Solo Performance
Old 01-08-2013, 09:39 PM   #85
Supercharged SS
Drives: 2010 Camaro
Could you change the title to:
"45 years until completion!!"
Ah, 6 bolts heads. That's nice to have. So it comes complete minus the intake?
Old 01-12-2013, 01:59 PM   #86
2SS45th
2SS45th's Avatar
Drives: 11 Seconds or Faster
That was the original plan, GM hasn't made the crate motor yet So I am now building the motor from scratch. It will still be the LSX motor, but will have entirely forged rotating assembly, CR around 9.3:1. Heads are backordered, but will be here in about a month, unless I go with PRC or Mast. Motor should take 18psi and at least a 300 shot. Dedicated fuel system for the Nitrous is next.
I Ain't About That Stock Life.
2SS45th is offline   Reply With Quote
Old 01-12-2013, 02:38 PM   #87
porkrind
Unapologetically American
porkrind's Avatar
Drives: 2013 Dusk Special Edition 2LT/RS
Wow...this build is intense!
Sent from my ADR6425LVW using Tapatalk 2
TEAM LFX
porkrind is offline   Reply With Quote
Old 01-15-2013, 12:29 AM   #88
Supercharged SS
Drives: 2010 Camaro
What's the deal with the stock engine you were building?
Old 01-15-2013, 12:32 AM   #89
2SS45th
2SS45th's Avatar
Keeping it around for now, I am reassembling it back to a drop in replacement. I might just forge it with what I have left over and have a spare. Who knows, maybe I'll sell it, I dunno.
Old 01-15-2013, 12:34 AM   #90
Supercharged SS
Drives: 2010 Camaro
In post 55 it looked like it was being rebuilt but it could very well be getting torn apart.
Old 01-15-2013, 12:36 AM   #91
2SS45th
2SS45th's Avatar
Yep, that was the initial tear down. As it sits now it is an empty block, sitting at a machine shop. It needs bearings to go back together, which I didn't expect with 1800 miles. Looked like there was some metal debris that came loose from the casting and put some grooves in em.
Old 01-15-2013, 12:43 AM   #92
Supercharged SS
Drives: 2010 Camaro
That makes sense. Thus the prowl for an LSX. Very nice. I'm interested to see how you fuel the nitrous with the dedicated system. Are you gonna go tank in the trunk like Ray?
Old 01-15-2013, 12:46 AM   #93
2SS45th
2SS45th's Avatar
Yeah I think so, Nitrous Outlet has a nice one designed for our cars. It'll at least ease the load on the LPE unit, which sounds like it'll be a good thing. If I can get 780 wheel with blower only I'd be good with that, then a 100 shot should take care of the rest. 780 is about all my injectors will support at 85% duty cycle too.
Old 01-15-2013, 12:48 AM   #94
Supercharged SS
Drives: 2010 Camaro
You won't see 780 wheel with an auto on the Maggie. Stick you will. That's where Jim topped out at.
Old 01-15-2013, 12:49 AM   #95
2SS45th
2SS45th's Avatar
Ooh I forgot about that, well my initial readings will be on a stick. The 4 speed should come into the picture sometime before CF4, but I want to give the shifting thing a whirl.
Old 01-15-2013, 12:58 AM   #96
Supercharged SS
Drives: 2010 Camaro
Farks is selling their T400 cross member. May want to look into that.
Old 01-15-2013, 01:00 AM   #97
2SS45th
2SS45th's Avatar
Hmmm maybe I should, I need to call RPM and find out what they would recommend too.
Old 01-15-2013, 01:00 AM   #98
Supercharged SS
Drives: 2010 Camaro
Check out "gotthato2fire's" build on here. He had a Maggie maxed 416 with the 10 rib through a built 6l. I think he could only make 14-15 psi on the 416 and I think barley cleared 700 wheel.
