Jason 98 TA
Old 07-16-2012, 11:13 PM   #1
silvio207col
Drives: ROCH-SS
2012 1LE package?
Does anybody know if the 1LE package will be avail. for the 2012 camaro?
silvio207col is offline   Reply With Quote
Old 07-16-2012, 11:25 PM   #2
MS3DALE
MS3DALE's Avatar
Drives: 2011 2SS/RS LS3/6M Litho#190
No,They are no longer producing 2012's.
'11 IOM 2SS/RS LS3/6M HURST - Roto-Fab CAI-Kook's LTs-CORSA-Black Bear tuned
Proud Litho owner #190 - Homecoming Litho #120
'15 SILVERADO Z71 1500 LTZ Crew Cab - 6.2 "Midnight Edition" -Airaid intake-CORSA
MS3DALE is offline   Reply With Quote
Old 07-16-2012, 11:42 PM   #3
silvio207col
Drives: ROCH-SS
I know there not producing 2012's.. 1LE is just a package like the RS packaege. my question is if they can install the 1LE package in my 2012 camaro
Old 07-16-2012, 11:44 PM   #4
BowtieBelle
They see me trollin'...
BowtieBelle's Avatar
Drives: 217 ci of fury; Chauffeured by SS
2012 production is over as stated above. Who is "they"? That kind of retrofit would be ridiculously expensive...
"Never race anything you can't afford to light on fire and push off a cliff." -CamaroSpike
2011 Custom LT/RS: Bella's Build Thread
BowtieBelle is offline   Reply With Quote
Old 07-16-2012, 11:46 PM   #5
silvio207col
Drives: ROCH-SS
any gm dealer?
Old 07-16-2012, 11:49 PM   #6
BowtieBelle
any gm dealer?
I am gonna say no. If you knew what all elements the 1LE consisted of you'd be surprised. It's more than a few suspension pieces..
Old 07-16-2012, 11:49 PM   #7
silvio207col
Drives: ROCH-SS
shouldn't be no modification required
Old 07-16-2012, 11:51 PM   #8
BowtieBelle
ok.
Old 07-16-2012, 11:51 PM   #9
silvio207col
Drives: ROCH-SS
I guess i'm have to do some research....no help here!
Old 07-16-2012, 11:55 PM   #10
Hylton
Hylton's Avatar
Drives: fanboys and ass kissers crazy.
Do you realize how much it will cost you to retrofit?
Hylton is offline   Reply With Quote
Old 07-16-2012, 11:57 PM   #11
BowtieBelle
maybe I should be more clear.
No GM dealer is going to retrofit your SS to a 1LE. It would require replacing/adding/retooling so many parts the cost would be prohibitive. Half shafts, dampers, gears, toe links, a new transmission (1LE is liquid cooled), adding fuel pickups, etc etc etc... Just to name a few things. Maybe you could do it aftermarket but it'd be far, far cheaper to just buy a '13 1LE.
Old 07-16-2012, 11:57 PM   #12
cbass
Drives: .
Do you just want the black hood wrap?????
The 1LE has..
A different transmission with additional cooling and gearing
Dampers
Different Fuel pump and fuel pickups
Flat bottom steering wheel with microfiber on wheel and shift knob
ZL1 forged wheels
ZL1 toe links
Upgraded half shafts probably off the ZL1
Monotube shocks
Thicker stablizer bars
Different wheel bearings
Tower to Tower brace
You are talking about lots of time and $$$ to try to install all that to a 2012
cbass is offline   Reply With Quote
Old 07-17-2012, 12:03 AM   #13
silvio207col
Drives: ROCH-SS
where did you get this info from??
Old 07-17-2012, 12:06 AM   #14
BowtieBelle
A lot of reading. It's a Camaro forum. We know things.
