sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 07-03-2012, 03:59 PM   #1
Sajonf
Drives: 2014 Corvette Stingray Z51
SS wheels test fit?
Has anyone test fit a set of SS wheels to see if the clear the ZL1 brakes?
I am looking for a set of wheels to mount winter tires on and I know there is a Pirelli set that works with the stock SS wheels.
Thanks!
Sajonf is offline   Reply With Quote
Old 07-03-2012, 04:33 PM   #2
ZL1 TIBS
ZL1 TIBS's Avatar
Drives: 1968 Camaro, 2012 ZL1
I already bought a set but didn't test fit. SInce they are the same diameter, I assumed they would fit fine.
Alan Tibbetts
Aston, PA
1968 Chevrolet Camaro LS-1/T56 transplant
2012 CRT 6 SP ZL-1
ZL1 TIBS is offline   Reply With Quote
Old 07-03-2012, 04:41 PM   #3
Sajonf
Thanks.. I assume they will too - just looking for confirmation before I pull the trigger.
Old 07-03-2012, 06:11 PM   #4
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
Edit - if I knew the precise answer, I'd give it to you straight out. But all I can do at this point to help is mention something else to check for.
What you need to confirm is not just that the "barrel" of the wheel will fit over the outside diameter of the caliper but that the back sides of the spokes will everywhere clear the outward thickness of the caliper as well. Unfortunately, this isn't easy to do "by eye".
This exact issue is a huge deal over on the Mustang side of the street, with many 18" aftermarket Mustang wheels not fitting cars with the 14" GT500 brakes even though the GT500's at the time wore 18" wheels. I know, I know, there's that "other car" again. But that doesn't eliminate the need to check this here. Unfortunately, dimensional "gotcha's" like this do occasionally happen.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-03-2012, 06:27 PM   #5
Sajonf
Absolutely agree norm that's why i asked. There are many factors to consider such as diameter, offset, back spacing, etc. Hopefully someone will do a test fit soon..
Old 07-03-2012, 06:50 PM   #6
ZoomZoom
R6P Owner
ZoomZoom's Avatar
Drives: 2000 Camaro SS
spare
They will fit. I took the front off my 2010 ss and it will clear. I took it to Georgia with me, to the fbod gathering. Not going to be at the mercy of a not noing tow truck driver. I'm looking for a polished wheel, if anyone knows where one is for sale.
ZoomZoom is offline   Reply With Quote
Old 07-04-2012, 12:24 AM   #7
fbodfather
fbodfather's Avatar
They will fit - in fact we had a few 2012 CTF ZL1s running around the Motor City last winter with SS wheels and Scorpion Snow tires -
I recommend that you order all-seasons or ice/snow tires early - they're not easy to find in the sizes that the ZL1 requires.
Old 10-11-2012, 05:43 PM   #8
SSeemego
Drives: 2016 1SS Hyper Blue 6M MRC NPP
fbodfather: confirmation please
Scott,
I am about to buy a set of SS wheels for my ZL1 and run all season tires for the colder months here in MD. Not clear about your statement about the CTF using SS wheels and Scorpion winter tires, in conjunction with your statement about "sizes that the ZL1 requires".
Is it okay to use the SS wheels with the 245/45/20 F and 275/40/20 R tire size that is standard on the SS? Or do I need to mount different size tires on the SS wheels for the ZL1?
Thanks,
Gary
SSeemego is offline   Reply With Quote
Old 10-11-2012, 10:17 PM   #9
RJ111
RJ111's Avatar
Drives: 2015 ZL1
Originally Posted by SSeemego View Post
Scott,
Thanks,
Gary
I would like to know this as well.I was thinking of running a 275-40 0n the front and a 315 35 on the rear.I dont see many options out there in the 285 35 for the front.
2013 Camaro ZL1,Victory Red # 441....SOLD
2013 Camaro ZL1, Summit White # 3071...SOLD
2015 Camaro ZL1, Summit White # 1325
Rotofab Cai,PCM cc,Kooks Headers,Cats delete,MF X pipe, ZLWin cam,upper/lower, Lingenfelter hx,715 rwhp,646 rwtq, BMR 1.25 Springs, Varro VD01 Wheels,
RJ111 is offline   Reply With Quote
Old 10-12-2012, 12:13 AM   #10
HDRDTD
Scott,
Thanks,
Gary
I think what fBodfather was saying was that yes the SS wheels will fit and that they were using them with Scorpions on them on the CTF, but if you want to run them on the ZL1 wheels, you best get them while you can since they are hard to find in the sizes needed for the ZL1 wheels.
Old 10-12-2012, 02:17 PM   #11
SSeemego
HDRDTD,
Thanks.
I really was wondering if the SS tires 245/45/20 and 275/40/20 were the ones they used.
I know Scott is busy and probably won't see this right away, if at all. But thought I would ask anyway.
Gary
Old 10-12-2012, 10:52 PM   #12
RobZL1580
Drives: 2013 Camaro ZL1
Does anyone have any pictures of a ZL1 with the stock SS wheels on them? I'm curious how they will look. I am not expert by any means but I think depending upon the offsets, the SS wheel could stick out or be recessed in the wheel well. Can anyone comment on that?
RobZL1580 is offline   Reply With Quote
Old 10-13-2012, 12:24 PM   #13
Norm Peterson
What I have for the SS
Front 245/45-20 on 20 x 8 x +35mm wheels
Rear 275/40-20 on 20 x 9 x +40mm wheels
For the ZL1
Front 285/35-20 on 20 x 10 x +?? wheels
Rear 305/35-20 on 20 x 11 x +?? wheels
If somebody can post accurate offsets of the ZL1 wheels, I can post up plots where the front SS wheel/tire package is overlaid on the ZL1 (and do the same for the rear). It accounts for the tire section width varying as wheel width differs from the "measuring width", <text deleted>
<sample plot deleted, see later post>
Norm
Old 10-13-2012, 03:00 PM   #14
fbodfather
fbodfather's Avatar
Some of our 2012 CTF ZL1s had SS wheels and ice/snow tires on them last winter - simply because we could not get the ZL1 sized tires in time to put the cars in service....from the side, they pretty much look like an SS until you see the hood and front splitter.
