| Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons Bolt-Ons | Intakes | Exhaust |
Thread Tools |
#26 | |
GrINned & JUICEd
Drives: EB Expedition, 2010 2SS/RS M6 Join Date: Nov 2009
Select the IAT pid, to accurately log AFR you need to have a wideband sensor installed in the exhaust along with a gauge/meter that is capable of sending an output voltage that represents the AFR, through the firewire to the handheld. Such as 0 volt output would be an AFR of 10 and a 4 volt output would be an AFR of 20. All voltages in between would be AFR=(Voltage*2.5) + 10. With Livelink II, you can enter this equation as analog input 1 or 2 and it is supposed to display it as the AFR. Well guess what. It doesn't work either. Livelink II will only log the raw voltage. Which you must then convert with the equation. Does your boost gauge/meter have a voltage output for logging? If so, then you could use the other analog input to log the voltage, then convert it. As far as your ZR1 MAP, that should be a PID you can choose.
Nitrous Outlet Plate (progressive, fuel hose upgrade, remote opener, heater, filter, console switches), LNC2000, ARH 1 7/8" LTs/gutted cats/X pipe/mufflers, Jet Hot Coated LTs, JRE SCT Tune, CAI, Rx Catch Can, Gates heater hose relocation, Metco loop, Momentum Tunnel Brace, Autometer wideband, Fesler Pillar Pod, LED strips (interior), Lloyds floor & trunk mats, LED DRL/front turn & license plate, DRL harness, VLEDs tail lights, Plasticoat Bowties, vinyl Bowtie center caps. No holes drilled. Ord: Oct 5, 2009 Rec: Nov. 19, 2009 13.17 @ 112.6 Bone stock
#27 | ||
Drives a Maro
#28 |
GrINned & JUICEd
I did that too. Says I'm up to date on all of it. Firmware too.[/QUOTE]
Yes, but that is for your current firmware and software. SCT does not have the new firmware on their site. You can download Livelink II from their site, but you need to call them for the firmware. SCT techs will remote into your computer and install the updates. They are also having headaches with getting the G8's to log. SCT will not release firmware on their site until all the issues are resolved. btw, what model is your handheld? Maybe if it's too old, you won't be able to get the new stuff.
#29 | |
![]() Drives: 2011 1SS/RS L99 Join Date: Aug 2011
2011 1SS/RS L99 VR - - Livernois 2c-hl cam, Livernois stage 2 heads, ported intake, ported TB, CAI intake, ADM scoop, Stainless Works 1-7/8" headers w/ hfc, Magnaflow 3" exhaust. - - 451 rwhp/411 rwtq - - |
#30 | |
Got Boost?
Drives: 2010 1SS RS Join Date: Aug 2011
[/QUOTE]+1 Call SCT and they will take care of it. Had to do the same. Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it. |
#31 |
Drives a Maro
My handheld is a few years old. Always worked just fairly ok for loading tunes into the car.
Data logging it has NEVER worked well. I haven't tried the new program. Shouldn't have to. Unless the old program rarely worked for ANYONE. I'm trying to find someone who has used this program to data log with any kind of regularity. A lot of people love SCT but I doubt a lot have logged a ton using LiveWire. I think most just load a tune and scan codes. Is there a better way to do it without buy the expensive tuner software? That would be overkill. I'm not a tuner and don't want to be. Just want to be able to log my car FOR a tuner to look at. Or to just get a few readings to use like in this case. I don't mind buying a stable handheld and program. For now I'm going to send the tensioner and pulley back and look into a logging program. Bottom line is I can't log the car and need to before and after I make any changes. |
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro Join Date: Feb 2010
9.80 @ 139.73, 1.45 60', 2010 Jannetty Racing L99
#33 | |
Drives a Maro
With SCT having all these problems I'd prefer to try another system. IF there are any that is good. Other than that I'll have to take it somewhere to have it done. Which sux because it's a 5 hour drive to the closest one. |
#34 | |
You should be able to calculate/log boost using MAP (uncertain about the PID, but it's there) and deduct the current barometric pressure from the amount read by the SCT, that'll give you your boost...
As far as AFR is concerned, I guess the SCT is kinda useless ![]() I got myself an Innovate LC-1 and an OT-2, this combo logs all the essentials and some more (except knock retard ) and logging itself is a breeze!!!One issue though: the OT-2 only talks to "apples".... Quote:
New engine in the works / TVS2300 / Built by Henrik's Racing & Customkingz / Tuned by Jannetty Racing
Kooks Headers / SLP LMII / Noweeds / CMGS Water Meth / JRE Maggie Max Stg.1 Pfadt Bushings, Arms & Rods / Pedders Supercar / HE Twin Carbon Street Slayer / DSS 1000hp Axles CTS-V Brake upgrade / Street: 22'' Vossen CV1 / Strip: 18'' Forgestar F14 on MT Street Radials http://www.camaro2010.de/ |
#35 |
I've never had one single issue with my SCT stuff. The only problems that arise are self inflicted.
#36 | ||
Drives a Maro
Where can I find that equipments and some 'apples'? hahaha Quote:
This is my problem with SCT. They are not user friendly at all. While I"m not an IT guy, I know my way around gadgets and computers. This is a software, firmware problem OR there is a trick that is not commonly known. I'm still looking for someone who has been able to set up the SCT with LiveWire from scratch and make it work well who isn't a tuner. I can't call SCT I have to be here at the office and don't have time during the day to fool with it. I'm gonna look into this Innovate LC-1.
#37 |
The SCT does work well for me, that's not the issue.
It's just that this innovate stuff is easier to work with, if you're only looking into logging, and the extremely useful gadgetery it comes with, such as fuel economy, dyno runs and uploading your personal spark advance tables to facebook ![]() Along with the LC-1 it should give you what you need - again excl. knock retard Here are the links: http://www.ot-2.com/ http://www.innovatemotorsports.com/products/lc1.php The OT-2 comes with LogWorks Software As far as apples are concerned... well... Watch out for trees like this - especially in summer you should be lucky finding some lying underneath ![]()
#38 | |
Drives a Maro
![]() That looks cool as shit. So it hooks to your OBDII and then send the info to an easy to read graphic interface on your phone and will datalog it too? Please tell me it's not ONLY for iPhone? THIS is what I'm talking about with SCT. It can be done so much better. And for the same basic cost too. (considering most already have a smart phone)
#39 |
The OT-2 is Apple only as far as I know - maybe you can have some scientists fiddling with it so it talks to other devices as well ![]() It's some much more conveniant not carrying a computer with you to actually see what you're logging. And it makes you look less nerdy too... Best thing it's WiFi and has build in router, so you can have LAN-Parties in your car ![]() But seriously: with the LC-1 (AFR) hooked up (still need to do that) it's a pretty cool package
#40 | |
Drives a Maro
![]() :upset: :upset: :upset:
#41 | |
Drives a Maro
OMG, this is so Fing cool.
#42 |
Drives a Maro
Triple post.
Screw it. I have an old iPhone I can use. Assuming the iPhone doesn't have to have phone service. Can't imagine why it would. Clearing coeds, reading engine CELs, all the info you want, easy to read, datalog, accurate 0-60s and other times, and more. I'm in. Anything else I might need to know. I gotta send my tensioner and pulley back or Bonnie will kill me. But I can at least read what I need and order it again later.
#43 | |
Tell Bonnie it works on Corvettes as well
![]() Quote:
But at least it doesn't require red hoses
#44 |
Fireproof Moderator
Randy - do you want me just to mail you my predator tuner? I've got it all set up for data logging already. All you'd have to do is plug it in and hit the "log data" button
#45 |
![]() Drives: Camaro 2SS/RS Ice Silver Join Date: Oct 2009
I used SCT to log too. The only way to set the PID's to log by the following steps.
- launch LiveLink. - start the car. - connect the ODBII cable to SCT device. - connect ODBII cable to the port. - connect the USB cable to SCT device then to the laptop. - open and configure your PID's. - save the config file and use it every time you want to log. Note: there is a special firmwere to log gen5 Camaro (which provide stable connection) only available by contacting SCT support. You cannot customize PID's like HPTuner to make one for boost. But generally boost equals (MAP-Baro) to get it in psi ( (MAP-Baro)/6.9) ). It is note necessary to log Barometric pressure every time. You have to know it one time only and use it as a constant. Sent from my GT-N7000 using Tapatalk 2 |
#46 | ||
Drives a Maro
I can make red hoses work on it anyway. LMAO To have an acurate AFR at all times would be pretty cool. I still want to put the gauges in for AFR, IAT and PSI but this will be awesome till I do. And even after. Quote:
I think I'll buy it AND keep the tensioner and pulley. I'll just do the AFR some other time. For under 200.00 I can have the system shipped to me. ![]() Ordering front Supercars to go with my rear ones so I'm a bit strapped right now. Have XAs in front right now and supercars in rear.
#47 | |
Drives a Maro
I decided to just get the easier system. Much better. At this point the only thing SCT is good for is carrying tunes to load to the car. And I can still use it for that. I now will have easy access to easy to read data logs and everything else at all times. But thank you for your help. With the one I'm getting it's just read boost for me.
#48 |
I use LM-2 to log AFR and also it can log PID from ODBII. Also i hook the wideband to the exhaust.
I wish for a softwere that can convert tune files between SCT, EFI Live, HPTuner and Diablo. Like converting video or music files from format to format. So you can use your preferred platform for uploading tunes and perform datalogging, while your tuner use his preferred tuner program. Sent from my GT-N7000 using Tapatalk 2 |
#49 |
Here are some screenshots...
That's the log from the OT-2 using LogWorks that came with the scanner. No AFR yet, as the LC-1 has yet to be put in the car... Not a Pro-Tool but it does it's job ![]() But that's enough thread hijacking I guess...
#50 | ||
Drives a Maro
Apperently you have to be a pro almost to use SCT to log. I'll just get the LC-1 to log and scan and clear codes and use the SCT if I ever need a mailed tune. Which I doubt. |
| Thread Tools | |
