BeckyD @ James Martin Chevy
Old 07-10-2012, 08:28 PM   #1
EdwardTheGreat
Drives: 2010 Chevy Camaro 2LT
Bumble Bee don't wanna crank
If I may request a little assistance from the Camaro gawds please!
Go to get in my car and double click the locks to initiate a remote start and the lights flash and it makes a single click like always but the car will not turn over. Unlock door and get inside and put key in ignition and turn the key to attempt to start. All the the dash lights and radio and a/c are on but car wont turnover until i try it multiple times. Cranks up finally and idles fine but engine light is on.
Noticed not too long ago the a/c blows hard the soft then hard then soft and radio light would dim and get bright...dim and get bright. None of these things happening at the sametime. It is 1400 miles outta warranty and I am sure GM isn't gonna help me out either.
Ideas? Anything is appreciated!
EdwardTheGreat is offline   Reply With Quote
Old 07-11-2012, 12:08 AM   #2
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Make sure your battery connections are clean and on tight. Your battery might be dying too. Hook up a multimeter and check the voltage. It should be 12.6 VDC.
Do you have any aftermarket electronics (sound system, etc.)? Make sure all grounds and electrical connections are tight and clean.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
LimaCharlie is offline   Reply With Quote
Old 07-11-2012, 09:17 AM   #3
EdwardTheGreat
That will be the first thing I try if it will ever quit frackin raining. Thanks.
As soon as stuff lime this happens I immediately figure/expect the worst.
Old 07-11-2012, 09:23 AM   #4
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Send a message via AIM to jeffny09 Send a message via Yahoo to jeffny09
See what the code is for the.engine light is. Hook up a scanner check that and heck the battery
top 10 reason why real men drive stick.
10. A manual transmission is the ultimate in control
9. You can use automotive jargon and not sound like a total tool
8. You can't spell "manual" without "man"
7. Manual transmissions prove you can do more than one thing at a time
6. You can't drift in an auto
5. You can't pull fancy moves in an automatic
4. You get better fuel economy with a stick
3. You値l never look like a chump if you can drive stick
2. Manual transmission cars are faster
1. Women like a guy who is good with his hands.
jeffny09 is offline   Reply With Quote
Old 07-11-2012, 01:11 PM   #5
EdwardTheGreat
Roger that but i dont have a scanner. Will definately check battery asap.
Old 07-11-2012, 05:23 PM   #6
EdwardTheGreat
Battery is good. Seems to only be not turning over after a fail attempt to start with remote start fob.
Old 07-11-2012, 05:28 PM   #7
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Do u have an autozone near u?
Are your brake lights working? Have soneone look at them as u hit the brakes...
Old 07-11-2012, 07:00 PM   #8
EdwardTheGreat
Running or not running?
Have an autozone not to far away.
Old 07-11-2012, 07:17 PM   #9
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
While not running. If the brake lights dont turn on when u step on the brakes and start the car..then u have a defective brake switch...easy to.change...try it a couple imes
Old 07-11-2012, 07:18 PM   #10
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
But being that ur engine light is on...it needs to be scanned autozone will do it for free
Old 07-11-2012, 09:18 PM   #11
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Update...
Old 07-12-2012, 09:50 AM   #12
EdwardTheGreat
Update...
Sorry. Tried the brake and all is working fine. Will take it to autozone this weekend and get the code deciphered. Only time it wont turn over is when/after i use the remote start. Guessing that is my issue but will see soon enough i guess. Calling warranty manager at a local dealership and hopefully they will foot the bill.
Old 07-12-2012, 03:05 PM   #13
Chevrolet Customer Svc
Drives: GM Vehicles
I apologize for the frustrations you may be experiencing with this issue. Have you been able to get the vehicle over to your local dealership yet? Please let us know the outcome!
Brandon
Chevrolet Customer Service
Old 07-12-2012, 05:05 PM   #14
jeffny09
jeffny09's Avatar
Drives: 2010 camaro
Hey man..not sure if u have onstar...but if u do u can call them and have them read the code for u bro...totally forgot about that...reason i said abiut the brake switch cuz my friend had the same problem..atleast thats ruled oyt
