Old 01-29-2013, 10:27 PM   #43
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: Longest things on Earth
Great job, looks like I just got me a winter project!!!
its a syn is offline   Reply With Quote
Old 01-30-2013, 01:03 AM   #44
Dissociation
Drives: Cyber Grey 2010 2LT RS Camaro
Do you find the brake light are any dimmer with this mod? Or is it pretty reflective to compensate for covering the partially up?
I seem to notice that there is not as much reflection on cars behind me, but it doesnt seem too much dimmer.
Dissociation is offline   Reply With Quote
Old 01-30-2013, 07:28 AM   #45
dragom
2G1FB1EV3A9121989
dragom's Avatar
Drives: Rally Yellow RS Coupe
anyone want to do a before and after shot
dragom is offline   Reply With Quote
Old 01-30-2013, 08:49 AM   #46
rking2000
rking2000's Avatar
Drives: 2011 Camaro 1lt r/s
Awesome DIY,and write-up! Liked it so much I copied the dimensions. Then I got to thinking a person could make a blind (block off the whole tail light),and cut what ever design they wanted.But I also want the rear end visible you know how some clowns are at running up on you at stop lights. I do have 1 question. Did you paint the blind on the outside? Side facing the lens? Great job. Thanks for sharing!
rking2000 is offline   Reply With Quote
Old 01-31-2013, 01:57 AM   #47
gotpball44
Boost Is Your Friend
gotpball44's Avatar
Drives: 2016 Hyper Blue 1SS Camaro
Send a message via AIM to gotpball44
Gonna try this, VERY NICE MOD!!! Was just thinking about coming up with a way to do this for cheap a few days ago. You just made my day lol.
gotpball44 is offline   Reply With Quote
Old 02-18-2013, 08:22 AM   #48
1969to2010
The Man in Black
1969to2010's Avatar
Drives: 1969 Camaro 2010 Camaro 1SS
great job and thnx for sharing this is on my long list , have afterburners now I like this look of these better
1969to2010 is offline   Reply With Quote
Old 03-23-2013, 09:31 PM   #49
Randyscamaro2010
Drives: Cammed
Thanks for the mod. I saw it today and did it today.
Randyscamaro2010 is offline   Reply With Quote
Old 03-23-2013, 09:55 PM   #50
FL1CK
Switchin' n Twitchin'
FL1CK's Avatar
Drives: 2011 Camaro
Originally Posted by colingordon View Post
Ok but they are the same if you guys were to take the time to look at e CCFL version they are exactly the same. If you think so tell me why?
Sent from my iPad using Tapatalk HD
1st reason, these are not lights glued onto the inside of the lens.
2nd reason, the depth effect is NOT the same, these are in the middle of the housing not against the lens. More like a concept look than adding a strip of light to the lense.
3rd reason,
I am not childish, you're just being a poopy head!
FL1CK is offline   Reply With Quote
Old 04-05-2013, 01:43 PM   #51
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
Did this yesterday and have to say that the instructions were pretty "spot on". Used the same cut out dimensions and lens cut marks and they fit perfectly. An easy way to line everything up is to shine a flashlight through the bulb hole. We also played around a little and drilled holes in the plate to see if we could get a deeper affect, but it didn't look right. The red lens is cut weird, kinda like a bunch of small prisms. That made the light from the drilled holes refract in different directions. Taped the holes with aluminum tape and reinstalled. Looks very cool. There's more than enough light shining around the block off to be easily seen. Driving around last night had me noticing everyone elses taillights. Mine has more light shining through than many other cars in OEM form. If you're that worried about the brightness, you can buy direct replacement LED taillight bulbs.
You really are only limited by your imagination, with this mod.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 04-25-2013, 03:20 AM   #52
BudMC77
BudMC77's Avatar
Drives: 2011 Camaro 1LT
Must say this is an amazing write up as well as mod it self. I can't wait to give this a try myself. I can't state how much I like this mod. For me, this is the type of mod I love, the ones where pure ingenuity comes out. Yes this is a cheap mod but a very professional looking and easy mod. If someone didn't know any better, they would think that someone shelled out 100s of dollars for this.
I did have one question on your project through. How did you come up with the half moon shape? Was it it completely free hand drawn or did you go by something or what? Is there anyway that you could post a measurement from the other side of the tab down to the bottom of the half moon? On the 1 inch side. I also agree on painting the outside face if the plate to better the look during the day as this will darken that area of the light while leaving the other side silver. This will allow the light to be reflected much better within the light and not minimizing loss of light output. Once again, great write up and very nice job. Thanks.
BudMC77 is offline   Reply With Quote
Old 04-25-2013, 10:54 AM   #53
bluemaro13
Drives: 2011 V6
Posting so I can find this again when I am ready for it next weekend. Thanks to the OP for the good details and write up!!!!!! I am going to try and mess with some designs when I do mine to see what the out come is like. I will post pics if they work well.
bluemaro13 is offline   Reply With Quote
Old 04-25-2013, 11:01 AM   #54
Monchy36
ZLT!!! COTW (8/5/13)
Monchy36's Avatar
Drives: 2011 IOM 1LT RS M6
Nice DIY! You just finish my idea!!! Thank you for this!!!
Monchy36 is offline   Reply With Quote
Old 04-25-2013, 04:26 PM   #55
rking2000
rking2000's Avatar
ok I'm stupid I guess, how do you
1. get the bezels off.
2.How in the hell do you get to the bols/nuts to remove the lights.
I already broke a tab on the one bezel,thenI thought I better ask for help!
Thanks
Old 04-25-2013, 04:32 PM   #56
Monchy36
Monchy36's Avatar
Thanks
http://m.youtube.com/#/watch?v=kphwN...%3DkphwNWklkRA I hope this help...
afterburner, afterburners, diy, lights, taillights
