sjm autoprod
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Camaro Fest VIII Discussions > 2012 Camaro5 Fest (III)
Old 07-15-2012, 02:32 PM   #1
Indykid
Indykid's Avatar
Drives: 2012 Camaro 2LT Convertible
Camaro5fest and your GPS
I-465 on the west side of Indianapolis has been undergoing a MAJOR widening and upgrading over the last few years. As a result the interchanges, including I-70, I-74 and the Sam Jones Expressway, on the west side of Indy have all changed. As a result my Garmin GPS with the latest map update is wrong and probably so is yours.
Also some of the exit ramps have been extended to the point that if you wait for your GPS to tell you to exit you will have missed it. This is especially true for those of you coming from the west on I-70.
Take it easy, read the signs and you will get where you want to go. Welcome to Indy!
Indykid is offline   Reply With Quote
Old 07-15-2012, 02:40 PM   #2
ripcard
INJACC
ripcard's Avatar
Drives: 2010 Camaro 2SS/RS CGM/IO 6M
Thanks for the heads up.
We'll be coming down from Chicago via I-65, blasting right through Indy to I-70 on our way to meet up with the rest of our gang in Dayton for Aug. 1. Then we'll cruise back with the whole group to C5Fest the next day.
Pedders Xa Coilovers & Sways w/Fe4, Pfadt Rear Trailing Arms & Tie Rods, Forgestar CF5s, ZL1 Brakes, 1LE 3.91 Diff, Pedders Cradle Bushings, MGW STS, BTR Stage II Cam, Fluidampr U/D Pulley, Performance Redline Dyno Tune, CAI & Apex Scoop, Pfadt Tri-Y Headers w/HF Cats, Magnaflow 3" Cat Back, RX Catch Can, VMax TB, Billet Tunnel Brace, SRP Pedals, Skip Shift, Seibon CF Hood & ST Trunk, 1LE Splitter, ZL1 Rockers & Diffuser, Heritage Grill, F & R Sparks "SS" badges, Billet Door Handles, Tint, Technostalgia Tail Lights, AAC Side Markers, BlackVue dash cam and my favourite accessory...Litho #163.
ripcard is offline   Reply With Quote
Old 07-15-2012, 10:33 PM   #3
OldJedi
Use the Force
OldJedi's Avatar
Drives: 1967 Corvette, 2012 ZL1, 2015 Z51
Send a message via AIM to OldJedi
Thanks for the info. We will be coming up from Florida and can use the info.
Walk softly, carry a light saber and drive a ZL1!
OldJedi is offline   Reply With Quote
