Old 07-10-2012, 01:39 AM   #1
Basemaro
Drives: 2015 BLACK LFX M/T
Motor mounts, different mounts
So on my previous vehicles i've always installed some sort of engine mounts or tranny mounts. Tightens everything up and transfers the power to the ground better or more efficiently i should say.
Being this isnt a FWD vehicle what can i do besides the pfdat motor mounts to tighten up the feel of the car.
I'd like to tighten the motor up and the tranny a bit. Not sure if the pfdat mounts will even work with the v6 being that i've only seen them on the SS.
Basemaro is offline   Reply With Quote
Old 07-10-2012, 03:02 AM   #2
Lil' Nasty
[COTW 4/13/15]
Lil' Nasty's Avatar
Drives: Supercharged LLT
Bushings can defiantly help get you off the line especially in a manual.
Lil' Nasty is offline   Reply With Quote
Old 07-10-2012, 06:31 AM   #3
Apex Motorsports
Apex Motorsports's Avatar
Drives: 2000 Camaro SS
With these cars I would suggest starting in the back and working forward. Sub frame and differential and then go from there.
Old 07-12-2012, 04:01 PM   #4
Basemaro
Cool thats what i thought also but i want that neck snapping throttle response i had when the car was new. 3000 miles on it and its broken in nicely. You can feel the motor bounce a little when i hit the gas,before it was a tight instant go.
Old 07-12-2012, 07:16 PM   #5
SimpleGreen
Drives: 2013 1SS/1LE IOM
I shook a brand new 1LT at the dealer and could watch the engine jiggle a good bit on the mounts. They definitely have some built in slop. Granted that was done for comfort in mind first.
2016 Jeep Wrangler Willys 2DR
2013 Camaro SS/1LE SOLD 4/27/16
SimpleGreen is offline   Reply With Quote
Old 07-12-2012, 09:27 PM   #6
Basemaro
Ok so it seems like differential bushings arent all that needed for the v6 but if were to be done would be best while doing a gear swap.....which i want to do. 3.73's or 4.10's maybe.
What else can be done without having to start dropping things and getting a press.
Was searching a bit and found that the LFX models dont have posi!?? One wheel wonder?....
Old 07-14-2012, 07:50 PM   #7
coloeb
coloeb's Avatar
Drives: 2012 2LT/RS 6L50 automatic TF-3
The automatics don't have posi I think the manuals do.
Its better to burn out , than to fade away.
coloeb is offline   Reply With Quote
Old 07-15-2012, 12:20 AM   #8
menendez1293
Emerald Coast Camaros
menendez1293's Avatar
Drives: 2010 Camaro 2LT/RS M6
Correct. Manuals do autos don't
Proud owner of litho #179 Click Picture for Build Thread
