Emblempros
Old 07-17-2012, 10:53 AM   #1
kiteman
Drives: 2012 45th Camaro, 2SS/M6
2012 bluetooth voice navi - Android
i previously owned a windows phone 7, which would answer calls and read/send text messages to me over bluetooth in my camaro. that phone did not have turn by turn directions, but my new galaxy s3 on android does.
i can only get my android to allow phone calls over bluetooth in my camaro. i cannot get the audio text messaging like my windows phone, and more annoyingly, i cannot get the voice navigation to read through my camaro's speakers.
is there some setting to change this on either the car or android? it seems like anything on your phone would communicate via bluetooth once bluetooth was enabled. thanks for any help.
kiteman is offline   Reply With Quote
Old 07-17-2012, 01:27 PM   #2
Casper45th
Casper45th's Avatar
Drives: 2012 45th SSRS A6
I haven't figured it out yet, but haven't spent much time on it either. I have a droid razr. I'll try to spend some time working on it this weekend.
Casper45th is offline   Reply With Quote
Old 07-17-2012, 01:50 PM   #3
jrpimp00
jrpimp00's Avatar
Drives: '10 Black/IOM Camaro SS/RS
I think you have to pair it under GM Music Connect and not the phone to hear that. Ill check when I get home
2010 Camaro 2SS/RS Black/IOM //// 1998 Pontiac Trans AM 819 RWHP @ 12 PSI (Turbo)
jrpimp00 is offline   Reply With Quote
Old 07-17-2012, 01:56 PM   #4
Casper45th
Casper45th's Avatar
Hadn't thought of that. I'll check that out tonight too.
Old 07-17-2012, 02:09 PM   #5
GbrilliantQ
¡ʇuɐıןןıɹq
GbrilliantQ's Avatar
Drives: 2011 Camaro IOM 2SS/RS
Yup. You have to connect through gm connect.
Sent from my Galaxy Note
GbrilliantQ is offline   Reply With Quote
Old 07-17-2012, 03:34 PM   #6
kiteman
How do you connect through GM connect? Will the phone still work too?
Old 07-17-2012, 04:43 PM   #7
Pur3vil
Drives: 2010 ABM 2SS/RS M6
For the GM Music Connect option, plug something into USB port (if you have one) hit the menu button on the radio, and go to bluetooth. Pair the device from there and it should create the second connection. My Droid Bionic seems to connect to both the phone connection and the music connection, and will drop the music if I get a call. unfortunately, it usually doesn't re-connect without help. Also, if you are using the music connection solely for navigation, you may have issues with dropping the connection. My solution is to run Pandora, or stream music on the phone over bluetooth to keep it connected.
Pur3vil is offline   Reply With Quote
Old 07-18-2012, 02:34 PM   #8
kiteman
so there is no way to keep it continually connected? if i leave my car now, my phone auto pairs when i get back in the car. i'd like it to do the same for navi and texting aloud as well...
