JUICEDMOTORSPORTS
Old 07-23-2012, 11:23 PM   #85
2cnd chance
Too Many Great Choices
2cnd chance's Avatar
Drives: Grand Sport/Z07
Originally Posted by wildpaws View Post
And over the rear spoiler to the bottom of the spoiler!
Clyde
Yes! Not down the back/bottom of the trunk.
2cnd chance is offline   Reply With Quote
Old 07-23-2012, 11:27 PM   #86
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Originally Posted by Fraxum View Post
My Z28 Formula:
  • 3,400-3,500 pounds
  • 500 crank hp
  • Small V8 or even a V6 with twin stage turbos
  • Strong fade free brakes with good fluid and reinforced brake lines
  • Light weight 18" wheels
  • Car styled for 18" wheels
  • Michelin Pilot Super Sports
  • Stiff bushings
  • Light understeer
  • Adjustable sways
  • No wheel hop
  • MRC OK, but not required. I'd probably rather upgrade to coil overs.
  • Track geared
  • Cloth Sport seats with side bolsters
  • Integrated roll bar
  • Coolers as needed
  • Brake ducting
  • Aero design with downforce
  • Air flow smoothed under the car
  • Cut outs for off road
  • Numbers on the doors
Okay, I might have to add a few of these things myself.
When I heard there was a Corvette running around with a small turboed V8 it got me to thinking. How perfect would that be for an ATS Camaro?
Your formula sounds great for a 6th gen ATS Camaro Z/28,just won't work for a 5th gen Camaro. For a 6th gen ATS Camaro Z/28, I would add that I want a small, high revving V8 engine, that would suit me better than a V6 TT.
Clyde
wildpaws is offline   Reply With Quote
Old 07-23-2012, 11:28 PM   #87
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Agreed!!
Clyde
Old 07-23-2012, 11:28 PM   #88
Bhobbs
Bhobbs's Avatar
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle
Clyde
Yeah. How ever the original Z28 had them.
Bhobbs is offline   Reply With Quote
Old 07-23-2012, 11:37 PM   #89
Mikes SS
Mikes SS's Avatar
Drives: '10 CGM 2SS/RS 6M
name of the thread...ENGINE for Z/28
Mikes SS is offline   Reply With Quote
Old 07-23-2012, 11:58 PM   #90
wildpaws
wildpaws's Avatar
Drives: 1999 Blazer
Well, we do get a little off track from time to time in this forum, after all, I've been told that six old geezers control it!
Clyde
Old 07-24-2012, 02:41 AM   #91
Bhobbs
Bhobbs's Avatar
I think there is somewhat of an agreement that gen 5 would likely have the LS7 and the gen 6 would have one of the new gen V engines.
Old 07-24-2012, 11:21 AM   #92
OldScoolCamaro
Clyde
...yup , you know how manipulating and controlling us OG's can be.....
Old 07-24-2012, 01:01 PM   #93
Mikes SS
Mikes SS's Avatar
Well especially now with the release of the 6th Gen in MY2016 versus MY15, I see it even more likely to get a Gen V engine in our camaros before the 5th gen is done being stamped
Old 07-24-2012, 08:44 PM   #94
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
My Z28 Formula:
  • 3,400-3,500 pounds Change out the front seats to light weight racing seats and you can pull a lot of weight out of the 5th Gen. That won't happen at the factory. We can delete the sound deadening and other non essential trim i.e. bar bones or minimal console A Quartermaster SCCA T1 or T2 clutch is what 20 pounds lighter... If YOU change out the front seats 3,600 to 3,700 is
  • 500 crank hp
  • Car styled for 18" wheels Bumper height / crash testing are a barrier to this as would be the sheetmetal changes. We're dreaming so why not?
  • Michelin Pilot Super Sports I am not sure why these tires get so much love with a 300 tread wear rating. PS2 with a special ultra sticky compound ie. the GY ZL1 proprietary tires. They are very good, just the wrong size.
  • Stiff bushings Stiffer rubber bushes have undesirable consequences. What we typically want is a more stable arm motion. With bonded to rubber steel ferules what we get is an increase in spring rate, a bounciness to the suspension. GM could use a few more sealed monoballs in the 5th Gen or call Pedders
  • Light understeer 1LE bars come close to this.
  • Adjustable sways Maybe they would do a front adjustable. The new Z style rear bar uses a droplink that is most effective straight up and down which limits adjustability.
  • No wheel hop The XL and XXL ZL1 shafts should do the job.
  • Track geared
  • Coolers as needed
  • Brake ducting
I have no doubt the new DI V8 is absolutely going to be turbocharged at some point and out of the box the NA version more fuel efficient and more powerful than the current LS3 A DI V8 Z/28 would be at least 4 or five years out. That is a long tome to wait.
The reviews I get from people that should know tell me the ATS is an awesome chassis. I also hear a few not so positive comments. We'll all know very soon how close the ATS is in terms of road manners from every auto rag out there.
Old 07-24-2012, 08:58 PM   #95
Mikes SS
Mikes SS's Avatar
I just can't see why some people say this engine would be 4-5 years out?? The trucks and/or the corvette will be sporting them this time next year!!
Old 07-24-2012, 09:02 PM   #96
Bhobbs
Bhobbs's Avatar
He said a new DI V8 Z28 would be 4-5 years out, not the engine itself.
Old 07-24-2012, 09:05 PM   #97
JusticePete
Generally the roll out would have the DI V8 in NA form going to the new truck or Vette depending on which is first to market. The boosted and other higher output derivatives would follow. i.e. a single turbo, then a twin turbo or higher displacement, or... So say the new truck gets it first in 13. A year would roll by bringing the first turbo version out in 14. Say the new Camaro rolls out in 15 as an SS. The Z/28 or ZL1 rolls out a year later as a 16 or maybe 17.
Old 07-24-2012, 09:30 PM   #98
Fraxum
Fraxum's Avatar
Drives: 2016 SS M6
About those stiff bushes, I was hoping for no step out. Is it possible to design the suspension to have compliant bushes that will only allow movement in the plane of the suspension travel?
Won't the ATS be comfortable with 18 inch wheels?
Thanks for the analysis of my dream Z28. It's just a dream.
I can wait for that dream, no hurry. I like my 5th Gen SS, so I will drive it for a while and have fun while I wait. Right now it probably would perform at about 95% of the proposed LS7 Z28. Maybe with some lightweight wheels it would be even closer.
A 5th gen Camaro cannot be the Z28 I dream of. Too big and too heavy. My dream Z28 is ATS sized. But I wonder if all that weight savings has created a less than rigid chassis. Looking forward to the full analysis.
Will you be Pedderizing the ATS? I suppose that higher HP turbo 4 manual will be the car to have.
M6, Pray Ported TB and MSD, E85, LTs, cats, Rotofab Dry, BMR Trailing Arms
