HeadlightArmor
Old 07-04-2012, 02:44 AM   #1
RSloth
[COTW- Never!]
RSloth's Avatar
Drives: Slothy; Sloth-like
Radio issue.
anyone with the rs package/ connectivity package having trouble with the usb?
Im getting fed up with the same issues
1. my bluetooth messes up the usb connection and my music gets
scratchy, staticy, and poppy.
2. tonight my car decided it wasn't going to read my iPod after i had just had it plugged in and un plugged it to put music on it..
said it didn't recognize and data.
Ive told my dealer and they said id have to leave it there.
which is fine but I have an intake i don't feel like getting my extended warranty voided for..
any suggestions?
tips?
RSloth is offline   Reply With Quote
Old 07-04-2012, 03:55 AM   #2
Arthur 818
Arthur 818's Avatar
Drives: 2010 Camaro 2LT/Fully Loaded
Send a message via AIM to Arthur 818
any suggestions?
tips?
The same thing happens to me sometimes, While the music from my ipod thats playing starts making anoying and crackling noises, and only goes away when i unplug the usb then replug after then it sounds fine. Wonder why that happens and btw why dont you put your stock intake back on, then put it back on after they finish service. Takes less than 30 minutes for install/uninstall.
Arthur 818 is offline   Reply With Quote
Old 07-04-2012, 04:05 AM   #3
AdamZ
Drives: Eve - 2011 Camaro 2SS/RS
This happens to me to. Just unplug and plug back in.
AdamZ is offline   Reply With Quote
Old 07-04-2012, 05:59 AM   #4
HorsePower-Freak
HorsePower-Freak's Avatar
Drives: 2011 Camaro 2SS M6
Works flawlessly in my 2011 2SS, haven't had this problem at all. As soon as I get a call it stops my music and plays the ringtone through the speakers till I answer.
As far as the CAI and your warranty, I don't know how GM can prove that it was the CAI that causes the radio to mess up but yeah. Lawyers these days.....
Originally Posted by HorsePower-Freak View Post
I know when I punch the gas pedal it makes ma D!#* move, and since that's a muscle.....I consider it a muscle car
HorsePower-Freak is offline   Reply With Quote
Old 07-04-2012, 06:04 AM   #5
RSloth
[COTW- Never!]
RSloth's Avatar
Not what I'm worried about
they will see it. and then cancel it..
they are jerks here at rancho motor.
I asked the guy me and a friend took on a test drive of a v8
he didn't know what torque was, he didn't under stand the trim levels
he said RS package is for v8 only and I pointed to my v6 rs..
then asked him about mods i.e. mufflers and intakes
he said any engine modification will result in warrant void.
mufflers are okay as long as it passes smog..
So.. my take on this.
idiots hold the power, and I don't want to mess with stupid in that case.
Old 07-04-2012, 09:12 AM   #6
heRS
Raised by Wolves
heRS's Avatar
Drives: IBM 2010 2LT RS M6
Mine has done it twice with my husbands old beat up ipod but plays mine flawlessly. Go figure. Meybe it's the ipod?
Tori
Old 07-04-2012, 09:40 AM   #7
HorsePower-Freak
Old 07-04-2012, 09:58 AM   #8
Calikenn
Calikenn's Avatar
Drives: 2012 Corvette GS
OP...maybe you don't have the latest software for your system? There is another member, sir nuke, that is very knowledgable re these matters. You can search and PM him. Good luck.
Calikenn is offline   Reply With Quote
Old 07-04-2012, 08:44 PM   #9
Kryptic
Kryptic's Avatar
Drives: 2010 Camaro 2SS/RS
OP check out this PDF in this link. I believe GM will address this with a firmware upgrade. My 2010 radio does the same thing and it drives me nuts as I listen to my ipod more than the radio. I need to bring mine to the dealer also to get this fixed. Hopefully their latest firmware fixes this problem.
http://www.google.com/url?sa=t&rct=j...DVrHXjxbvqnXpQ
Kryptic is offline   Reply With Quote
Old 07-08-2012, 12:09 PM   #10
2Carats
2Carats's Avatar
Drives: '12 Camaro 2SS/RS LS3
mufflers are okay as long as it passes smog...
And you didn't kick his A$$ out of the car for being an ID10T?
I solve problems for a living. Either accept my advice or go figure it out on your own.
2Carats is offline   Reply With Quote
Old 07-08-2012, 12:37 PM   #11
Sir Nuke
Master of All Things
Sir Nuke's Avatar
Drives: '17 Corvette Z51 Coupe
if you are having these problems and you have a 2010 or 2011 model. There is a TSB out on our cars. Mine had the issue ya'll are describing. I did a lot of research here on the site and found the anwser. This has been a known issue since the car came out iof the factory back in 2009....and numerous fixes were tried with different software upgrades. bak in may of 2010 the fix was found and is available if your car is having the problem.
the TSB, and withing the thread Chevrolet Customer Service even posted up the GM P/N that will fix the issues.
There was a TSB (Technical Service Bullitin) issued (PI0055B) that will address these issues. I have attached the TSB and at the top is the GM P/N that needs to be installed.
The following information was sent to me via:
Scott Settlemire - GM Global Headquarters
Cheryl Pilcher – Camaro Product Manager
Jeff Morris – GM Customer Service.
In the TSB PI0055B, you will find this info:
In the top in the CONDITION/CONCERN section......This covers the issues with the operation of the unit.
NEXT you need to determine the Hardware/Software version you have in your system and how you and the dealer will proceed.
In the next section down, the RECOMMENDATION/INSTRUCTIONS section gives you the inscructions on how to determine the HW/SW version. If your HW version is either a Cx (where the X stands for any of the C versions) or a DA you need to have them REPLACE the entire PDIM unit....hopefully this is where you are at. PRINT OUT THE TSB and take it with you when you go to your dealer.
PI0055B with GM PN#.pdf
There is a thread here that was started in 2009 and is still going....whe I had this same issue, I found the thread and it was 30 pages long, its up to 39 pages now, and still active....I read every page, and did my homework.....even the GM Service Rep was helping and was posting so that all the correct info was put out. I went to my dealer with this TSB, they ordered the part listed on the top of the TSB and my system has performed FLAWLESSLY ever since.
Here is a link to the thread: http://www.camaro5.com/forums/showthread.php?t=31235
also attached is what your HW/SW window will look like when the proper PDIM is installed.
Old 07-21-2012, 11:45 PM   #12
ImperialSScamaro
Im a noob
ImperialSScamaro's Avatar
Drives: Black 2016 1SS
Chevy wouldn't help me with this issue. Lots of people having it.
ImperialSScamaro is offline   Reply With Quote
