Jason 98 TA
Old 07-17-2012, 04:23 PM   #1
Higgs Boson
in the ZL1 Market
Drives: 2014 C7; 2015 2500HD
1LE/ZL1 Part Numbers
1LE Diff (3.91) - 22806794
1LE 3.91 Gears only - 22813040 (fits SS and V6 manual)
1LE LH Axle - 22806795
1LE RH Axle - 22806796
1LE Front Sway Bar - 22812946
1LE Front Sway End Link (passenger side) - 22842515
1LE Front Sway End Link (drivers side) - 22842516
1LE Rear Sway Bar - 22786260 (same as ZL1, comes with brackets and bushings)
1LE Rear Sway Bar Endlink (2) - 22761221
1LE Rear Sway Bar Bracket Bolt (4) - 11518623
1LE/ZL1 Wheels 20x10 Black - 22798741
1LE/ZL1 Wheels 20x11 Black - 22798743
1LE/ZL1 Hubs - 22924741 (x2)
ZL1 Toe Rods/Links - 22845487
ZL1 Front Sway - 22842517 (comes with brackets and bushings)
ZL1 Rear Sway - 22786260 (comes with brackets and bushings)
Higgs Boson is offline   Reply With Quote
Old 07-19-2012, 07:46 PM   #2
pouncer72
Drives: 2011 Camaro SS
Send a message via AIM to pouncer72
Diff (complete)
Gears
pouncer72 is offline   Reply With Quote
Old 07-19-2012, 09:20 PM   #3
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Originally Posted by Higgs Boson View Post
I called the GSM at my friendly Chevy dealer for a VIN so I can get PNs....He doesn't have one yet and a locate within 500 miles came up blank. We will try again each week until we get a VIN and some part numbers. :-)
What PNs do we want?
Diff -
Half Shafts -
Wheels (guess I could get that from ZL1) -
Hubs -
No need to check for vins for awhile. The 1LE doesn't go into production till end of Aug and won't hit dealers till Oct at the earliest.
As for parts, the only parts I've seen any interest in is;
- complete diff
- just the gears
Old 07-20-2012, 12:47 AM   #4
monstertodd
monstertodd's Avatar
don't need it to hit a dealer, just for a vin to get stamped.... :-)
guess I'll let the thread die for a month before I resurrect!
Don't worry I'll help you keep it at the top because I'm looking for these parts too!
I just hope they'll fit 2010s.
Old 07-22-2012, 01:04 PM   #5
Avalnch
Avalnch's Avatar
Drives: Rally Yellow Camaro+Avalanche
Another 1LE thread to subscribe to.
Vengeance Kaotik Cam, C.A.I., ARH LT, Pypes Cat Back, ZL1 Shifter+2012LS3VERT bushing, Quantum Brake Ducts, JDP Tow Hook Scorch Yellow Trim Kit, Shark Fin, AAC DRLs+ABLs+SMDs, ZTA Rear Spoiler, R.Y. 1LE Splitter. Pfadt coilovers, camber plates, trailing arms, Pegasus Solid Subframe. Pedders ZL1 barz, radius arm & steering rack bushings. BMR adjustable toe-rods. Hotchkis Max Chassis Brace. ZL1 GMPP Driveline Upgrade. TurnOne P/S pump.
447 HP @ 6180 RPM / 418 TQ @ 5100 RPM
Avalnch is offline   Reply With Quote
Old 07-23-2012, 03:10 PM   #6
Cpanthers85
Drives: 2011 Camaro 2SS RS
I'm just curious if those Axles will slide right in and are going to be less expensive than the 1000hp aftermarket ones.
SUBD!
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 07-23-2012, 03:17 PM   #7
monstertodd
SUBD!
I imagine they'll be cheaper. I don't see why they wouldn't slide right in. As far as I know, the driveline is very similar between the 2010's and 2013's. It's the suspension that is different.
Old 07-29-2012, 02:10 PM   #8
monstertodd
Any new news on this?
Old 07-29-2012, 10:04 PM   #9
BUMBLE-B-TUNA
BUMBLE-B-TUNA's Avatar
Drives: 2010 SS
Subscribed
BUMBLE-B-TUNA is offline   Reply With Quote
Old 07-30-2012, 05:43 PM   #10
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
I had to get my car inspected a couple days ago and the dealer said these parts aren't in the system yet.
Old 07-30-2012, 06:38 PM   #11
monstertodd
Thanks for checking on that.
Old 07-30-2012, 07:22 PM   #12
Driveshaftshop
Driveshaftshop's Avatar
Drives: own more cars than i can list
i was told the axles are the same but have a larger outer CV, so the hubs would have to changed out also.
Driveshaftshop is offline   Reply With Quote
Old 07-30-2012, 08:47 PM   #13
HaubSS
HaubSS's Avatar
Drives: '11 IBM 2SS/RS LS3/M6
I am not sure, but I was under the impression that the Differential is the same, the only difference is the ring and pinion. However the axles are different/upgraded but I don't know if this will be a direct bolt-in or require a hub change as mentioned above.
2011 IBM 2SS/RS - LS3/M6 - Grey Interior
Full bolt-ons + TSP 229/236, 112 LSA
Tuned by BROOKS PERFORMANCE
BMR Stage 3 suspension
MRR 288 - 20x10(+35), 20x11(+43)
HaubSS is offline   Reply With Quote
Old 07-31-2012, 08:45 AM   #14
Badger
Badger's Avatar
Drives: 2010 ABM SS #14 of 2,027
How can the ring and pinion be different if the Differential is the same??...do you mean the gear ratio is different?? 3.91?
"One of the ordinary modes, by which tyrants accomplish their purposes without resistance, is, by disarming the people, and making it an offense to keep arms."
-- Constitutional scholar and Supreme Court Justice Joseph Story, 1840
Badger is offline   Reply With Quote
