JDP Motorsports
Old 07-07-2012, 06:02 AM   #1
TriGun
TriGun's Avatar
Drives: Camaro 2SS/RS Ice Silver
Oil Pressure Sensor Problem ?
Recently I installed JRE Smooth Idle Blower Cam. I drove the car for a week and NO troubles at all. Engine Oil level and pressure were fine, nothing out of ordinary.
Today when I started and after warming up the car, oil pressure gauge needle either set at 0 or 70 (max) and NO engine light came out.
when I plugged HPTuner to check for DTC I found the following code were thrown:
P0522 Engine Oil Pressure Sensor/Switch Low Voltage
P0523 Engine Oil Pressure Sensor/Switch High Voltage
I guess it is the the problem is the oil pressure sensor went bad or its wiring has some problem.
if there is a problem with the oil pump, one of the above codes will be thrown and another different code regarding the oil pressure.
What do you think ?
My Current Mod are:
- MagnaCharger TVS2300.
- 6-ribs 3.6 Supercharger pully.
- L99 to LS3 Conversion Kit.
- LS3 Smooth idle blower cam package.
- RX Catch can.
- ZR1 3 bar MAP sensor.
- Rotofab Maggie CAI.
- American racing headers 1-7/8 with x-pipe no cats with mufflers and tips.
- 160 thermostat.
- ZR1 plugs with MSD wires.
- MSD fuel pump booster.
TriGun is offline   Reply With Quote
Old 07-07-2012, 07:17 AM   #2
TheHorse13
TheHorse13's Avatar
Drives: 2011 Black SS M6
If you had a bad oil pump, the DIC would be screaming at you. There are a few threads about the exact conditions when an oil pump goes bad. The codes/warnings are different than the ones you have here.
TheHorse13 is offline   Reply With Quote
Old 07-07-2012, 07:53 AM   #3
Southern Comfort
No Tags/Habitual Violator
Southern Comfort's Avatar
Drives: 2010 ABM/LT/RS & z71
What do you think ?
My Current Mod are:
- RX Catch can.
- 160 thermostat.
Can you log oil pressure to validate the readings?
Also, listen for lifter/rocker tapping. If you hear any noise louder than normal, shut it down immediately.
Southern Comfort is offline   Reply With Quote
Old 07-07-2012, 09:40 AM   #4
TriGun
TriGun's Avatar
No unusual noise coming from engine. Now i have another code P0521 which is related also to sensor "P0521 Engine Oil Pressure Sensor/Switch Range/Performance".
when i logged the oil pressure via HPTuner the values were 412kPa=60psi when the engine is not running and 712kPa=103psi at idle.
Sent from my GT-N7000 using Tapatalk 2
Old 07-07-2012, 09:42 AM   #5
Jayrcr3
Jayrcr3's Avatar
Drives: 2011 IOM 2SS/RS
The sensor is bad. I would guess it's reading about 40psi at idle, but something has caused the reference voltage to be off (the sensor).
Sent from my HTC One X using Tapatalk 2
American Racing 1 7/8" Headers and Hi-Flow Cats, CAI cold air intake, Flowmaster AT exhaust, Vengeance Racing Stage 2 cam, VMax ported throttle body, TEA valve springs and titanium retainers, Trick Flow hardened pushrods, 180* T-stat, Comp Trunion kit, ZL1 Fuel Pump, ADM Fuel Pump Control Module, 20% window tint, Whipple Supercharger. Tuned by Mike Norris Motorsports. 656rwhp/584rwtq @10 PSI.
Jayrcr3 is offline   Reply With Quote
Old 07-07-2012, 11:15 AM   #6
TriGun
TriGun's Avatar
I guess that too. Maybe sensor cable is damaged while installing the supercharger.
Old 07-07-2012, 02:16 PM   #7
SC2150
Reach back around to make sure you did not pinch the harness to the sending unit between the IM and the heades. Seen that far to often.
Old 07-10-2012, 12:02 AM   #8
TriGun
TriGun's Avatar
I replaced my oil pressure sensor and now it is fine
