R1 Concepts
Old 07-21-2012, 03:14 PM   #183
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Refill needed
And glad to hear your bro is ok
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline
Old 07-21-2012, 03:38 PM   #184
SIXJAK
SIXJAK's Avatar
Drives: MO's only SC'd LLT.
Originally Posted by jrrod6410 View Post
Refill needed
No belt yet.
IPF supercharger kit, IPF tune, SW LT's, R. Tech HFC's, ARK DT-S catback, SS Brembo brake upgrade, BC Racing adjustable coilovers, Hurst STS, Pfadt rear arm package, Pfadt adjustable sways & end links, Pfadt diff bushings, BMR rear cradle full kit blk bezels,SS diffuser, Innovate gauges.
SIXJAK is offline
Old 07-21-2012, 04:38 PM   #185
SIXJAK
SIXJAK's Avatar
Update. Jon just called said belt came in and he had cut it down to a 6 groove belt and then said "Listen up" and then I heard my car start. OMG!!!!! Headed over there after the show tonight and we're going to do our best to get that thing started up and take it for a test drive.
It's hotter than H at the shop so Jon's gonna take a break go get a few more things and then we're gonna get that thing plumbed and IC mounted solid.
Tracy what size bolts used on the catchcan. I left mine in when I shipped it to you but since you sent a brand new 2 valve out. I don't have any. I can either pick some up at Wally World tonight or perhaps bum a couple off my neighbor-stereotypical old guy who has every tool bolt nut and screw ever made and knows where all of it is to boot. He rules.
SIXJAK is offline
Old 07-21-2012, 05:27 PM   #186
V6owner
Cedar Creek Woodshop
V6owner's Avatar
Drives: One Badass 1LE
Awesome! Can't wait!
2014 Black 2SS/RS 1LE
V6owner is offline
Old 07-22-2012, 10:32 AM   #187
SIXJAK
SIXJAK's Avatar
Installer-Jon was experiencing heat exhaustion like symptoms last night so we were not able to get the car running last night/early this morning like we had hoped. After this past week, not messing around with this heat.
SIXJAK is offline
Old 07-22-2012, 11:07 AM   #188
BaylorCamaro
Track > 1/4 Mile
BaylorCamaro's Avatar
Drives: 2016 C7 Z51
Good Lord man, you guys are having some serous heat there it sounds like!
BaylorCamaro is offline
Old 07-22-2012, 11:25 AM   #189
V6owner
V6owner's Avatar
Damn heat is no joke
V6owner is offline
Old 07-22-2012, 12:26 PM   #190
baup5f
baup5f's Avatar
Drives: 2010 2SS/RS Coupe
Hope all is well man. This is pretty exciting, but safety has got to be #1.
2010 CGM 2SS/RS
baup5f is offline
Old 07-22-2012, 02:20 PM   #191
KMPrenger
KMPrenger's Avatar
Drives: 16 SS Camaro, 06 Colorado
With high humidy, and 100+ degree heat that makes it feel more like 110 or so and working in a shop on top of that....lots of breaks and fluids should be required!
So Jak...you keep saying "tweener" belt lol. At first I thought you meant it was the belt that provides the lower boost rating....or is it the smaller belt that provides the higher boost rating? lol Thanks.
You should be ultra excited now after the SWEET times that V6owner got out of high car in the bad conditions and with the 6 psi belt.
KMPrenger is offline
Old 07-22-2012, 03:01 PM   #192
SIXJAK
SIXJAK's Avatar
Update. Radiator air scoop is modded, plumbing for SC is complete. Taking a break because it's too haught. Just need to Tee into vacuum line for BOV, mod crash bar with vents and install gauges. Prolly do that this evening. Gettin there peeps.
SIXJAK is offline
Old 07-22-2012, 03:10 PM   #193
V6owner
V6owner's Avatar
I'm sure Jon knows this already but just want to you avoid the no boost experience I had. But tap into the line before the check valve lol
V6owner is offline
Old 07-22-2012, 04:39 PM   #194
SIXJAK
SIXJAK's Avatar
Yep. Will do.
SIXJAK is offline
Old 07-22-2012, 11:27 PM   #195
SIXJAK
SIXJAK's Avatar
Here's some pics.
Pre modded crash bar. The more my installer mulls this over it looks like he's leaning towards doing something similar to SSE 4 2SS's crash bar design. He's also going to try and mount another fan up in there as well.
Oh and do not test drive with front clip off. Derrrrrrrrrrrrr.
Guess I be ordering a new set tomorrow. Uploading vid shortly.
SIXJAK is offline
Old 07-22-2012, 11:47 PM   #196
V6owner
V6owner's Avatar
Ouch!
I like the placement of the intake filter! Word of advice use a T-clamp and flare the end of the tube!! Trust me. Mine fell off while driving and I crushed it
V6owner is offline
lol
