Caryle Racing
Old 07-02-2012, 02:02 PM   #1
camaro2rs
camaro2rs's Avatar
Drives: camaro
Problem with my car after fuse went :(
have a big problem with my car one of my fuses blew it was BCM2 on the dash panel....i replaced the fuse with a new one....i put the key in and now cant get the key out...car wont go in gear.. and my trunk wont open and hi beeams will not go on.......also my windshield washere are doing a random dance....i checked all the other fuses and there fine. i am really scared too bring it to my dealer because i have some lighting mods....i do have a good relationship with my dealer and i spend lots of $$$$$ over there.....my 3 year 36 expired the 27th of june.....any suggestions on what i should do thanks
camaro2rs is offline   Reply With Quote
Old 07-02-2012, 02:12 PM   #2
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
not sure about electrical part but if the key wont come out and car wont go into gear,try wiggling<back and forth with lots of force> the sterring wheel a bit while you are turning the key backwards,sometimes when you stop pressure is on the key lock and this will stop key from coming out,i cant imagine an electrical issue being the cause of the key issue,but you never know
bcguy is offline   Reply With Quote
Old 07-02-2012, 02:15 PM   #3
camaro2rs
camaro2rs's Avatar
Drives: camaro
tried that and no luck...........anyone know how to reset the bcm?
