sjm autoprod
Old 07-14-2012, 07:49 PM   #1
bcguy
bcguy
bcguy's Avatar
Drives: 2011 ss/rs m6
1 st race at the track
well i got to go to my first race today at the track,made 3 passes ,12.7,12.9 and 12.3.stock oem tires and i spin at throttle until 3 rd when i can start laying it to it,120 mph top speed,2.38 60 ft time.i know i got some practicing to do.NEED TIRES BADLY.pulled a decent.038 reaction time on one run.going tommorrow and going to try starting off in second,maybe that will help untill i get some different rubber.okay million dollar question,if i start looking for corvette rims,will the 18 inch fit over my calipers(ss)i have not really followed this to closely as i didnt need it up until now.have lots of power and need to hook up ,will drag radials on 18 inch rims be enough for this,sure spins alot and im only pushing 6 to 7 pounds boost,should have pulley for 9 or 10 next week,looking for feed back thanx
Agp 62/66 ,lsx 427. , Callie's ,diamond ,all pro ,American racing ,I'ds130s,102 intake and throttle body,etc .fore triple , Turbo 400 level 5 , b and m pro , dss carbon fiber , dss ford 9 inch with strange pumpkin,3.73 ratio,1400 hp axels,boost and air fuel pillar guages. Weld rts 17x10 and 17x4.5 with m and h drag radials and skinnys
bcguy is offline   Reply With Quote
Old 07-14-2012, 09:46 PM   #2
Neumatic
Neumatic's Avatar
Drives: 2010 Camaro 2SS M6
For the Corvette rims the 18X9.5 +40mm offset and the 18X10.5 + 53mm offset are what will fit over the brembo's.
Neumatic is offline   Reply With Quote
Old 07-14-2012, 09:49 PM   #3
Supercharged SS
Drives: 2010 Camaro
Drag radials will work great!
Old 07-14-2012, 10:07 PM   #4
bcguy
bcguy
bcguy's Avatar
Ok the 18x10.5 plus 53 offset for the rear what year of vette are this rim size from. Need to know what to look for. Thanx
Old 07-14-2012, 10:11 PM   #5
bcguy
bcguy
bcguy's Avatar
Ok you are saying there's will work great.are these what you are running.i would assume a315 can fit on a 10.5. I know there has been numerous posts and opinions on this but Wich one hooks best( brand name)
Old 07-14-2012, 10:12 PM   #6
get some Hoosier QTP's and your Camaro is going to fly.
Old 07-14-2012, 10:35 PM   #7
bcguy
bcguy
bcguy's Avatar
The Hoosier qtp I just googled ,I would love to try that but the largest rim size I see that they will fit on is 16 s unless I read wrong. In order to put that small of rim on I believe we have to modify back brake system(smaller rotor and caliper
Old 07-14-2012, 11:07 PM   #8
bcguy
bcguy
bcguy's Avatar
Checked out corvette replica wheels and they list 58 mm and 56 mm offset not the 53 that they call for. Anybody deal with this
Old 07-15-2012, 12:13 PM   #9
Neumatic
Neumatic's Avatar
There are Bogarts and Welds that are 17" that will fit over the Brembo's. Granted, you do have to drop a pretty penny on them as well.
I believe the 18X10.5 +53mm are the rear rims off of a C5 Corvette Z06.
