AAC Style
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Road Course/Track and Autocross
Old 07-16-2012, 09:37 PM   #1
rockrau
rockrau's Avatar
Drives: 2010 2ss red LS3
Any tips for my first HPDE ?
Doing my first HPDE at NJMP Thunderbolt 8/22-23/2012.Looking for advice & tips from those who have experience.Car is stock except for Pedders pace car kit with FE4/5 sway bar & lowered 33mm.Planing brake fluid flush(Motul RBF600)& tech 2 weeks prior to event. Tire pressures?Damping settings?Anything?
rockrau is offline   Reply With Quote
Old 07-17-2012, 12:39 PM   #2
ericedelman
ericedelman's Avatar
Drives: 2017 ZL1 (on order)
For stock tires/rims, set the cold pressures to 30psi for the fronts and the rears to 28psi. Recheck them each time you go back on the track, you may have to adjust them during the day, your instructor will help you with this.
Flush the brake fluid, including the clutch line before you go.
Call Pedders and ask what settings they recommend for you.
Tech inspection will happen at the track before you go on, you don't necessarily need to do it beforehand, unless your group requires it.
Bring a cooler with ice water, gatorade, etc....
At your first event it will feel like everything is happening very quickly, so try and relax and go with the flow. Go to the driver's meeting so you can learn where to go on grid, where to enter the track, and where to exit the track. Drive carefully in the paddock. Listen to your instructor.
When you are on track, the best lessons to learn early on are to keep your eyes up so you can see as far ahead of you as possible, and to gently squeeze and release the throttle and brake pedals. Think of a dimmer switch with infinite settings, rather than an on-off switch. Make your steering inputs small, careful, and smooth. If you can do those things, you will have a successful first day at the track.
Specific to Thunderbolt: Park on the asphalt, the grassy area is pretty sandy and the sand will get everywhere. The building with the bathrooms has showers, if it is hot, bring a towel and change of clothes with you for the end of the day. The Millville Queen Diner serves excellent food quickly for lunch when you get a break.
Enjoy your 1st track day!
2017 ZL1 (on order)
ericedelman is offline   Reply With Quote
Old 07-17-2012, 05:26 PM   #3
PfadtRacing
PfadtRacing's Avatar
Drives: 2010 Camaro, 2006 Z06
Biggest Rule - Be safe.
Second Biggest Rule - Have a fantastic time! Don't get caught up in trying to out drive that Spec Miata you're likely to give a pass by too. Remember that driving a skill and there are VERY few that are just born with it, you have to work at it to get faster. Having a great time is the best way to make sure you're going to come back, and get better.
Old 07-17-2012, 07:12 PM   #4
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Rokrau, thanks for asking this. This is good info for many of us here!
Thanks Eric and Phadt. Us newbs really appreciate it. The more 5th gens on the road courses the better, for data!!!!
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-18-2012, 07:30 AM   #5
TLSTWIN
Romans10:9-13
TLSTWIN's Avatar
Drives: /\yes, this is me/\
Learn the track lines first before trying to go fast. Once you learn the lines and braking points, speed will come. You will find a rhythm on the track. DO NOT worry about what is behind you. Focus on the track, your entry point, apex, and exit points. You find SMOOTH throttle imputs work best, not "ON" "OFF"
Like the other guys said, HAVE FUN
Don't set your parking brake unless you absolutely HAVE to.
Do you mind if I ask how much it is and how did you sign up for it? I was on there web page and didn't see a place.
R.I.P. http://www.camaro5.com/forums/showthread.php?t=373249
Back Street Performance has done a great job with ALL my Performance & Suspension mods, highly recommend them (Rich@BSP) he's in my friends list. https://youtu.be/Lht8sKe1Maw
TLSTWIN is offline   Reply With Quote
Old 07-18-2012, 07:51 AM   #6
1977and2010
Tampa Gulf Coast Family
1977and2010's Avatar
Drives: 1977 Z28, 2SSRS 2010 M6
Don't forget a hat and sunblock. Check the dress code. Some groups are liberal and require only closed toe shoes and a helmet others require at least long jeans, long sleeve cotton shirt, and an SA approved helmet (no M ratings). You might also want to ride along the first couple laps with your instructor in your car to get a view of the track which also lets the instructor get a feel for how safe your car is. If you think about it thats a pretty tough job to jump into some strangers car and trust them and their car not to kill them at some serious speeds. And have fun.
1977and2010 is offline   Reply With Quote
Old 07-18-2012, 09:31 AM   #7
Mikamaro
MikeNoMaro
Mikamaro's Avatar
Drives: A 2016 Challenger R/T M6 STP
Excellent tips!!
Eric you should join our performance group.
http://www.camaro5.com/forums/group.php?groupid=244
Everyone is Welcome too!
Track Day Videos: http://www.youtube.com/user/mrgoodman2000/videos
Built #83817, Born January 18th, Christened June 11th 2010, Stolen October 3rd 2016.
Mikamaro is offline   Reply With Quote
Old 07-18-2012, 04:31 PM   #8
rockrau
rockrau's Avatar
TLSTWIN; http://jsrpca.com/ Guys thanks for the info.
Old 07-21-2012, 09:16 AM   #9
rockrau
rockrau's Avatar
Anyone have XA damping setting recommendations?
Old 07-21-2012, 10:30 AM   #10
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
As this is your first HPDE keep it conservative 15 in the front and 15 in the rear. The harder you set the rear damping the looser / faster it will be.
  • You have the brake fluid flush planned. Stainless lines are a plus.
  • Check your pads and replace them if you don't have 60% of the pad to use.
  • I am a maintenance fanatic and would replace the dif, tranny and PS fluids. Fluids are cheap compared to repairs.
  • Double check your belts and tensioner.
  • Lay a wrench on every nut and bolt in the suspension and drive line to verify they are tight.
  • Empty your car of everything including floor mats. You don't need the trunk mat. Your don't need a spare tire in a can / inflator on track. Is your battery secure?
  • Pull your engine cover, coil covers or any other dress up stuff that holds heat.
  • Get a http://www.cg-lock.com/how.html Rob Anderson Info@PeddersUSA.com has them in stock. Staying in your seat will make you faster.
  • Check you lug nut torque.
  • Hydrate. This stuff is intense.
Have fun.
Old 07-24-2012, 07:06 AM   #11
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 10 Legacy 2.5GT, ...
NJMP requires an SA helmet for automotive use, and even though an open-face helmet may be OK for cars with airbags it's still better to have the closed face.
Bring some kind of portable shade to go with your cooler and water/juice. Also some weights to keep loose stuff from blowing away. It can get windy there.
Don't get carried away with tuning the car. There's something to be said for leaving it somewhere near what you're already accustomed to. You're about to start learning a new skill, and trying to learn the car being different at the same time can get in the way of that. The fun part is in the driving (and maybe realizing that you're starting to find that rhythm), anyway.
Track maps of NJMP are available, as are aerial pictures via Mapquest and plenty of videos. I think it would be worth a little time beforehand getting an idea of the layout, where the flag stations are, etc.
Norm
Norm Peterson is offline   Reply With Quote
Old 07-24-2012, 09:12 PM   #12
rockrau
rockrau's Avatar
Thanks guys,especially Pete! I AM SOOOOO EXCITED!!!!
Old 07-30-2012, 03:36 PM   #13
boltvette
boltvette's Avatar
Drives: 1963 Corvette, 2001 Corvette
Angel Pads are a bit more expensive than CG locks, but they do a better job of keeping your butt planted in the seat. They're made by Angelwings Tech.
2-seater "Camaro" w/JMS Racing LS3; C5 Z06 trans; C6 ZR1 exhaust; Dynatech catback; Ron Davis radiator; trans, diff & engine oil coolers; Pfadt JOC Stage 1 bars & shocks; C6 Z51 brakes; Angelwings C5 Track Day Bar; Angel Pads!
boltvette is offline   Reply With Quote
Old 07-31-2012, 08:44 AM   #14
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I have a set and they work well.
http://angelwingstech.com/featured-product-3/
Also, Craig wrote a good article about track day prep for Corvette Online. Check it out here:
http://www.corvetteonline.com/other-...r-first-event/
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
