Old 07-13-2012, 05:50 PM   #1
camaro2rs
camaro2rs's Avatar
Drives: camaro
Just ordered a FARK harness. WHICH AMP?
hey guys i got the fark harness now i need a good amp any suggestions? i want one that is easy to install and sounds good
thanks for the help
camaro2rs is offline   Reply With Quote
Old 07-13-2012, 06:21 PM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Depends: If your goal is to only power the front and rear speakers, then I would recommend the amp that I have been running, which is the JL Audio XD400/4. Fits right into the stock BA amp location.
I cannot speak for any 5-channel amps though, but I'm sure somebody can recommend other amps.
Old 07-13-2012, 06:23 PM   #3
camaro2rs
camaro2rs's Avatar
Drives: camaro
i would like to power all my speakers but i plan on adding a bass
Old 07-13-2012, 06:37 PM   #4
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
If you will be adding a subwoofer later on down the road, then you may benefit more from a 5-channel amp.
I have 2 seperate amps: one for the front and rear speakers and another amp for the sub
Old 07-13-2012, 08:06 PM   #5
camaro2rs
camaro2rs's Avatar
Drives: camaro
dam i ordered the convertible harness
Old 07-13-2012, 08:35 PM   #6
Storm T
Can't slow down
Drives: 2013 SS Dusk Edition (Insain Bolt)
I'm running the JLAudio 900/5 and it's awesome. And while they were going to put the new amp in the stock location I had them mount it under the deck. If I ever want to change settings it'll be a little easier. I think I have it tuned pretty good now after doing it myself. Great great amp but pretty expensive. It is a bit much for the factory speakers but you don't have to crank it up all the way. I have some really nice new speakers up front and you might want to add them later.
Storm T is offline   Reply With Quote
Old 07-14-2012, 01:21 PM   #7
murdered
Drives: 2012 2SS 45th Ann. Edition
Storm T, so the 900/5 will fit in the stock location?
2012 2SS 45th Anniversary Edition
murdered is offline   Reply With Quote
Old 07-14-2012, 01:54 PM   #8
CrutchfieldBrooke
CrutchfieldBrooke's Avatar
Drives: 2010 Camaro, 1968 Camaro
I too was going to suggest the JL 900/5 amp if you need a 5-channel. Compact, efficient, clean, and powerful!
CrutchfieldBrooke is offline   Reply With Quote
Old 07-14-2012, 02:04 PM   #9
camaro2rs
camaro2rs's Avatar
Drives: camaro
soo it mounts in the stock location no problem? where can i order? and i need a farkharness to make it plug and play right? also any other amps that are not that much $$$ the jl amp is like 800
Old 07-14-2012, 03:04 PM   #10
Storm T
Can't slow down
900/5
It's only a tiny bit bigger. They said it would be no problem. They were actually set to put it there but I wanted it to show a tiny bit so I had them put it under the deck. Though you can't see it unless you're looking.
Yes, they said they had put the same amp in other Camaros.
I knew you were smart!
You can get them from Brooke at a better price I think or you can get them directly from JLAudio's website. You can also find them on Ebay also for lots cheaper. I wouldn't recommend it though 'cuz of the warranty thing.
Old 07-14-2012, 03:40 PM   #11
Iwantone2
Iwantone2's Avatar
Drives: CGM 1SS RS
...and i need a farkharness to make it plug and play right? also any other amps that are not that much $$$ the jl amp is like 800
Yes, the FARK harness will make it plug and play, IF you have the Boston Acoustics system.
As far as where to order or buy, I would recommend you go to your local audio shops (that are authorized dealers, of course) to see what price they are offering. Like the XD400 retails for $400, but I got it at half that price at a "local" audio shop that is JL authorized.
Old 07-14-2012, 03:43 PM   #12
camaro2rs
camaro2rs's Avatar
Drives: camaro
is the xd400 a 5 channel amp? and can you order the fark harnesses yet all i see is for the vert and thats what i ordered but i dont think it will work
Old 07-14-2012, 04:17 PM   #13
CrutchfieldBrooke
Thanks Storm! Yes, we do carry both on our site. The XD400 is a 4-channel and would be a great choice if you only want to add an amp for your regular speakers now, and then add a mono amp later for a sub.
Old 07-14-2012, 06:49 PM   #14
Storm T
Can't slow down
Sure thing.
