R1 Concepts
Old 07-10-2012, 01:34 PM   #1
Nitro Dave
Drives: 2010 RS SS Juiced!
Tach & TPS Wire Connections for V6
Hey guys I figured I would share this info. For those who are installing nitrous systems with a nitrous controller and need to know TPS and Tach signal connection points on the V6 camaro.
I installed a controller on the car to varify everything.
TPS- At throttle body connector. Most controllers will work of either rising or falling voltage.
Purple Wire = Rising Voltage
Green Wire = Falling Voltage
Tach signal- Passenger side, front ignition coil.
Its a flat 4 wire connector, 3rd wire from the left, (Pin C) Purple wire.
The Nitrous Outlet controller RPM setting should be on 00 for individual coil per cylinder.
Dave
Nitro Dave is offline   Reply With Quote
Old 07-10-2012, 01:38 PM   #2
h2oplay
Winners find a way
h2oplay's Avatar
Drives: 2010 2LT/RS M6
Dave,
Are you sure you're getting a good signal? I had to add a tach signal box to get it to work correctly, it also wouldn't work well for my shift light until I added the box....
Injen LT | Magnaflows | BBK LT & HFC | Mace 25mm & P Spacer |Richmond 3.73 | Trifecta Tune
RX Catch Can & Breather | Pedders Inserts | IDEALG Clutch MC & GTO Reservoir | JDP Colorshift Halos | Drake Bowtie Delete |
h2oplay is offline   Reply With Quote
Old 07-10-2012, 01:41 PM   #3
Nitro Dave
I had a nice clean signal. I installed a controller, Played with the rpm settings and varified it was not erratic. The rpm read out on my controller matched the cars tach the entire time.
If you are using a T-tap connector that could be your problem. Best way to do it is tap into the wire and soldier the connection.
Dave
Old 07-13-2012, 02:06 PM   #4
h2oplay
Winners find a way
h2oplay's Avatar
well, I'm soldered up now with my add on box, perhaps that was my issue initially.... I'm using the nytrex controller which was a PITA to setup but has a lot of features.
Old 07-19-2012, 05:30 PM   #5
Nitro Dave
Sounds good. Have you ran your car on the spray yet?
Dave
Old 01-27-2014, 08:45 PM   #6
manu_b
Drives: 2010 Camaro inferno orange 2LT RS
Dave
Hello Dave: is it required to use passenger side first ignition coil. I tried on the driver side first cylinder and my summit racing rpm switch did not work.
manu_b is offline   Reply With Quote
Old 01-28-2014, 10:15 AM   #7
MagnumForceGB
MagnumForceGB's Avatar
Drives: Fastest 2010 Camaro V6
Good information, thanks. Will help me out when I get a progressive controller.
Camaro V6 = 11.268 @ 120.11
MagnumForceGB is offline   Reply With Quote
Old 01-28-2014, 05:12 PM   #8
manu_b
Tried the passenger from coil did not work. Hopefully my switch is faulty
Old 01-30-2014, 09:10 AM   #9
ksspeed
ksspeed's Avatar
Drives: 2013, Camaro 2LS (BRM)
Im running an msd window switch, i used the driver side first coil, if im not mistaken, and your box is looking at a "single cylinder" set up, it shouldnt matter which coil you tap on to, as long as it is the purple wire on one of the coil wires of the four wire connector. I could be wrong, but thats been my experiance, so far.
ksspeed is offline   Reply With Quote
Old 01-30-2014, 09:02 PM   #10
manu_b
Stupid me,I bought cheap summit rpm switch and now bought MSD GMR but still nothing worked. Only problem is I can't check what is faulty.
Old 01-31-2014, 09:11 AM   #11
IneedAZ
IneedAZ's Avatar
Drives: 2017 ZL1 A10 & 2012 2LT RS
Make sure you have the MSD set to 1cylinder not 6cylinder.
2012: e85, 80mm TBody, CAI w/scoop, Solo HFC, ZL1 FP, Magnaflow TruX, Dynomax VT, Elite catch can, HP Tune, Throttle Contoller, BMR; Springs, Sways, Trailing Arms, Toe Ends, & Safety Loop, Koni str.t, Pioneer Z150bh, Phoenix Gold Sub, Hertz speakers & 5ch Amp, 1LE rear with 3.91 gears, BMR bushings, Baer Decela Rotors, Goodridge brake lines, Brembo(GM) 4 piston calipers, Hawk Ceramic pads, ported intake, Circle D 5c. 12.3@112 old setup
2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17
IneedAZ is online now   Reply With Quote
Old 01-31-2014, 11:42 AM   #12
manu_b
Its not msd switch that might be the issue. Its a summit racing rpm switch
Old 01-31-2014, 04:54 PM   #13
IneedAZ
IneedAZ's Avatar
I just reread what u wrote. When I replied I thought bought the MSD switch after realizing the Summit doesn't work, missed the GMR part of your sentence. Yes, Summit switch wont work as it only goes down to 6 cyl. You can return the GMR too if u want..u need the MSD switch itself which does go down to 1 cylinder. I did the same as others buying the cheaper Summit thinking 6cyl is all we needed, but no, we need 1cyl option.
Old 07-25-2015, 09:04 PM   #14
IneedAZ
IneedAZ's Avatar
No the lfx I didn't find any of the wires at the throttle body to work for tps, but the blue wire at the pedal works. I posted this so when people do searches they will know how to make it work. I figured it out by testing all the wires at throttle body and pedal.
