| Tuning / Diagnostics -- engine and transmission Tune and diagnostics for engines and auto transmission. |
Thread Tools |
![]() Drives: '12 2SS/RS, '13 Vette, '13 Wrangler Join Date: May 2012
S mode tuned into 2LS by GM?
As the title says do yall think it is possible for me to take my car to the dealer and have them put the stock tune from say a 2LT so that I have S mode? I want this so that when I tune my car for my supercharger I can have them aggresively tune S mode and leave D mode a little less aggressive. I am not very good with tuning things so I am not sure this will even work.
2012 Camaro Ashen Grey Metallic 2SS/RS "Timberwolf". 348rwhp/370rwtq SAE corrected. Resonator and muffler delete with a magnaflow resonator added, RX oil catch can and oil breather, CAI inc intake, tuned.
2013 Corvette Torch Red LS3. 378rwhp/375rwtq SAE corrected, tuned. ROCK CHALK JAYHAWK GO KU! |
![]() ![]() Drives: 2011 Summit White 2LS Join Date: Jun 2011
We don't have S mode?
The 2012 2LS doesn't. For some reason they took it out. That is why I think that it could be tuned back in. All it would take is the stock tune from a 2LT....I think.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 CGM Camaro LS A6 Join Date: Jan 2011
Nope, they won't do it.
Current Mods:
Vararam | Borla ProXS Custom Axle-Back | Mace 25mm Insulator | MACE Ported Intake Manifold | And a few other things ![]() Click here to visit my Build Thread! |
Yeah I called today and both places I called told me that I would have to get approval from the service manager to have it done and would have to get approval from GM regional after that to have it maintain under warranty. I think I am going to pursue it. I see not reason why it would hurt anything. I mean if they did it for the 2010 and 2011 and they have it on every other model of 2012 why can't they do it for mine? Ill let you know what I find out.
#6 |
The reason it doesn't have it is for them to be able to achieve the mpg that they advertise. Same reason you don't have the gear ratio a 1lt has. You could probably get it done but under warranty who knows. Good luck though
Current Mods:
#7 |
Right but what they should have done is the MPG tune into the "D" and then havbe an "S" mode. I just dont understand why they did that.
#8 |
I don't think its possible to program d and s independently of each other for a lot of things. I could be wrong but that could be it
Current Mods:
#9 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
If I'm not mistaken the LS tranny has different gearing ratios compared to the LT which is why it doesn't have it.
#10 |
No the only difference is the gears in the differential are 2.92 instead of 3.23.
#11 |
I will probably just wait until I get my new gears and then get the Trans and engine tuned. Then retune it for my supercharger. I was mostly just curious if it was possible.
#12 |
Banned
I have a 2011 2LT and it can be tuned for each mode. I have D set a little bit more aggressive than stock and S mode tuned to be a True Sport mode. From what I was told before the tune is each mode uses its own tables.
#13 |
Yes, what your speaking about is shift firmness and torque management which can be tuned independently of mode. But the op is suggesting that gm should have put an mpg tune into d and a sport mode in s. That can't be done. The tune applies to both modes and you can't have one tune for d and another for s. I've asked Vince about it already and he said he couldn't do it because the code didn't allow for it. This might have changed since I asked but that's what he responded to me
Current Mods:
#14 |
Big Time Newb
Drives: C63 Join Date: Jun 2012
The only thing that changes between modes is shift points (MPH/RPM) and shift pressure.
Torque management, engine criteria (AF ratios, timing, etc) are all the same. OP, you are totally wasting your time (and money?) by doing this, also, they may not even be able to do it, they are different operating systems and they are actually totally different ECUs. 10-11 have Bosch ECUs while the 12's do not. Totally different code, OS, etc. |
#15 |
I understand that the 2011 and 2012 have different ECUs. What I am saying is take the tune from a 2012 2lt and put it in a 2012 2ls giving it an s mode.
#16 | |
Big Time Newb
![]() With that said, you will probably need a tuner to do this for you, not the dealer. |
#17 |
Yeah. Reason I was thinking the dealer is becuase all I want right now is the STOCK tune from a 2LT and if I could get a dealer to do it I could keep my warranty. It would just be like they were reflashing a stock 2LT but it would be my 2LS instead.
#18 |
![]() ![]() ![]() ![]() ![]() Drives: 2012 Camaro LS "Hot Blown Six" Join Date: May 2012
Will shut off other things, it is VIN specific, so communication will be a problem between controllers.
#19 | |
![]() ![]() ![]() ![]() ![]() Drives: 550+RWHP 2010 camaro Join Date: Sep 2007
that would work but you would still need tuning software for the trans to adjust your shift points and rpm back to your original settings because the final gear ratio is different between the 2 models, find someone with obd2 tunercats, i have this and i can re-program the trans module seperate from any other module
#20 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '12 SS/RS LS3 IBM Join Date: Dec 2009
The only factory tune alteration I've ever heard of is for an optional available accessory wheel size. Like if you bought a truck with 19's and they had accessory 20's available, they would also have the 20" calibration available. Never heard of using a different model calibration, highly doubt it would work.
#21 |
The new Global Architecture electrical systems do not allow controller swaps between vehicles. Swapping ECM’s or other modules (including Radio, BCM, EBCM, SDM, TCM, ECC (HVAC), EPS, HPCM, VCIM & IPC) on vehicles with the new Global Architecture electrical system will result in damaging both controllers (A NO START CONDITION WILL OCCUR ON BOTH VEHICLES IF THESE MODULES ARE SWAPPED) due to the new vehicle security code protocol (environment) starting with the 2010 MY GDS applications.
#22 |
I called 6 dealers and none would do it (under warranty). Oh well. Ill just wait and tune my stuff when I get my supercharger. Thanks for the input yall.
#23 |
![]() ![]() Drives: 2010 M6 2SS Join Date: Mar 2011
If the cars have different rear gears, then there is most likely no factory calibration available for the 2.92 car with S mode. Dealers can't make their own tunes, they can only flash in what's available from the factory. The gear ratio affects shift points and converter lockup points as well as speedometer calibration. Flashing in a calibration from a 3.23 car will result in the speedo working incorrect, and less than optimal shifts, as well as possible problems not shifting at full throttle.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust. 499 RWHP 463 RWTQ. |
#24 |
![]() ![]() Drives: 2010 Cobalt SS, 1972 Nova Join Date: Sep 2011
We can tune D independently of S and make the car shift differently in S vs D.
And we've been toying with the idea of D being an economy mode and S being power mode. We would do it if there were a lot of interest in it. I don't know how much more MPG we could get out of it, but there's gotta be something on the table. Last edited by BNRacing; 07-20-2012 at 07:27 PM. |
#25 | |
Banned
| Thread Tools | |
