bump stops over big hits. This ultimately makes the shock more functional for the ride height your trying to achieve.
Again, if you have H&R springs follow the instructions posted by H&R.
Old 07-16-2012, 11:18 PM   #8
WONSS
WONSS's Avatar
Drives: 2012 1SS/RS M6 SUMMITT WHITE
I installed H&R springs and cut the bump stops..the car rides awesome and does not bottom out....
WONSS is offline   Reply With Quote
Old 08-19-2012, 08:36 PM   #9
nUcLeArEnVoY
Oldbie that nobody knows
nUcLeArEnVoY's Avatar
Drives: 2011 1SS/RS M6
That's an insane drop. You running the H&R 1.4's or 1.8's?? I'm getting the BMR 1.4's and if this is how my car is gonna look, then I am one happy camper lol
nUcLeArEnVoY is offline   Reply With Quote
Old 08-19-2012, 09:28 PM   #10
FresnoStateDogs
FresnoStateDogs's Avatar
Drives: 2012 2SS/RS LS3
+1
I have Eibach's, instrustions say DO NOT cut.
Spiral Ported TB, K&N Typhoon, JBA Performance Cat-back, RX catch can and Oil Breather.
FresnoStateDogs is offline   Reply With Quote
Old 08-20-2012, 09:16 PM   #11
WONSS
WONSS's Avatar
they are the 1.7 and 1.8's
Old 08-21-2012, 10:32 PM   #12
IPT
Drives: '02 Trailblazer, '12 Camaro 2SS/RS
can you post some more pics? Want to see that drop? Any alignment issues?
IPT is offline   Reply With Quote
Old 08-21-2012, 10:37 PM   #13
Atti2de
Móderator
Atti2de's Avatar
Drives: 2SS/RS
Have the H&R 1.4" and did not cut. No issues after 3 years, YET!
I'm not the one with the Atti2de problem it's everyone else that has a problem with my Atti2de!
Atti2de is offline   Reply With Quote
Old 08-21-2012, 10:47 PM   #14
diamondmike
diamondmike's Avatar
Drives: 2SS/RS
Cut one inch off
7.83 @ 172 and 1.15 60ft 5th gen
4.93@143
diamondmike is offline   Reply With Quote
