Cold Air Inductions
Old 07-11-2012, 08:40 PM   #15
Deke736
COTW 12/3/12
Deke736's Avatar
Drives: 2012 Ashen Gray ZL1
That really sucks! I hope they get it all straightened out properly for you.
Deke736 is offline   Reply With Quote
Old 07-11-2012, 08:40 PM   #16
04ssSilverado
04ssSilverado's Avatar
Drives: above `12 zl1 #780
Damn that blows & sucks at the same time. Hope they get it straightened out & it was just a bunch of flukes at the same time. But I am definitely alittle nervous now. The oil pump went out on my SS with 2400 miles, but I thought that was a fluke also.not.
04ssSilverado is offline   Reply With Quote
Old 07-11-2012, 08:41 PM   #17
Flavorwrench
Flavorwrench's Avatar
Drives: 2012 ZL1 & 67 RS-SS TwinTurbo
Chevy will make it right. I'm actually impressed with the clean shop and how fast they are on it for you. Don't sweat the clutch, that's really nothing. Your car has character, it told you early on its not right and needs you to fix a couple of things. Stay positive, no matter how it looks now, it will always be a ZL1!
Flavorwrench is offline   Reply With Quote
Old 07-11-2012, 08:45 PM   #18
kush396
Drives: chevy
Originally Posted by CAM ZL1 View Post
I told the service manager several times to look the exhaust over and the best I have heard so far was that they are going to try to clean it with steel wool. I'm not happy with that sort of response to what I still think qualifies as "New"
Dude i feel for u , i would feel the same way , and all i can say is i hope everything gets fixed to your expectations and u are happy ,,,,,,maybe demand a 2013
kush396 is offline   Reply With Quote
Old 07-11-2012, 08:47 PM   #19
UCANTCME
1st ZL1 in Rochester, NY
UCANTCME's Avatar
Drives: 2012 ZL1 #480
Sorry to hear your situation. Unfortunately, getting an EXACT replacement MY 12 probably won't happen. I wouldn't be very happy either. I hope GM corrects your problem. Good luck.
UCANTCME is offline   Reply With Quote
Old 07-11-2012, 08:56 PM   #20
sasquash1984
502 RWHP N/A
sasquash1984's Avatar
Drives: The yeti
Dealerships know how to take apart cars......jk I had too, sorry bout the problems hopefully u get back on the road enjoying ur new ride
factory motor factory trans, Gpi ss4 cam stock heads ported and milled, full exhaust, circle d 5c 4000 triple disk, 3:91 rear end with posi mod, cai, bmr derlin rear diff bushins, bmr derlin cradle bushins, bmr trailing arms, toe rods with bushings, and bmr anti extreme sway bar. Weld rt-s 17x5 fronts and 17X10 rears on mickey thompson et street r's
sasquash1984 is offline   Reply With Quote
Old 07-11-2012, 08:58 PM   #21
Rangore
Rangore's Avatar
Drives: 2012 Camaro 2SS 45th Anniversary Ed
Ouch!!
2012 Camaro 2SS 45th Anniversary Edition - No longer owned: 2010 Camaro 2LT, 1993 Camaro Z-28
Rangore is offline   Reply With Quote
Old 07-11-2012, 09:01 PM   #22
CAM ZL1
CAM ZL1
CAM ZL1's Avatar
Drives: 2012 Chevrolet Camaro ZL1
I am very interested and the service tech working on the car would be interested as well to know if that wiring harness is intentionally placed in the location mine was or if it really was a fluke. So if any ZL1 owners feel like getting underneath their car, please report back.
The service technician that's working on my ZL1 seems to be going the extra mile in getting this car back to "new". My trust in production GM cars; however, has taken a pretty big hit unfortunately. In the brief chat I had with customer service, I was offered a year's worth of tire rotations and oil changes on a vehicle whose tires cannot be rotated and oil that lasts the better part of an entire year.
CAM ZL1 is offline   Reply With Quote
Old 07-11-2012, 09:04 PM   #23
klatterblast
klatterblast's Avatar
Drives: 2010 camaro 2ssrs blk.
I would definatly let them keep it , they would have to replace too much to be like new again. I thought Chevy had the love it or leave it guarantee. Order a 2013 ZL1.
T-BONES BLACK 2SSRS TEAM L99
CAI w/ADM scoop,Magnacharged 3.8 pulley,L92 ported heads,ss valves,patriot springs,yella terra rockers,Comp cam,L99 to LS3 conv.ATI super damper,Taylor plug wires,NGK plugs,ARH 1 7/8 lt headers w/Borla stingers,Elite oil catch can,trans cooler,Jannetty built Richmond 4.11 rear end,Spohn trailing arms,front Racing Brake rotors,Hawk hps pads,BMR end links,AACstyle lighting. Thanks to Shane & crew for engine work at Thunder Racing & tuner Jeoff at EPS. 501rwhp-463rwtq ++
klatterblast is offline   Reply With Quote
Old 07-11-2012, 09:05 PM   #24
72MachOne99GT
72MachOne99GT's Avatar
Drives: 1972 Mach 1, 1999 GT
At least there is a little humor in the night.
2013 GT500- Grabber Blue/stripe delete, Base, Recaros,
1999 GT- Atlantic Blue, gears, exhaust, tires 13.6@100
1972 Mach 1- Med Lime Green Metallic, 351-4V, auto,
...if you want to compare performance numbers, well, the GT500 retains it's title of the highest hp, worst performing car in the world.
72MachOne99GT is offline   Reply With Quote
Old 07-11-2012, 09:07 PM   #25
james347
Drives: 2006 Crownline
Thanks for posting all of this information. I do not have a ZL1 but am very concerned about this. I would also forward this thread, and photos, to the appropriate GM contacts.
Also, I believe there is a GM Customer Service rep(s) that sometimes monitor these threads, you should be able to search/find them and also forward them some information. The more you get this out, the more likely you will get the issue corrected to your satisfaction.
I hope this gets resolved so you are fully satisfied with the car, as it should have been from day 1.
james347 is offline   Reply With Quote
Old 07-11-2012, 09:10 PM   #26
rpepka
rpepka's Avatar
Drives: 2013 ZL1 # 2195
My first 2010 2SS was very slow, many L99's were having the same problem. The V6's were going faster then the V-8's. I took it to the dealer 4 times and they kept saying nothing was wrong with it. I had another on order coming in a month so instead of fighting it I would sell it. Later on we all found out it was a GM defect which required a fuse pull to reset the computer for premium gas. I picked my 2nd 2010 a month later and on the 4 hour drive home the power steering pump blew up! Sprayed fluid all over!
So, I understand how you feel. SORRY!
rpepka is offline   Reply With Quote
Old 07-11-2012, 09:11 PM   #27
BrazenBeast
ZL1 #1745
BrazenBeast's Avatar
Drives: 2006 Pontiac GTO \ 2012 ZL1
The oil problem looks like rear main seal to me. I know they are tricky to replace without having a leak. They have a very tight tolerance. The wiring issue is interesting and something i'm sure people will be checking now. If it is widespread I wouldn't be surprised if a tsb gets sent out on it. Good luck.
2012 zl1 Black #1745 Black Wheels ECF Suede 6 spd
BrazenBeast is offline   Reply With Quote
Old 07-11-2012, 09:16 PM   #28
RULK
RULK's Avatar
Drives: 2012 Camaro ZL1 Victory Red M6
Oh man, that sucks man....I'm actually concerned about my car, it #1567 just a few cars older than yours. I think they were built the same week. I'm still under 1500 so I'm taking it easy just wondering if I'm going to run into the same issue :(.
RULK is offline   Reply With Quote
2012, issue, oil leak, pcv, pos, problem, zl1
