Solo Performance
Old 07-06-2012, 05:21 PM   #43
BubbaSS
WHAT RED LIGHT?!
BubbaSS's Avatar
Drives: 2011 Black Camaro 2SS/RS M6
You guys can always get smaller rear gears to torque it up
2011 2SS/RS M6 BLACK - VARARAM NO TUNE INTAKE, MODDED AND PORTED TB, PORTED INTAKE MANIFOLD, VITESSE THROTTLE CONTROLLER, DOUG THORLEY LT'S, CATLESS, X-PIPE, 25" STAINLESS WORKS RETRO CHAMBERED MUFFLERS, CUSTOM 2.5" MANDREL BENT EXHAUST, RICHMOND 4.10 GEARS, CUSTOM CAM (231/242 @ 114LSA), MUSTANG DYNO TUNED BY TORQ, 20% CERAMIC TINTS, EIBACH PROKIT SPRINGS 1" DROP, HAWK PERFORMANCE CERAMIC BRAKES, NITTO INVO TIRES, HYDROCARBON TAIL LIGHT AND FOG LIGHT BEZELS BY EMBLEMPROS, METRA DASH KIT, JVC KW-AV71BT, PHOENIX GOLD iAMP GM1, PASSPORT QI45 - 450 RWHP 415 RWTQ
BubbaSS is offline   Reply With Quote
Old 07-06-2012, 06:07 PM   #44
Henry G.
Drives: 2012 Camaro LFX,CAI,DynomaxVT,RX CC
Yohan love AB have all three albums! Seriously, you got to rev that thing, thats all it is. Get a catch can so youre not puking oil into the intake and let 'er rip!! I can hit about 100 in 3rd gear, this little car is under-rated! If there is a next Camaro, get the manual!!
What Simplegreen said too.
Henry G. is offline   Reply With Quote
Old 07-06-2012, 06:09 PM   #45
butters
It's not the batmobile!
butters's Avatar
Drives: 2010 Camaro SS L99
Wouldn't you want bigger gears for more torque? I believe the A6 is 2.97?
butters is offline   Reply With Quote
Old 07-06-2012, 06:52 PM   #46
Yohan
Drives: 2012 Camaro V6 1LT
Originally Posted by SimpleGreen View Post
Your really comparing apples to cookies though.
It's hard to find spec's on the 4.7L but I know it makes atleast 315tq at 3400 RPM. Your Camaro only makes 278tq at 4800 RPM. That is exactly why it feels good at 4000RPM and up. If you aren't driving the engine where it makes power, then it just doesn't make power. There is no magic trick to making a V6 drive like a V8 short of serious power adders. Big motors make power down low, little motors make power up high. That's why those Hondas have tachometers that get awful close to double digits.
Great post, and yes those are the torque numbers for the '04 Sequoia 4.7L. With those torque numbers, even though its a brontosaurus at 4600lbs, it just jumps when u tap the throttle from dead stop, and gets up to speed quickly, effortless.
With our 1LT A6, at only 278ft lb tq, seems like it's kind of low for the weight of the car.
As noted on the SS---426hp/420 ftlb TQ, almost a 1:1 hp/tq ratio---it can effortlessly accelerate and doesnt need to be revved to 4000 rpm to feel alive getting normal driving or a little agressive, I'm sure.
However, for our V6, we only get 278, and wish it was more like 317-320 ft lb TQ, for a similar HP/TQ ratio of 1:1, like an SS.
So why only 278? Is because it was programmed from GM this way, shift points, etc., or the gearing is not as good?
In meantime, I've def learned so far that it's ok to be more agressive on throttle on this car---seems like it likes to revved as you said, and gets bored and sluggish w/ lower rpm, LOL.
Yohan is offline   Reply With Quote
Old 07-06-2012, 07:35 PM   #47
Yohan
Henry, ABIII & Creed, man
For now, I'll defenitely drive it in Sport mode, and use more rpm. For city, I just get up to 45-50mph faster, accelerating at 3-4ooo rpm, and once it hits 4th I just let it coast and keep it around 1200rpm and watch those mpg avg numbers soar, as I blast "Broken Wings", lol
Old 07-06-2012, 09:22 PM   #48
Henry G.
Get the exhaust and CAI if you can afford it. It will enhance a tune and/or intake if you decide later to pull those triggers. Honestly there is a nice gain from both.
Old 07-06-2012, 09:44 PM   #49
Yohan
Got the CAI kit a few weeks ago, and lovin it. Now its a matter of making it more responsive in low end, and I think the ported TB should help.
Wish there were LFX programmers available already so I could play around with shift points. Someone mentioned that IFS Live reads the 2012? Wonder if hypertech is releasing something for our LFX anytime soon.
Old 07-06-2012, 09:53 PM   #50
KMPrenger
KMPrenger's Avatar
All V6s except the 2LS have 3.27 gearing.
Actually 278 TQ is not too bad for this engine. Sure, 300 TQ would be nice, but look at many other potent V6s out there and you will find their TQ numbers are quite a bit lower than their HP figure. My numbers aren't exact, but the mustang V6 makes around 273TQ, and even the all mighty 370Z makes no more TQ than our car does. But both of these cars offer lower gearing and weigh less and so their straightline performance is better.
Look at the new Cadillac ATS with the LFX V6. It has the exact same 3.27 gearing, but weighs only about 3460 lbs compared to the Camaro V6 3750 lbs. The ATS is rated at 5.4 seconds 0 - 60 while the Camaro was rated 4 or 5 tenths of a second slower to 60 than that. Put lower gearing or add bolt ons to that ATS and suddenly you could have a V6 that will do the 0 - 60 in under 5 seconds.
Old 07-06-2012, 09:59 PM   #51
Yohan
Did someone suggest a tune? Jeesshhh, this guy's peelin while upshifting have read and heard great things from Trifecta tunes. Will wait a little to see if there's a programmer out there for LFX to mess around with simple tunes myself. Not looking for fancy stuff--just need to upgrade those shiftpoints, and be able to "hide" the tune when going to dealer for SVC.
Old 07-06-2012, 10:11 PM   #52
Yohan
Originally Posted by KMPrenger View Post
Actually 278 TQ is not too bad for this engine. Sure, 300 TQ would be nice, but look at many other potent V6s out there and you will find their TQ numbers are quite a bit lower than their HP figure. My numbers aren't exact, but the mustang V6 makes around 273TQ, and even the all mighty 370Z makes no more TQ than our car does. .
The TQ is not bad, but our heavier Camaro v6 could use a boost in tq. But even a v6 Mustang with 305 hp and 273 tq = 1.11 ratio, where our Camaro has almost 1.17! Its the weight of our car that hurts us some, or the lack of torque.
Old 07-06-2012, 10:16 PM   #53
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Garnet red 2016 Camaro 2SS
I've had an L99 and currently have a 2012 SS M6. For kicks the other day, I went to the Chevy dealership and drove a V6 Camaro auto trans and I was very impressed by it's performance. I tried it at moderate throttle, wide open and in both manual and sport modes and it definitely has a lot of spunk for a V6. I wish I had the bucks for a second new car, it would definitely be one like yours.
SOLD: 2016 Camaro 2SS, Garnet Red Metalic, 8A, NPP, Nav, Sun Roof, upgraded silver wheels, lit door sills, Ash gray interior.
Now driving a 2017 Silverado, Red Hot, 5.3, regular cab, short bed and lovin it. Waiting until later this year to buy a Z16, C5...it's hard to wait.
Previous Performance Cars:
1966 Chevelle SS 4M 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto
2002 C5 Corvette 6M
2006 Corvette Auto
ParisTNDude is offline   Reply With Quote
Old 07-06-2012, 10:19 PM   #54
SimpleGreen
Drives: 2013 1SS/1LE IOM
Because engines are still very much mechanical beings. It goes much deeper than computer work. Valve sizes, camshaft profiles, piston sizes, crank stroke, head flow, intakes, etc...the engine doesn't make high torque because that's not how small naturally aspirated V6s work. Its extremely common for a motor of the size to make more HP than TQ the way this one does. It's simply the nature of the beast.
The Ford Ecoboost 3.5L V6 makes 367HP at 5400 RPM and 420TQ at....2500 RPM. Because, among other things, they stuck twin blow dryers on it. That's the exception.
Yes, the 6.2L doesn't need to rev to 4000 to move because it makes far more power down low. You have to understand how an internal combustion engine works before you can compare to wildly different engines such as the LS3/L99 6.2L and the LFX 3.6L. They simply will NEVER act the same. They having nothing in common aside from running on gasoline. They make way different amounts of power in different places. No computer tune, CAI, exhaust, or rear end gears will make one act like the other. Short of $6K investment into forced induction a V6 is going to act like a V6.
278TQ isn't much for a 3700lb car, but if one drives that engine like GM designed it to be driven, it motivates these fat Camaros just fine
Stock for stock, it will never compare to a V8 but I wasn't spending $7500 more to get to a entry level 1SS and then paying even more on insurance than my already high truck premiums.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 07-06-2012, 10:20 PM   #55
Yohan
Here's a vid of 0-60 on a v6: Sure I can hammer it like that get it to shift near redline, but that's not how I get out of my driveway to go work, man I'm talking more about normal daily driving, especially low end, pulling out from stop or turning into street and then accelerating, etc---that's when the lag or sluggish feel seems be at when compared to a v8. Perhaps it was just that I was expecting my A6V6 to respond lowend like a v8, more alive, but instead we just gotta rev it more.
Old 07-06-2012, 10:23 PM   #56
SimpleGreen
Precisely. You MUST rev smaller motors to get power. Sad fact of life, lol.
