Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums -
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - > Technical Camaro Topics > Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum
Old 07-16-2012, 09:27 PM   #1
Warsteiner's Avatar
Drives: 2016 Red Hot 2LT RS Vert
AMP Ground
I have replaced my factory AMP with a new one. When I originally hooked it up I had the ground wire connected directly to the battery. Someone told me that was not good so we moved the connection to the same bolt that the battery terminal connects to the body with.
The thing is now I get a lot of noise (sounds like an electrical motor running) when the radio is on. I am sure that this is due to a bad ground as when I had it connected directly to the battery terminal I had no such noise. The noise is coming from the speakers and goes away when I turn the car off.
The sound system also sounds a lot better with the car off and just the radio on.
So my question is this, is it really that bad to hook the ground directly to the terminal on the battery? Should I move the Ground back? Where is a good spot to ground the AMP?
BTW I am using 4 AWG wire for power and ground.
Thanks in advance.
Warsteiner is offline   Reply With Quote
Old 07-16-2012, 09:34 PM   #2
OUWAN12's Avatar
Drives: cts
Put it back on the battery , long as you have a fuse on the positive. you be find. less noise. thru radio.
OUWAN12 is offline   Reply With Quote
Old 07-17-2012, 09:01 PM   #3
Drives: Too many to list
Battery, seat belt bolt, main ground point (near battery) are all sufficient points for grounds.
ecko04 is offline   Reply With Quote
Old 07-18-2012, 08:11 AM   #4
Aural Assault Vehicle
darkrider01's Avatar
Drives: 2010 IBM 2SS/RS, 2015 Sierra Denali
Ground it back to the battery. If that does not clear up the noise, get a ground loop isolator for your RCA's.
My amplifier pop/click/thump solution thread
Power Mods * K&N Typhoon CAI, Flowmaster American Thunder cat-back exhaust, Hurst Short Throw Shifter Visual Mods * Black Phantom Grille * 22" T.I.S. 537MS wheels w/ Nitto INVO rubber Suspension Mods * BC Racing Coilovers * Lakewood Strut Tower Brace Audio Mods * Stinger SPP 2250 Battery * Pioneer DEX-P99RS * Pioneer AVH-X7500BT * Scosche Dash Kit * 2 - Mosconi AS200.4 * 2 - JL Audio 13W6v2 * Focal 165KRX2 Power (active) * Mosconi Gladen One 240.2 * Rockford Fosgate Power T1692
darkrider01 is offline   Reply With Quote
