Old 07-08-2012, 09:52 AM   #1
UNDsioux
Drives: Silver SS
Oil pressure issues
Just noticed that my oil pressure on my 4 gauge cluster is a 50 when I'm just driving regular. It shoots way up to maximum at 70 when I accelerate fast and when I stop it goes down to likr 20.
Is this an issue?
UNDsioux is offline   Reply With Quote
Old 07-08-2012, 09:54 AM   #2
nytrorcr
nytrorcr's Avatar
Drives: I.P.C. 2SS vert, 21 wheels
Location: Cookeville, TN but Just above Atlanta, GA for now
Who changed your oil last? Was it the proper grade?
2011 2SS Convertible A6
nytrorcr is offline   Reply With Quote
Old 07-08-2012, 10:02 AM   #3
UNDsioux
Drives: Silver SS
I took it to a nice car wash called Auto spa. I told them to do the best/most expensive. It was like 3 months ago maybe?
Old 07-08-2012, 10:21 AM   #4
UNDsioux
Drives: Silver SS
Should I not drive it? Help please
Old 07-08-2012, 10:41 AM   #5
two_wheel_mayhem
Would rather be riding
two_wheel_mayhem's Avatar
Drives: No car no more
My V6 does exactly the same thing. Is yours a V6?
And no it doesn't bother me. Things that would bother me would be excessively high or low at idle, or excessively low anytime.
50 at cruising 20 at idle is awesome, it's a tight little engine. Mine will peg the 70psi gauge when its cold and hardly getting on it. The 3.6 has a lot of moving parts, it requires one hell of an oil pump. They probably have the relief valve set pretty high.
I use Mobil 1 5w30 synthetic.
two_wheel_mayhem is offline   Reply With Quote
Old 07-08-2012, 10:42 AM   #6
UNDsioux
Drives: Silver SS
Yeah it's a 2012 v6
Old 07-08-2012, 11:11 AM   #7
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
That's like a recipe for "help me empty my wallet." Go in informed. Tell whoever is working on your car exactly what you want, like "it needs 6 quarts of Mobil 1 synthetic 5w-30 and a GM oil filter," etc.
It's not unusual to see very high oil pressure at cold start-up. As another poster said, the relief valve on the oil pump must be set for fairly high pressure. High oil pressure could cause leaks, but other than that, it probably wouldn't hurt anything.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 07-08-2012, 11:44 AM   #8
UNDsioux
Drives: Silver SS
It's not just at start up. It's whenever I accelerate. Not even when I accelerate hard. It's 100 degrees outside so the engine isn't cold and it happens even when I've been driving for 10+ min.
Old 07-08-2012, 12:47 PM   #9
JohnnyBfromPeoria
Have it checked. I'd first suspect the gauge. You could swap in another one to see if it reads differently. You could also find a way to temporarily rig up a mechanical gauge (the one you have now is electrical).
Is it leaking any oil? Probably not. That's why I suspect the gauge first.
John B.
Old 07-08-2012, 12:57 PM   #10
1BADLS3
1BADLS3's Avatar
Drives: Sold: 2011 2SS/RS
The sending units for GM oil gauges are always suspect. I've had problems with them in GM cars dating back to the early 1990's. One of my first cars was a 1990 Lumina that would peg the oil pressure gauge on startup and then it would bounce all over the place depending on how I accelerated. Replaced the sending unit and it was fine.
It's normal for oil pressure to be high on startup when the engine is cold. The oil moves slower when it's cold, so the pressure is way up. When the oil reaches temperature, it's easier to move through the engine, so the pressure should drop way down at idle, and then you'll see it surge slightly as you accelerate, as the pump runs faster in check with RPM.
Oil pressure is nice to know. If it's reading funny, rely on your senses and info you can readily tell about the car.
1. Is any oil leaking?
2. Is the oil level, color, and smell okay on the dipstick?
3. Are there any warning lights about oil?
4. Does the engine sound ok?
5. Does the oil temp gauge read within spec when the engine is at operating temperature?
If all those items are fine, I'd definitely suspect the oil press sending unit...
1BADLS3 is offline   Reply With Quote
Old 07-08-2012, 01:54 PM   #11
c5dreamer
Drives: Tacoma/2LTRS
Mine does the same...moves all over as I drive
c5dreamer is offline   Reply With Quote
Old 07-08-2012, 01:57 PM   #12
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Mine does the same. It moves when I Acclerate idel and so on. Isn't notice it till the other day
Proud owner of litho #179 Click Picture for Build Thread
Old 07-08-2012, 03:11 PM   #13
ICTsccaCamaro
ITCRNRS
ICTsccaCamaro's Avatar
Drives: 2014 Summit White 2SS/RS 1LE
Totally normal on v6 tons of threads on this all peg 70 on accel very normal for v6 at least
2018 ZL1 1LE on order, Summit White, PDR, NAV
SOLD: 2014 Summit White 1LE 2SS/RS, Recaros, NPP, NAV, KONI Yellow's, Elite Gen2 CC, ZL1 splash guards, ZL1 pedals, Exhaust Commander, GTO Clutch reservoir, Forgestar CF5V 19's on HoosierStone Tires, Previous Car: 2012 Black 2LT/RS, Fully 1LE swapped, Wichita Region SCCA #98
ICTsccaCamaro is offline   Reply With Quote
