| Camaro ZL1 Forum - ZL1 Specific Topics Camaro ZL1 specific topics |
Thread Tools |
#1 | |
Wired SS
Drives: 1967 Camaro, 2010 Camaro, 2012 ZL1 Join Date: Apr 2009
630 RWHP ZL1 by LMR
Here is the latest ZL1 upgrades from Late Model Racecraft. -LS3 Comp Cam Kit, Comp Custom Grind Cam Shaft, -Comp Double Valve Spring kit good for .675 lift, -Titanium Retainers, Spring Seats, Valve Seals, and -Comp Chromoly Pushrods -LMR Custom Torque LMR Custom Torque Converter -Upgraded Heat Exchanger -Solid isolator -2.55” upper pulley -Upper pulley hardware kit - Dowel pin - Pulley cap - Alignment dowel pin - Bypass positioning tool -160* Thermostat -LMR Cold Air Induction System -10% overdrive harmonic balancer -63 lbs/hour fuel injectors -American Racing 1 7/8 He... 1 7/8 stainless steel headers/Connection ---pipes with high flow cats -NGK Spark plugs... NGK Spark plugs Iridium Plugs 89.63 89.63T -MSD 8.5mm wires LS1 MSD 8.5mm spark plug wires Last edited by Ben Herman; 07-04-2012 at 07:23 PM. |
![]() ![]() Drives: Getting 2010 Camaro Join Date: Jul 2008
You see , this is what I don't get. For all those cry babies out there saying that the new GT 500 has 662 HP and the Camaro is slower in a straight line. From everything I've seen the GT 500 is at least $6000 more than a ZL1.
I'm pretty sure these upgrades at LMR was less than $6000. Now this car has roughly 725 HP wich should more than keep up with a GT 500 and for the same or less money |
![]() Drives: 2012 ZL1 #165 Join Date: Apr 2009
Man that thing sounds good! Are you guys going to make another video at the strip with the new mods? (That's the same car, right?)
P.s. Just for the record, the mustang doesn't need all the options to handle well at the strip... |
![]() ![]() ![]() ![]() ![]() Drives: 2000 Camaro SS Join Date: Dec 2008
MSRP on the 2013 gt500 is 55k, about what the zl1 is so its not 6k more. You also just lost your warranty.
Drives: 2012 ZL1, 2009 CTS-V Join Date: Jun 2011
Solid mid ten second car. Congrats.
#6 |
![]() Drives: Blown G8 GT Join Date: Apr 2010
Damn that sounds good
2008 G8 GT-Procharger D1-Livernois Stage 1C Cam-Kooks 1 7/8 Longtubes-Magnaflow Exhaust-Camaro SS Wheels and Brakes-Demon8 Designs Triple Gauge Pod( Dual Aeroforce and Wideband)- Dual Kicker CVX10-BMR Sway Bars, Trailing Arms, Toe Rods and Cradle Bushings
596/526 @9.5 lbs 11.6 at 123. 1.92 60ft |
#7 |
![]() Drives: Don't have my Camaro YET Join Date: Aug 2010
I stopped chewing my chips to hear the car better. its a beast.
#8 |
![]() Drives: Grabber Blue Mustang GT Join Date: Apr 2010
i was told the ZL1 has a 1.9 liter blower. is that correct?
#9 |
![]() Drives: 2003 Mustang Cobra Join Date: Jun 2010
630 with cats, NICE!!! Are strip times in the future?
#10 |
![]() Drives: myself crazy Join Date: Apr 2008
Nice...very nice numbers
#11 | |
Who really gives two $H!TS about warranty, highly over rated.... |
#12 | |
CaRaHoLiC
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp Join Date: Aug 2011
Track your ford and you lose YOUR warranty.
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams stage 3 cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, Tuning by Jannetty, install by me. |
#13 |
![]() Drives: 2011 chevy camaro ss Join Date: Jun 2012
Is kenne bell or whipple gonna make a twin screw for the ZL1?
#14 |
#15 |
#16 |
Petro-sexual
Drives: Ultra-Grin Join Date: Oct 2006
LSA is still a 6.2, like LS3/L99, so I imagine it should fit in ZL1 with no problems. I have to wonder if the STB might get in the way, but I imagine it probably won't. There are other solutions I believe would take care of that anyways.
"...What IS true: We anticipated that this would happen - we are never finished - and yes, Ford DOES deserve to win now and then. To think that GM can come out with a car to make ford throw in the towel is simply foolhardy..." - fbodfather
#17 |
I don't see why the LSA would make more power than the LS3 with a tvs2300 on it. The LSA is just way better built to handle the power
#18 | |
Petro-sexual
#19 |
![]() Drives: 2013 red Lingenfelter ZL1 Join Date: Apr 2012
Can you guys give mustang comparison a rest!!! That thing acts like it wants to jump off the dyno! Awesome!
#20 | ||
![]() Drives: 2010 Vette Join Date: Jun 2010
Ben....WICKED sounding car with nice numbers - congrats! |
#21 | |
When I bought my '98 Camaro SS, I didn't bother with the extended warranty, because I knew I was going to mod and race it. It's a good thing I knew how to fix cars, plus in 1 1/2 years I put on 40K miles, so the warranty was gone quickly.
#22 |
On the mod list I did not see anything about head porting? Man that sounds wicked!!!
#23 | |
![]() Drives: Ford Join Date: Jan 2012
FWIW, I am sure this package is mroe than 6k installed. |
#24 |
Whats the limit on the rotating assm. on the zl1? Doesnt it have non forged internals?
#25 |
![]() Drives: 2010 2SS/RS/LS3 Join Date: Dec 2011
Wow...that thing is a beast
| Thread Tools | |
