Rick@Livernois
Old 05-21-2009, 04:51 PM   #1
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
Engine Break in
What is your feelings on engine break in? Drive it like your going to drive it from day one, or give it the 1500 miles like manual says.
TC is offline   Reply With Quote
Old 05-21-2009, 04:53 PM   #2
LDGn63
LDGn63's Avatar
Drives: WNABEE
i've got 200 of the 1500 left to go... and i'm itchin....
Why oh Why?
Windshield=10" vertical
mirror= 3 7/8" (that's almost 4") vertical
that means that the mirror is 38.75% the size of the vertical windshield...
it sure seems like the ratio could be better... just sayin....
our collective MIRROR patch:
http://www.camaro5.com/forums/showthread.php?t=24612
LDGn63 is offline   Reply With Quote
Old 05-21-2009, 05:03 PM   #3
The Dark Knight
Batmobile in Disguise
The Dark Knight's Avatar
Drives: 2009 Pontiac G8
What do you mean by "breaking in"...burnouts? Lead footin it? 0-60 trials?
The Dark Knight is offline   Reply With Quote
Old 05-21-2009, 05:06 PM   #4
tribone
Searchin' ....
tribone's Avatar
Drives: Powered by Bowtie
What he said!!
-Guillermo
My Pictures
Old 05-21-2009, 05:11 PM   #5
sschons74
sschons74's Avatar
Drives: 16 Camaro 1SS & 82 Silverado
Rings and valve seals will last longer if you break her in easy for at least 1500. After 5k it should feel even faster because of break in. Try to keep it under 5 grand until she is used to it, then drive it like you stole it.
sschons74 is offline   Reply With Quote
Old 05-21-2009, 06:04 PM   #6
TEAMBADDASS
2010 2SSRS Camaro #72
TEAMBADDASS's Avatar
Drives: 08denali08dually72chevy2010SS
F#ck that i had 35 dyno pulls in one day @157mph with only 50 miles on it and been taking it to 6700 rpm 50 to 100 times a day breaking that b!tch in..
the harder you drive it the harder it will run..you have to teach them while there young
TEAMBADDASS is offline   Reply With Quote
Old 05-21-2009, 06:08 PM   #7
Number_9
Number_9's Avatar
Drives: 2010 2SS/RS L99
I've always heard this too.... and to not run a consistent speed for too many consecutive miles. I assume this is still true too? Does the manual make mention of anything like this, along with the 1,500 miles?
Number_9 is offline   Reply With Quote
Old 05-21-2009, 06:12 PM   #8
69 Hugger
69 Hugger's Avatar
Drives: 69 Convertible Camaro
Do a search on "engine break in", you should find a couple threads that go into detail on how to break in the motor.
Got this from speedster, Modern engines are nothing like their counterparts of a decade or two ago. Bearing and ring materials are completely different and the level of finish on the crank/rods and cylinder walls is excellent. Valvetrains are also ready to go. These are roller drivetrains so varying the rpm isn't necessary like flat tappets for oil dispersion and tappet rotation.
The professional builders I have dealt with warm up the motor at 1,500 - 2,500 rpm, check for leaks and set the timing/fuel ratios. Then they change the oil and filter to get rid of any residual dirt/particles/break-in lube.
After that, they fire it back up, bring it to temperature and hammer it for as many dyno runs as necessary. This is from personal experience and there are probably factory GM types that know a whole lot more that can chime in.
Basically you are probably pretty safe in whatever break-in method you choose. GM tests these things to failure to make sure you don't...
If you want to be super safe, get to 500 miles to cover the drivetrain and brakes. Matter of fact you can do the pump and fade method to break the brakes in quicker. Change the eingine oil to get out any residual crap. Then fire it up and hammer it !!!
69 Hugger is offline   Reply With Quote
Old 05-21-2009, 08:08 PM   #9
Hoss
Hoss's Avatar
Drives: 2004GMC Extended Cab
OK we need 1500 miles on it......so what does Chevy say about the RPMs and oil changes?
Thanks,
Carl
Hoss is offline   Reply With Quote
Old 05-21-2009, 08:43 PM   #10
JohnnyBfromPeoria
JohnnyBfromPeoria's Avatar
Drives: 2012 LS M6, Black
1. Heat cycle the engine. Start it from cold, go out and heat it up and park it until it cools off. The various materials "grow" and "shrink" ever so slightly, "getting to know each other." Do this several times. Really, the long waits between drives? You can call that bedtime.
2. Vary engine speed if you can. I take that to mean, don't head out on a cross-country trip on the interstate the day you pick it up.
3. Get some good deceleration cycles in there. Downshift sometimes instead of just braking to a stop. You can do this with either transmission. Find a nice long hill and accelerate down it then let it coast down in an appropriate gear. This is the best way to seat the rings quickly.
4. Change the oil. This doesn't help break-in, it gets the tiny metal pieces out of the crankcase and the filter. Don't worry about switching to an oil like Mobil 1, as that particular one, as most others, is a "type 3" synthetic. It's been modified through chemistry, but it isn't any more slippery than conventional oils, therefore will not impede any break-in procedure. It'll just cost a lot when you find out just how much oil your crankcase holds. I think the V-6 holds 7.5 quarts or thereabouts.
5. Use a good oil filter and change it at every oil change. I do not like Fram. I do like Purolator Pure-One, NAPA Gold and Mobil 1's filters. There are good ones that others will mention. Just don't go Fram. I'm thinking change oil/filter at 100/500/1500 miles, then follow the mfgr intervals. Do not buy into Jiffy Lube's hype of 3000 mile oil changes. If GM says 5000, do it then, unless you're driving all dirt roads, all the time, like Bo and Luke Duke or something.
Your mileage may vary. I know guys that do indeed go right out of the showroom and hammer the throttle and swear it's the right way. Maybe it is...just not on my car.
John B.
12 LS M6, IPF S/C, ASA GT-5 wheels, VMax PTB
1995 Mitsubishi Montero SR
1987 Dodge Raider Turbo Project
1986 Mitsubishi Montero 2.4l FI Transplant
JohnnyBfromPeoria is offline   Reply With Quote
Old 05-21-2009, 08:55 PM   #11
craigd853
Drives: 199 SS Camaro
Listen the specs on the new engines being built now don't require a break in. The engine is ran on a dino now and the tolerances on new enginges are not like they were back in the 60's and 70's. Now if I'm wrong then someone please speak up. Thanks if I'm right and sorry if I'm wrong.
craigd853 is offline   Reply With Quote
Old 05-21-2009, 09:07 PM   #12
JohnnyBfromPeoria
Yes and no, CraigD853. The rings still need to seat completely. Deceleration cycling and heat cycling is easy and cheap insurance against a futuire oil-burner.
The brakes also need to be bedded in. Get yourself on a freeway exit ramp at a good clip and apply brakes firmly and consistently. Lather, rinse, repeat. Aviod panic stops for the first couple of days.
These modern engines ARE built with much tighter tolerances and are far more forgiving than 30 years ago. They are also much more expensive to replace if something goes wrong. But it probably won't...
John B.
Old 05-21-2009, 09:45 PM   #13
rays
V6 - It just isn't normal
rays's Avatar
Drives: 2010 2LT M6, F250 7.3L Diesel
John B.
+1
No Fram... The AC Delco filters are very good too. They are selling them at Wally World now too.
2LT RS M6 RJT Black leather
4/29/2009 Ordered
6/24 6000 Delivered
rays is offline   Reply With Quote
Old 05-21-2009, 10:06 PM   #14
Vash
Drives: 00 Blazer
We have threads for this already with lot more info....
BMEP-Or why you only need 1 camshaft rayhawk Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 25 12-03-2008 12:28 AM
LS9 SC old news. Here comes the LSX. 850HP, 840 lb-ft of Torgue 13F20 5th Gen Camaro SS LS LT General Discussions 15 09-22-2008 04:35 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
GM moves closer to HCCI engine production Scotsman Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 16 05-16-2008 06:16 PM
Axial Vector Engine Mr. Wyndham General Automotive + Other Cars Discussion 6 06-20-2007 04:00 PM
