Old 07-10-2012, 07:17 PM   #1
Camero5
Hide! My wife's coming!
Camero5's Avatar
Drives: 2013 Chevrolet Camaro ZL1
2012 Camaro SS L99 Dyno Tune Results
Finaly got my car to where i want it . Thanks to ADM Performance, it drives like a beast now.
ADM Performance CAI w/ Race Scoop
1 7/8 Stainless Works Headers w/ HF Cats.
Magnaflow Comp. Exhaust 16583
Ported Throttle Body
Swaped gears to 3.45 from an LS3
Custom Tune by ADM
RWHP 366 Torque 370
I think for an L99 that is pretty good considering the heat and humidity today. Next will beLS3 conv and cams . Going to knock out suspension work in a few days.
Camero5 is offline   Reply With Quote
Old 07-10-2012, 07:19 PM   #2
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Sounds like how I did last yr same set up except I have borla atak exhaust, and of course Andy and Ben are awesome at adm welcome to the brotherhood
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 07-10-2012, 07:19 PM   #3
djxrated81
djxrated81's Avatar
Drives: 2011 camaro SS/RS
What kinda of dyno?
2011 2SS/RS Airaid cai, ARH HF cats X pipe, SLP LM1, 160stat,RX Catch can, Tuned @ Tune Time Performance, side marker black outs, decepticon bowtie emblems, stealth turn sig. bulbs,Hyper White DTRL Painted GFX, Havoc Spoiler
[IMG][SIGPIC]
djxrated81 is offline   Reply With Quote
Old 07-10-2012, 07:20 PM   #4
Camero5
Camero5's Avatar
Originally Posted by djxrated81 View Post
What kinda of dyno?
DynoJet
Old 07-10-2012, 07:21 PM   #5
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
Drives: 2011 1SS/RS VR/BLK A6
Not bad but, why the gear swap to LS3 gears?
Originally Posted by HufferSS View Post
Fast cars have rubber on the quarter panels...you sissies need to knock it off.
daveagogo1 is offline   Reply With Quote
Old 07-10-2012, 07:23 PM   #6
Camero5
Camero5's Avatar
Thanks
I thought about doing the borla atak but wanted something quieter.
Got to get used to the firm shifts at WOT
Old 07-10-2012, 07:24 PM   #7
sasquash1984
502 RWHP N/A
Drives: The yeti
Does well at shift points and higher mph in a trap on a track
Old 07-10-2012, 07:25 PM   #8
sasquash1984
502 RWHP N/A
Drives: The yeti
Originally Posted by Camero5 View Post
Thanks
Did he tell u to heat cycle ur gears before letting loose
Old 07-10-2012, 07:26 PM   #9
daveagogo1
TRI COUNTY TAMPA
daveagogo1's Avatar
And less power to ground on the bottom end. Just wondering what the thought process was at this stage of the build. Get gears out of the way?
Old 07-10-2012, 07:26 PM   #10
Camero5
Camero5's Avatar
Old 07-10-2012, 07:28 PM   #11
Camero5
Camero5's Avatar
No, should I if i swapped with an lS3 that is broken in?
Old 07-10-2012, 07:28 PM   #12
sasquash1984
502 RWHP N/A
Drives: The yeti
U might look into their transmission cooler works wonders if u wish to run ur tranny hard
Old 07-10-2012, 07:28 PM   #13
sasquash1984
502 RWHP N/A
Drives: The yeti
No ur good
Old 07-10-2012, 07:33 PM   #14
Camero5
Camero5's Avatar
Ill be doing more upgrades soon but the reason i did it was because i got a real good deal to do it now
