Cold Air Inductions
Old 07-15-2012, 07:11 PM   #1
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Drives: '12 ZL1,67 Cam,68 Biscayne 427 4 sp
ZL1 GEARS...LOOKING FOR 4.10 OR 4.30
What's the deal-ee-o? Can't seem to find any info on replacement gear sets for the ZL-1. Anybody got any ideas?
2012 ZL1
2.55 upper, 10" lower pullies, Innovators west billet hub and sfi balancer, solid blower drive isolator, 50 mm idler kit, full length S/S headers no cats, comp cams custom grind cam, comp roller rocker trunion kit, comp push rods,dual valve springs retainers and locks, Injector dynamics ID850 inectors, Rotofab ZL1 cold air kit, Lingenfelter 160 thermostat, Rotofab intercooler reservoir, stock plugs, LS7 90mm throttle body, GTO clutch reservoir mod, my own custom catch can, Tuning by Jannetty, install by me.
2012ZL1 is offline   Reply With Quote
Old 07-15-2012, 09:31 PM   #2
1st Gen Forever
ZL1 #140
1st Gen Forever's Avatar
Drives: Camaros: 68 SS, 10 2SS/RS, 12 ZL1
Not to sidestep but doesn't the ZL1 have 3.73 already? would 4.10 or 4.30 help much?
1st Gen Forever is offline   Reply With Quote
Old 07-16-2012, 11:41 PM   #3
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
Yup. Car wants to shift into 4th about 100 ft from end of track. running out of rpm in third,and not enough room to rev out 4th. I guess the flip side would be to rev it to 7k, but that seems dangerous.
2012 ZL1
Old 07-17-2012, 05:11 AM   #4
DangerZL1
Drives: Accord
What other GM vehicle shares this rear diff with the larger ring and pinion gear? If you used DRs with a slightly lower height would that drop the effective ratio down enough to force earlier shifts and avoid a gear swap?
DangerZL1 is offline   Reply With Quote
Old 07-18-2012, 01:10 AM   #5
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
hmm. Maybe shorter tires would do it...
2012 ZL1
Old 07-18-2012, 10:40 AM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
If there is another ring gear that would fit, it might be from the 9.5-inch truck axle. It's a semi-floating 14-bolt (I think it was semi-floating...). However - ZL1's ring gear is 9.9-inches (9.8XX").
How about a taller DR? Redline ran a slightly taller Mickey Thompson DR on their car if I remember correctly. That might be worth looking into. It's in the current GMHTP. I think it was a 305/40/18 or something. It would require you to go with a smaller wheel, but it sounded like the tire was taller, which might be a solution.
If you rev' higher, it'd probably be a good idea swapping valve springs/retainers for valve float. ZR1 features forged slugs, titanium rods, intake valves, hollow exhaust valves and better valvetrain, and it's limited to 6600. I'm not saying you couldn't take LSA to 7000, but it was my understanding blown motors don't like being over-rev'd...
JMVHO. I wish you luck
05 Hummer H2 SUV on OEM Air Ride
Forged 11.4:1 408 LQ4 (K1 crank & rods; Mahle pistons)/CPP LS3 CNC heads/BTR Stage IV LS3 cam/home ported L92 intake manifold/ported 90mm TB/custom Volant CAI/mid-length headers/AFE dual 3" CB/Corvette Servo/el cheapo lift/Cognito UCAs/Sphon poly adjustable TA/Sphon adjustable rear LCAs/e'fan conversion/DirtyMax radiator/Moroso catchcan/HPTuners/HID conversion/LED exterior lighting/LED interior accents/Autometer Cobalts/AEM WBPioneer AVH-5600BHS/Pioneer GM-9601/2-Pioneer TS-W310D4s/Obcon Labyrinth dual-12 box/lots of other little stuff
Old 07-19-2012, 02:07 PM   #7
RoketRdr
RoketRdr's Avatar
Drives: 2010 Duramax; 2012 CTS-V Coupe
Depends on what end result you're looking for. You can go with a shorter tire which will give you a quicker ET or you go with a taller tire that will net a higher trap speed. I have a gear ratio, speed and tire size calc in an Excel spreadsheet if you would like to play around with the numbers to see what changing the tire size will do on your rpm's and speed. I've already plugged in the auto and manual gear ratios for the ZL1 as well as stock tire diameter. Shoot me a PM and I'll send it to ya.
RoketRdr is offline   Reply With Quote
Old 07-19-2012, 02:17 PM   #8
RoketRdr
RoketRdr's Avatar
What he said. Run a shorter tire on your DR's and it will cure your problem without swapping gears. Then back to stock tire diameter for fuel mileage and normal street driving.
Old 07-19-2012, 03:16 PM   #9
2012ZL1
CaRaHoLiC
2012ZL1's Avatar
I am already looking for wheels to use with drag radials, but so far can't find any for less than 350 a wheel which is a little steep for occaisional use.
I'm looking for 18" wheels that aren't too heavy.
2012 ZL1
Old 07-19-2012, 08:56 PM   #10
hognutz
hognutz's Avatar
Drives: 2013 ZL1
tire is probabably the way to do this if you still want to be able to throttle out of coners hard on street rubber.
4.10's or 4.30's are nice at the drags but in turns on street rubber you might break grip to easy. I had this issue on a mustang. I think that is why the GT500 went 3.31's.
2017 zl1 or GT350 hmmmm
2015 Hellcat-sold
2013 ZL1 -sold
2013 Dart
2013 Megacab 8" lift 38"mt's
hognutz is offline   Reply With Quote
Old 08-15-2012, 08:15 PM   #11
All-American ZL1
Chevy Power
All-American ZL1's Avatar
Drives: 13 ZL1 M6 #123, '98 Jeep Wrangler
Anyone have an idea of what the smallest size would be that we could run? Any idea of what would be too small of a tire? And will an increase in horsepower affect what tire size we should choose?
All-American ZL1 is offline   Reply With Quote
Old 08-16-2012, 04:40 AM   #12
NASTY99Z28
Drives: 99z28 with bolt-ons and a mwc fab 9
They went with 3.31's so they could hit 60 mph in first, run 200mph and avoid the gg tax. Although I'm sure it does tame the power when coming out of a turn it wasnt the main reason.
I like my woman like my milk shakes, THICK!!!!
NASTY99Z28 is offline   Reply With Quote
Old 08-18-2012, 12:17 AM   #13
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
http://www.f-body.org/gears/
Higgs Boson is offline   Reply With Quote
Old 08-25-2012, 01:05 PM   #14
RoketRdr
RoketRdr's Avatar
Originally Posted by Higgs Boson View Post
No thanks...I like mine better.
