Cold Air Inductions
Old 07-15-2012, 07:25 PM   #1
Supercharged SS
Drives: 2010 Camaro
Anyone ever run this tire:
I just ordered these to use in the true street class. I had gd look with an 18" M&H drag radial so this should be no different.
http://www.mandhtires.com/M-H-Drag-R...7#.UANfY4l5mc0
Thanks!
Old 07-22-2012, 12:51 PM   #2
silverfox
silverfox's Avatar
Drives: 2010 camaro ss
I use them. Have about 30 runs on them and still look good. I run them at 16psi.
There is a discount code to get 15 percent off the price. Dakotartclub.
[SIGPIC][/SIGPIC]Va.Speed built 427 stroker
LS2 Darton sleeved 427 stroker.Callies dragonslayer crankshaft. Callies I beam rods. Wiseco blower pistons. Mast cnc 12 degree big bore ls3 heads-2.2 intake &1.6 ex. 6 bolt 270cc-.750 deck. Lunati link bar lifters.T&D roller rockers.COMP-VA. Speed special cam 605 lift, 238dur. Procharger F1R @15psi. ARH headers with custom 3'' exhaust all the way.Magnaflow mufflers. QTP cutouts.Rossler built 6l80e trans. DSS 1400hp axles.
Pfadt suspension.-Coilovers, sway bars,motor mounts,trailing arms. Aeromotive eliminater pump.
907rwhp.
silverfox is offline   Reply With Quote
Old 07-22-2012, 01:14 PM   #3
Supercharged SS
Drives: 2010 Camaro
Thanks!! Problem is I already have them.
Old 07-22-2012, 03:47 PM   #4
Pro Stock John
Writer
Pro Stock John's Avatar
Drives: 2010 SS / 1967 Camaro
I believe MightyMouse, well known 4th gen car (8.5's street car) ran some and did well with them.
PROJECT HEAVY CHEVY
13.15@106 1.95 | 100% Stock
Old 07-22-2012, 05:50 PM   #5
se7en
Drives: 87 Pinto on 32's
Im wondering about these as well. I wanted to go with some MT's but dont know how much a 26" diameter tire will affect the car over a 28".... anyone know?
se7en is offline   Reply With Quote
Old 07-22-2012, 06:19 PM   #6
Supercharged SS
Drives: 2010 Camaro
Which MT are you thinking about? The 295?
Old 07-22-2012, 06:21 PM   #7
se7en
the 315's
Old 07-22-2012, 06:38 PM   #8
Supercharged SS
Drives: 2010 Camaro
the 315's
What gear is in your car? That tire will def need a retune for the shifting.
Old 07-22-2012, 06:46 PM   #9
se7en
3.91's turning from a 4L65E
Old 07-22-2012, 06:52 PM   #10
Supercharged SS
Drives: 2010 Camaro
May to short. I don't have the formula but that'll give you a working rear ration of over 4.00. Def play havoc on shifting. When I was playing with hearing the 4.10 would make the car shift into 5th right before the finish. I would stay away from the tire. May be a tuning nightmare.
Old 07-22-2012, 06:56 PM   #11
se7en
Yeah i think im gonna stick with the M&H's 28"
Old 07-22-2012, 06:57 PM   #12
Supercharged SS
Drives: 2010 Camaro
The 325 is stupid wide. I think my car will hook with them.
Old 07-22-2012, 07:00 PM   #13
se7en
Wider isnt always better, but im thinking the same way you are at this point. Many IRS's have changed from 345/325/315 to a 295 and 275 and hook a lot better, but im going to try the 325 and see what we get. Ive done almost every trick in the book at this point to get my car to hook up and its still blowing the tires off with just a little throttle off the start. The 325's better work for another $550+
Old 07-22-2012, 07:07 PM   #14
Supercharged SS
Drives: 2010 Camaro
You don't want a slick? The 295, 17" mt ET street worked in my car in the low 600's. At 650 they wouldn't hold the car.
