Solo Performance
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Sponsors Classifieds Marketplace > Transmission / Driveline
Old 04-28-2013, 07:05 PM   #43
GVA 45TH 2SS
KNGTFALL
GVA 45TH 2SS's Avatar
Drives: 2012 2SS 45th edition
Originally Posted by Klepton View Post
Use Coupon Code FREESHIPPING for FREE GROUND SHIPPING TO THE LOWER 48!
GVA 45TH 2SS is offline   Reply With Quote
Old 04-29-2013, 10:24 AM   #44
JDP Sales
JDP Sales's Avatar
Drives: Chevys at the limit
Feel free to call, PM or email me anytime with questions!
Best regards,
Tyler
888-308-6007
Old 04-30-2013, 09:23 PM   #45
Klepton
Klepton's Avatar
Drives: 2011 2SS/RS, LS3, SW w/ IOM package
I finally got around to completing this mod. However, it was a pain in the ass! I had such a hard time taking the clamp off the stock brake/clutch line on the firewall side because I could not reach in there with my right hand and my injured left shoulder doesn't have its complete range of motion back to allow me to do it with my left hand. Therefore, I ended up bending the bracket provided with this kit on the clutch reservoir so that it was close enough to attach the stock brake/clutch line to it. Another problem I had was with the small clamp that is provided with the plug in this kit. It was way too small and I couldn't make it go over the tip of the stock brake/clutch reservoir nipple. I ended up having to purchase a bigger clamp from Auto Zone. It was slightly bigger than it needed to be, but small enough to prevent the plug from coming out.
This allows the usage of the stock brake/clutch line, which is what I wanted all along. Therefore, you don't have to go through the hassle of replacing the stock line!
Last edited by Klepton; 01-24-2014 at 01:58 AM. Reason: Updated picture links since their location moved
Klepton is offline   Reply With Quote
Old 05-01-2013, 10:39 AM   #46
JDP Sales
JDP Sales's Avatar
Glad you got it in! That clamp on the firewall can be a real PITA! We recommend a long set of needle nose pliers, preferably with a small bend in them like so:
This will make short work of that clamp.
As for the cap clamp, it is a bit small, but if you open it up using 2 sets of pliers, it will provide a very good hold.
Feel free to call, Pm or email me anytime with questions.
Best regards,
Tyler
888-308-6007
Old 05-08-2013, 09:14 AM   #47
hcoll003
Proven Wicked Suspension
hcoll003's Avatar
Drives: 2010 Camaro 2SS/RS
For those who can't seem to use the small clamp that was provided, I used a zip-tie and turned it towards the bottom so you can't see the little square receiver of the zip-tie. I tightened the crap out of it and I cut the excess. It blends in well because it's black.
hcoll003 is offline   Reply With Quote
Old 05-08-2013, 01:14 PM   #48
1hotchevy
Scottish Knight
1hotchevy's Avatar
Drives: RS/2SS 6 speed manual
ERROR
i keep getting this message:
403 FORBIDDEN!
Why, hello xxxx.xxxx.xxxx
You do not have permission to access this section of our website.
It's kind of a security thing that we don't allow.</B>
This error is most likely due to folder structure abuse by use of your IP address or because
you are a naughty bot that is known to cause havoc.
If you believe you should be able to access this section please contact the
creator or the site current administrator.
1hotchevy is offline   Reply With Quote
Old 05-08-2013, 01:37 PM   #49
JDP Sales
JDP Sales's Avatar
I apologize for the inconvenience.. Our Website is currently down. If you have questions, need pricing or wish to order, feel free to give me a call toll-free at 888-308-6007 and I can assist you over the phone.
Best regards,
Tyler
888-308-6007
Old 05-08-2013, 05:57 PM   #50
BAWLZ SS
BAWLZ SS's Avatar
Drives: '10 Camaro LS3 2SS/RS, 1968 Nova
Just ordered the Stage 2. Cant wait to install it!!!!
Performance- Kooks Headers w/HF cats, ZL1 Corsa exhaust, VMax, CAI Inc. CAI, MGW shifter, RX CC Suspension - KW V3 Coilovers/ Full PFADT & BMR suspension Appearance - ZL1 Fascia/Sides/ Diffuser, AAC Afterburners, RK Sport 3pc Spoiler, SLP Black out Kit
BAWLZ SS is offline   Reply With Quote
Old 05-08-2013, 09:35 PM   #51
fldrummer
"Black Ace"
fldrummer's Avatar
Drives: Supercharged 2010 SS, 2016 Golf R
How easy was it to bend the bracket and what did you use? Just a couple pairs of pliers or did you need a vice? This sounds like the approach I would take. I tried reaching for that firewall end clamp and it does not look like something I'd want to pull a muscle dealing with.
2010 2SS/RS M6 "Black Ace" - Delivered 6/4/2009
Mods: Forged 416 LS3, Maggie TVS 2300 SC (~11 psi), custom cam (232/247, .630/.630, 118 LSA), 90-lb. injectors, ZL1 fuel pump & ADM controller, Alky Control meth kit, Monster LT1-SC twin-disk clutch, ZL1 drivetrain conversion w/ DSS 1000-HP axles & 1-pc. driveshaft, CAI Inc. intake w/ ADM scoop, XS Power full exhaust (1 7/8" LT headers with 3" off-road pipes), VMAX CNC-ported TB, LSR adjustable sway bars, LPE rear end-links, BMR 1" drop, BMR polyurethane bushings; UMI trailing arms & toe rods. Built & tuned by Kraftworks. 755 rwhp/708 rwtq
fldrummer is offline   Reply With Quote
Old 05-08-2013, 09:42 PM   #52
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Drives: 2012 SS/RS LS3
You don't need to bend the bracket. I installed mine just fine. I used a pair of pliers to reach the clamp at the fire wall. The best thing for working on cars is a steady hand and patience.
CHMSC is offline   Reply With Quote
Old 05-08-2013, 09:45 PM   #53
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Just a few weeks after I installed mine. As you can tell no more dirty brake fluid and no more clutch problems, I would also suggest ideal garage master cylinder and tick high flow clutch line with this kit. Works great, thank you JDP!!
Old 05-08-2013, 10:47 PM   #54
fldrummer
"Black Ace"
fldrummer's Avatar
Yeah--2 things I don't possess much of, hence the reasoning for my question and why I don't work on cars much (that, plus my back and hands are too valuable to me to injure).
Old 05-08-2013, 10:49 PM   #55
CHMSC
ROAD COURSE JUNKIE
CHMSC's Avatar
Lol ya I am sure you could bend it if needed. Would be easiest with a vise.
Old 05-09-2013, 02:17 AM   #56
Klepton
Klepton's Avatar
The bracket is easy to bend, being that it is not too thick. I didn't use anything but my hands. Once the bracket (along with the new clutch reservoir) are attached and screwed in, I simply bent the bracket towards the firewall as much as possible (until the cap of the new reservoir touched the side of the stock brake reservoir). It doesn't take an extreme amount of force to bend it with your hands.
Correct, you don't NEED to bend the bracket. I did so mainly because with my left shoulder injury I wasn't able to get to the firewall clamp on the stock clutch line. However, it turned out to be what I wanted in the first place...which is to use the stock clutch line.
