ADM PERFORMANCE
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Regional Forums > USA - Texas > Local Marketplace
Old 07-17-2012, 01:42 PM   #1
beaSSt 2011
Drives: 2011 SS M6
FS: LS3 heads
These came off a 2011 LS3 with less than 10K miles; Upon pulling off heads, found that some of the valves touched piston
so selling heads with stock yellow valve springs. heads are not milled. First $ 250 takes them. Located near Deep Park/La Porte area.
Ready to be ported and have new valves dropped in; I gained 40 RWHP from a set of ported LS3 heads on my set up.
beaSSt 2011 is offline   Reply With Quote
Old 07-17-2012, 03:23 PM   #2
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Drives: A 4000 Lb BeaSSt
Any damage to the heads themselves or did it just damage the valves? What cam were you running and why did they touch?
TEAM LS3 Best pass: 10.49 @ 135 with M6
730RWHP 650RWTQ ECS S/C stock bottom end, 4L80, 9"
Built by: J-Rod.... Tuned by: Matt Sorian @ FSP (floridaspeedandpower.com)
Check out my youtube channel: http://www.youtube.com/user/6410Jrod
Follow me on Instagram: @J_Rod6410
J-Rod6410 is offline   Reply With Quote
Old 07-17-2012, 03:37 PM   #3
beaSSt 2011
Drives: 2011 SS M6
No damage to heads, just the valves.
LG G6X3- My best guess is that valves hit pistons on a missed shift/over-rev.
Car ran well for a year- put up good numbers. Only reason I found out I had bent valves was when I installed new heads on it.
Old 07-19-2012, 02:51 PM   #4
J-Rod6410
M6 10 second club
J-Rod6410's Avatar
Wow! Good to know. I'm trying to convince my son to get these for his GTO
Did you stay with the same cam and flycut or what? How much total power did you make after the heads? I may pick these up myself to avoid some down time when I do mine.
Thanks.
Old 07-23-2012, 12:50 PM   #5
beaSSt 2011
Drives: 2011 SS M6
Sold
