BeckyD @ James Martin Chevy
Old 07-07-2012, 09:23 PM   #1
Steve@HPE
Drives: 2014 SS/RS
SC pulley change on a ZL1
I was told that the blower has to be 70% disassembled to change the pulley on the ZL1 super charger. Is this true?
The pulley looks to be pressed on , nice move GM, but there appears to be room to use a puller to remove it. I suppose the issue is getting the new pulley back on, since it needs to be pressed on. A little oil and a hillbilly press (a.k.a., hammer) won't work?
Tips appreciated!
Steve@HPE is offline   Reply With Quote
Old 07-07-2012, 09:28 PM   #2
Supercharged SS
Drives: 2010 Camaro
Tips appreciated!
I'm pretty sure you need a puller to remove the pulley. Go on the lingenfelter site. They make a hub you can put on after you take the stock pulley off which allows a quick pulley change possible. But you'll need to machine the blower.
Old 07-07-2012, 10:29 PM   #3
Steve@HPE
Drives: 2014 SS/RS
Got it Jamie, thanks
Old 07-08-2012, 05:30 PM   #4
Z_Rocks
Z_Rocks's Avatar
Drives: everyone crazy...
Tips appreciated!
Steve, did you buy a ZL1?
Z_Rocks is offline   Reply With Quote
Old 07-09-2012, 11:10 AM   #5
Sales @ ECS
Sales @ ECS's Avatar
Drives: 2011 CG 2SS
Yes this is basically the same setup as a CTS-V.. We remove the supercharger at the split between the S/C and the intercooler/heat exchanger. Then it gets pressed off, new pulley on, into the bridgeport for the 2 pin holes drilled/pressed-in, and then back onto the vehicle!
If you are uncomfortable performing the actual pulley swap, and the drilling, you can send us your front snout with parts (Or we can provide parts) to complete the installation. We do this all the time for the ZR1's, CTS-V's and the ZL1's.
Sales @ ECS is offline   Reply With Quote
Old 07-09-2012, 01:38 PM   #6
Ryne @ CMS
Ryne @ CMS's Avatar
Drives: 16 Camaro SS, 06 C6 Z06, 15 Sierra
that stock pulley is really on there too....
Ryne @ CMS is offline   Reply With Quote
Old 07-09-2012, 02:08 PM   #7
camslambam
Drives: 2010 SS, 06 SRT10 Ram
lolgm
camslambam is offline   Reply With Quote
Old 07-10-2012, 02:17 PM   #8
Sales @ ECS
Drives: 2011 CG 2SS
Oh it takes some pressure to get it off.. I'd say we've done 100+ of them on the V's and maybe 3-5 of the pulleys are somewhat salvageable after removal. Not like they would ever go back on, but they do get quite mangled to remove and there is not much of an edge to press it off to begin with.
Old 07-10-2012, 04:22 PM   #9
Steve@HPE
Drives: 2014 SS/RS
I did, but it's the wife's. If/when you're married you'll understand
Old 07-11-2012, 02:10 AM   #10
Z_Rocks
Z_Rocks's Avatar
That's why I'm not...
Congrats man. Leave the poor ZL1 alone. It's awesome as is!
Old 07-11-2012, 02:22 AM   #11
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
Wow. And all this time I've been saying "Simple Pulley Swap" for he ZL1.
Guess not so simple.
