Old 07-09-2012, 08:38 PM   #1
jshaf
Montani Semper Liberi
jshaf's Avatar
Drives: 2011 Black 2SS/RS w/ IOM stripes
Best Battery for high powered audio system?
was thinking of changing the battery to something a little more resilient next year to better handle the upgrades I plan next spring, any suggestions on brand or type? Model numbers? running 710w single amp 10" sub and getting new speakers down the road.
Stainless Works 1 7/8 Long Tude Headers, Stainless Works High Flow Cats, Stainless Works Retro Chambered Catback, Z/28 Air Intake, RDP Tuned, FR41 Chrome Rims, 1100W stereo, 35% Tint
jshaf is offline   Reply With Quote
Old 07-09-2012, 09:14 PM   #2
yotaman96
yotaman96's Avatar
Drives: 2010 Camaro SS, 2000 Trans Am WS6
Maybe an Optima yellow top?
2017 Krypton Green SS 1LE
Magnacharged 2000 Trans Am WS6 manual trans
2015 Ram Crew Cab Cummins
yotaman96 is offline   Reply With Quote
Old 07-09-2012, 09:15 PM   #3
grocerygetter
instigator
grocerygetter's Avatar
Kinetik
-John S.
Thanks to:
Tony@ dv8motoring
TCAudio in Benton AR
Old 07-10-2012, 12:42 AM   #4
NathanRobinson
NathanRobinson's Avatar
Drives: 2011 Camaro
You'll be fine on the stock battery. I'm running close to 1500 rms now with no problems, but if you really want a new battery get something reliable like a yellow top.
NathanRobinson is offline   Reply With Quote
Old 07-10-2012, 03:25 AM   #5
DraggnFrameGMC
DraggnFrameGMC's Avatar
Drives: 2011 Synergy Green Camaro LT
Optimas are horrible, quit using them years ago. Kinetik or we've been using a battery out of wheelchairs lately (if you plan on adding it as a secondary) and theyre cheap to. Theye a high amperage, high output battery. With that much wattage you really dont need another battery, even if you added a 4ch, you'd still be good on the stock battery. But if its time to change, you might as well upgrade.
DraggnFrameGMC is offline   Reply With Quote
Old 07-10-2012, 09:34 AM   #6
yotaman96
yotaman96's Avatar
I've had excellent experiences with Optima's.
Old 07-10-2012, 10:22 AM   #7
DraggnFrameGMC
We've had alot of issues with them. All warrantied issues, but issues none the less. Plus theyre not built for stereo upgrades. With the wattage JSHAF is running he should be fine, but if you get into anything 1500 watts and over the discharge/flow rate of an optima isnt enough to keep your amps fed. Theyre deep cycle and built for a slow discharge.
Old 07-10-2012, 06:49 PM   #8
jshaf
jshaf's Avatar
where do you get the kinetik? was thinking yellow top possibly. I have had my battery go dead twice last winter, going to try and tender it this winter and if it goes dead again I am replacing the damn thing, will keep kinetik in mind as well as yellow top. thanks guys!
Old 07-12-2012, 07:47 PM   #9
CWI
Helping Build America
CWI's Avatar
Drives: 2010 2SS/RS,LS3 2013 Duramax 3500HD
Yellow top is good for deep cycle use like draining to a low voltage before recharge. Red top is better for high current where you use a lot of amperage but keep it charged all the time without draining the voltage. I bought a red top at Autozone i 2008. It went bat 3 years later + 10 days. Autozone replaced it no questions asked, even though warranty was expired.
I have around 2800 wats on my system and haven't had any issues. Not even dimming lights with it LOUD for an hour. You will be fine in the 700 watt range with the stock battery. I'm waiting untill I detect a problem with the stock battery, which is over 3 years old now and still working fine. Then i will probably go with Kinetik for the higher amperage.
A big key is using the right size cable to supply power (and ground) to your amp. Too big is a lot better than too small. Too small creates resistance and heat that is not good for any part of the system including the power supply.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy shit, what a ride!"
CWI is offline   Reply With Quote
Old 07-12-2012, 07:53 PM   #10
ToddB
Drives: 2011 2SS Convertible Supercharged
I have 3 of these in my camaro. pushing 5000 watts also have a 275 amp DC power alternator. http://www.kinetikaudio.com/2009/default.asp
ToddB is offline   Reply With Quote
