Old 07-06-2012, 07:10 PM   #1
Topnation
Topnation's Avatar
Drives: White 2012 Camaro 2Lt RS
Ground For Amplifier
Just curious but where did yall ground yalls amplifier to for your audio systems? Im having a hard time finding a good ground spot and looks like I might have to drill
Topnation is offline   Reply With Quote
Old 07-06-2012, 07:19 PM   #2
jeepguy_1980
jeepguy_1980's Avatar
Drives: 2010 Camaro 1SS
My battery
jeepguy_1980 is offline   Reply With Quote
Old 07-06-2012, 07:23 PM   #3
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
If you take out the trunk trim, you will find a hole in the chassis structure just below the rear deck. Make sure to sand off the paint and use a star washer to ensure a good connection. Make sure to use wire at least as heavy as your power cable.
I used this location because it was convenient and quite adequate. I am running a 1/0 cable from there to a block for three high power amps and have no problems whatsoever. No power issues, even with the BA head unit, there isn't even any detectable hiss between songs at high volume
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 07-06-2012, 07:35 PM   #4
jeepguy_1980
a.k.a. The only head unit. 2013 models not withstanding.
Old 07-06-2012, 07:51 PM   #5
Topnation
Topnation's Avatar
CWI I will check that spot and Jeepguy ill do battery if all other possibilities dont work. Thank you
Old 07-06-2012, 08:55 PM   #6
CWI
CWI's Avatar
That spot is on either side below the rear deck but above the fender well. It's maybe a 3/8"-7/16" hole in the sheet metal. I think I used a 5/16" bolt. Very solid ground. Like I said, just be sure to clean the paint and I recommend a star washer for better contact.
Old 07-06-2012, 10:15 PM   #7
yzark99
I run 2 catch cans...
yzark99's Avatar
Drives: 2012 1LT SIM Auto
I used one of the protruding studs under the rear deck, next to a 6x9 speaker. I think it is a 5 or 6mm nut, fine thread. I sanded the stud area, used a flat washer, a copper electrical lug that is attached to a 4-gauge ground wire, a star washer, another flat washer and a nylock nut to hold the whole mess together and prevent it from vibrating loose.
Overkill tuned • Air Scoop • CAI • VMAX PTB • JacFab Extendolator • SOLO Hi-Flo Cats and Cat-Back Exhaust
View my top 3 LFX performance mods and more:
yzark99 is offline   Reply With Quote
Old 07-07-2012, 12:25 AM   #8
Topnation
Topnation's Avatar
I just wired it to my battery and sups play good! thanks for the help and the Ideas.
